I have a small problem I hope someone having experience with sensors can resolve. I'm using a digital compass sensor hmc5883l. The code to read the compass heading is for a different compass model hmc6352. For some reason I need to use this code for my sensor. So I changed the slave read/write address in the code but it still doesn't work. What else do I need to change. I have very little knowledge about i2c devices.
slave read address for hmc5883l= 0x3D
slave write address for hmc5883l= 0x3C
Code for hmc6352 is posted below
#include <Wire.h>
int HMC6352Address = 0x42;
int slaveAddress;
byte headingData[2];
int i, headingValue;
int headingcompass;
void setup(){
slaveAddress = HMC6352Address >> 1;
Wire.begin();
void loop(){
Wire.beginTransmission(slaveAddress); //the wire stuff is for the compass module
Wire.send("A");
Wire.endTransmission();
delay(10);
Wire.requestFrom(slaveAddress, 2);
i = 0;
while(Wire.available() && i < 2)
headingData[i] = Wire.receive();
i++;
headingValue = headingData[0]*256 + headingData[1];
int pracheading = headingValue / 10; // this is the heading of the compass
if(pracheading>0){
headingcompass=pracheading;
Serial.println("current heading:");
Serial.println(headingcompass);
