Hi There,
I'm trying to write an Arduino to be a motor driver (slave) for an RPi Zero (master) I have. However, whenever the message frequency sent by the RPi is too fast the Arduino completely stops working. When the frequency is low (below 40Hz) it works perfect, but I need it to run at least 100Hz. The message size is 25 bytes.
Even when I look for it through the RPi's I2C command line tool it is not there. I'm not sure what is going on and any insight would be nice.
Thanks!
Arduino Sketch:
#include <Wire.h>
int messageCount = 0;
int debug = 1;
unsigned int motors[6];
Wire.begin(4); // join i2c bus with address #8
Wire.onReceive(receiveEvent); // register event
if (debug) {
Serial.begin(9600); // start serial for output
void clearI2CBuffer(){
while(Wire.available()){
Wire.read();
if (debug) {
Serial.println("****");
Serial.println(messageCount);
for (int i = 0; i < 6; i++) {
Serial.println(motors[i]);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany) {
int i = 0;
int pos[6] = {0};
while (Wire.available()) {
byte temp = Wire.read();
if (i > 0 && i < 25) {
int ind = (i - 1) / 4;
pos[ind] = pos[ind] << 8;
pos[ind] |= temp;
i++;
for (int j = 0; j < 6; j++) {
motors[j] = pos[j];
messageCount++;
slave_receiver.ino (1.96 KB)
