Hello there,
I'm doing my undergraduate thesis and I'm using arduino to do so. I'm using a bunch of sensors to get measures of me experiment. These sensores are:
- 1x Water flow sensor (uses interrupt to count pulses).
- 3x vibration sensors.
- 1x Water flow with TDS sensor embedded (uses interrupt to count pulses as well).
- 1x Differential pressure sensor.
- 1x MPU 6050 GY 521 sensor measures accel and gyro (I2C protocol).
I didn't use any library to handle the MPU sensor, instead I've done everything by my self using only Wire and sensor's datasheet. However, when I open the serial monitor to check my values the monitor freezes when it reaches the time to read MPU values for accel and gyro. I've seen that this might have something to do with the other interrupts and this kind of stuff, but since I'm new to Arduino and don't know that much about the matter I'd appreacite some help on this one.
Here is all my code:
// Arduino Nano
// SDA - A4; SCL - A5
// Digital Pins for Interrupt: 2;3
#include <Wire.h>
int HzPerLiterInlet = 98;
int HzPerLiterOutlet = 24;
int interval = 5000;
// Sensors' pins
const byte pinInletFlow = 2; // Pin to Interrupt first flow meter (pure water) YF-s401.
const byte pinOutletFlow = 3; // Pin to Interrupt second flow meter (Air-Water mixture) DWS-MH-01.
int pinPiezo1 = A0; // Piezoeletric Ceramic Vibration sensor pin.
int pinPiezo2 = A1; // Piezoeltric Vibration sensor pin.
int pin801s = A2; // 801s Vibration sensor pin.
int pinPressure = A3; // Differencial Pressure sensor pin.
int pinCond = A6; // Condutance Sensor pin (embedded in DWS-MH-01).
// Pulse variables
volatile double InletPulses; // Inlet flow pulses to count - volatile because it's inside ISR (Interrupt Service Routines).
volatile double OutletPulses; // Outlet flow pulses to count - volatile because it's inside ISR (Interrupt Service Routines).
// Storing Variables
double valueInletFlow; // Inlet water flow - L/min.
double valueOutletFlow; // Outlet Air-Water flow - L/min.
float valuePressure; // Differencial Pressure - kPa.
int valueCond; // Condutance value.
int valuePiezo1; // Vibration value from piezo 1.
int valuePiezo2; // Vibration value from piezo2.
int value801s; // Vibration value from 801s.
// I2C Adress for MPU-6050 sensor
const int MPU = 0x68;
// Variables for MPU
float AccX, AccY, AccZ, Temp, GyrX, GyrY, GyrZ;
// Begin Serial Transmission.
Serial.begin(9600); //baudrate
// Setting MPU 6050 up.
setMPU();
// Attaching functions to interrupt pins for flow meters
attachInterrupt(digitalPinToInterrupt(pinInletFlow),CountInletPulses, CHANGE);
attachInterrupt(digitalPinToInterrupt(pinOutletFlow),CountOutletPulses, CHANGE);
// Printing headers.
Serial.print("Piezo1");Serial.print(",");
Serial.print("Piezo2");Serial.print(",");
Serial.print("801s");Serial.print(",");
Serial.print("Condutance");Serial.print(",");
Serial.print("dP");Serial.print(",");
Serial.print("InletFlow");Serial.print(",");
Serial.print("OutletFlow");Serial.print(",");
Serial.print("AccX");Serial.print(",");
Serial.print("AccY");Serial.print(",");
Serial.println("AccZ");
// Dealing with interrupt
InletPulses = 0; // Resets pulse counter for inlet flow.
OutletPulses = 0; // Resets pulse counter for outlet flow.
interrupts(); // Enables interrupts.
delay(interval);
noInterrupts();
// Reading sensors' values.
valuePiezo1 = analogRead(pinPiezo1); // Piezo 1 value.
valuePiezo2 = analogRead(pinPiezo2); // Piezo 2 value.
value801s = analogRead(pin801s); // 801s value.
valueCond = analogRead(pinCond); // Condutance value.
valuePressure = readDeltaPressure(); // Pressure value.
valueInletFlow = Flow(HzPerLiterInlet,InletPulses); // Inlet flow value.
valueOutletFlow = Flow(HzPerLiterOutlet,OutletPulses); // Outlet flow value.
// Reading MPU 6050 measures
Wire.beginTransmission(MPU);
Wire.write(0x3B);
Wire.endTransmission(false);
Wire.requestFrom(MPU, 14, true); // Solicita os dados ao sensor
AccX = Wire.read() << 8 | Wire.read(); //0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AccY = Wire.read() << 8 | Wire.read(); //0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AccZ = Wire.read() << 8 | Wire.read(); //0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Temp = Wire.read() << 8 | Wire.read(); //0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
GyrX = Wire.read() << 8 | Wire.read(); //0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyrY = Wire.read() << 8 | Wire.read(); //0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyrZ = Wire.read() << 8 | Wire.read(); //0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
// Scaling factor MPU 6050
/* Accel
+/-2g = 16384
+/-4g = 8192
+/-8g = 4096
+/-16g = 2048
Gyro
+/-250°/s = 131
+/-500°/s = 65.6
+/-1000°/s = 32.8
+/-2000°/s = 16.4
// Accel
AccX = AccX/16384;
AccY = AccY/16384;
AccZ = AccZ/16384;
// Gyro
GyrX = GyrX/131;
GyrY = GyrY/131;
GyrZ = GyrZ/131;
// Printing values
Serial.print(valuePiezo1);Serial.print(",");
Serial.print(valuePiezo2);Serial.print(",");
Serial.print(value801s);Serial.print(",");
Serial.print(valueCond);Serial.print(",");
Serial.print(valuePressure);Serial.print(",");
Serial.print(valueInletFlow);Serial.print(",");
Serial.print(valueOutletFlow);Serial.print(",");
Serial.print(AccX);Serial.print(",");
Serial.print(AccY);Serial.print(",");
Serial.println(AccZ);
void CountInletPulses(){
InletPulses++;
void CountOutletPulses(){
OutletPulses++;
float readDeltaPressure(){
float sinal = analogRead(pinPressure);
float dP;
if(sinal<102){
dP = -2.0;
}else{
if(sinal>921){
dP = 2.0;
} else{
dP = (sinal/1023-0.5)/0.2;
return dP;
double Flow(int CalibrationFactor,volatile double pulse_counts){
double Measure;
Measure = pulse_counts/CalibrationFactor/interval*1000;
return Measure;
void setMPU(){
Wire.begin();
Wire.write(0x6B);
Wire.write(0);
Wire.endTransmission(true);
// Configuring Gyro Range
Wire.write(0b00000000); // +/-250°/s
Wire.write(0b00001000); // +/-500°/s
Wire.write(0b00010000); // +/-1000°/s
Wire.write(0b00011000); // +/-2000°/s
Wire.write(0x1B); // Gyro register
Wire.write(0x00000000); // Set Gyro range
Wire.endTransmission();
// Configuring Accel Range
Wire.write(0b00000000); // +/-2g
Wire.write(0b00001000); // +/-4g
Wire.write(0b00010000); // +/-8g
Wire.write(0b00011000); // +/-16g
Wire.write(0x1C); // Accel register
Wire.write(0b00000000); // Set Accel range
