I2C simultaneous master & slave communication
Hello This is my first forum on Ardiono site. i really need help.
this is my problem im working on a project to send data from a arduino nano to another arduino nano with i2c. one is the master writer one is the slave receiver. but both of them send and receive from each other at the same time it works fine but i have one problem. the master keeps receiving data from the slave non stop that is what i need, but the slave receives only once and that's it i need the slave also to keep receiving non stop. i tried to reverse the code many times but no result.
This is the master code:
while (Wire.available());
Serial.print("Recieving floats as String...");
Serial.print("Full Array: ");
Serial.print(string);
Serial.print(" Rendement belasting " );
Serial.print(RB);//as a string
//Serial.print(P);//as afloat
Serial.print(" Koppel belasting motor " );
Serial.print(KBM);
Serial.print(" Vermogen belasting motor " );
Serial.print(VBM);
Serial.print(" Temperatuur " );
Serial.print(TMP);
I2C_IN_Data_Array_Invullen();
Wire.beginTransmission(2); // transmit to device #8
dtostrf(Max_Verm, 5, 2, I2C_IN_Data_Array);
Wire.write(I2C_IN_Data_Array); // appx 8 bytes
dtostrf(Max_Snelhd, 5, 2, I2C_IN_Data_Array);
dtostrf(Max_Temp, 5, 2, I2C_IN_Data_Array);
dtostrf(Verm_Setpoint, 5, 2, I2C_IN_Data_Array);
Wire.endTransmission(); // stop transmitting
As you can see the first part is receiving from the slave and second part is sending to the same slave it works very good.
This is code of the slave:
void I2C_IN_Start(int howMany)
do
char c = Wire.read(); // receive byte as a character
I2C_IN_fulldata = I2C_IN_fulldata + c; //Keep saving whatever is comming
MV = I2C_IN_fulldata.substring(0, 5); //slpit String from 0 to 5
MS = I2C_IN_fulldata.substring(5, 10); // Split from 6 to 12
MT = I2C_IN_fulldata.substring(10, 15);// split from 13 to 18
VS = I2C_IN_fulldata.substring(15);//tot aan het einde van array
while (1<Wire.available()); // loop through all but the last
// I2C_IN_Data_Array_Invullen();
Serial.print(" Hele string" );
Serial.print(I2C_IN_fulldata);
Serial.print(MV);
Serial.print(MS);
Serial.print(MT);
Serial.print(VS);
This is the interrupt of receiving here is the problem i guess it receives only once with out repeating.
I need to know why do i have this problem please. Thanks
Please, post your complete codes (with code tags) for both Master and Slave.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks... Tom.. :slight_smile:
while (Wire.available()) ;
WARNING! That ';' at the end of the line is the only statement in your loop. This line will keep the sketch in an empty loop until there is no data in the Wire receive buffer.
Similar problem here.
Thank you John wasser that was the problem the while loop of wire.available that was it i removed the { and } just like the master while wire.availbe loop and it works now good non stop receiving.
Thanks everyone for the help
