Alright I could use some help here on this weird issue I saw today while testing my application.
Long story, short, while trying to debug another issue, I saw in my output logs, messages that only occur in the func mapped to "onReceive" for my Slave device. Here's the thing, for this to have happened, I would have also seen respective output messages on the Master device that it requested data ... but those logs don't exist.
Somehow, the Wire code was thinking a request came in from the Master, when it didn't, only way I can explain it.
Now this doesn't appear to be a common issue, it was a fluke I found it, though it could be happening more frequently then I realize, I've just never seen it in my output messages (I have a lot). Even even more, it doesn't APPEAR to be causing any problem, but, I can't say for sure, as I have another issue I am pinning down, but at the current time, appears to be completely unrelated.
I have already put in place a work around for this, as any message the Master sends to the Slave has a flag in the data that flat out says if the message sent was simply that, or a request for data from the Slave. However, I'd still just like to get a better understanding of what's going on. While yes, my code should prevent this, I feel the base I2C code shouldn't have even gotten to this scenario.
For the record the Master is an ESP32 DevKitC, and the Slave is a Teensy 4.1 (I have also two other Teensy 4.0s on the I2C lines, but they haven't been coded yet, aka, brand new, and aren't doing anything at all)
