Hey!
I am currently trying to figure out how to work with I2C since I don't find working with libraies without knowing how the backend works very interesting. Now I have stumbled across some problems/questions which I hope you can help me out with.
1.) Can I read more than one register at once? Meaning can I send two adresses and then request 2 bytes worth of response?
2.) In the documentation of my sensor is says: "UT = MSB << 8 + LSB" with MSB and LSB being registries. I can't figure out what "<<" is...
3.) It also says that I have to wait 4.5ms between writing the command to determine the temperature and reading the result from the respective registry. Do I have to use a delay here? Does it matter if I wait much longer than that?
Thank you a ton for your answers in advance (=
