Hi there,
I have an i2c smart card based with the http://www.atmel.com/dyn/resources/prod_documents/doc5279.pdf chip
how would i send commands to read and write this card?
I have a Arduino Mega 1280
thanks
Hi there,
thanks
Thanks richard.
I now have this code:
#include <Wire.h>
void i2c_eeprom_write_byte( int deviceaddress, unsigned int eeaddress, byte data ) {
int rdata = data;
Wire.beginTransmission(deviceaddress);
Wire.send((int)(eeaddress >> 8)); // MSB
Wire.send((int)(eeaddress & 0xFF)); // LSB
Wire.send(rdata);
Wire.endTransmission();
// WARNING: address is a page address, 6-bit end will wrap around
// also, data can be maximum of about 30 bytes, because the Wire library has a buffer of 32 bytes
void i2c_eeprom_write_page( int deviceaddress, unsigned int eeaddresspage, byte* data, byte length ) {
Wire.send((int)(eeaddresspage >> 8)); // MSB
Wire.send((int)(eeaddresspage & 0xFF)); // LSB
byte c;
for ( c = 0; c < length; c++)
Wire.send(data[c]);
byte i2c_eeprom_read_byte( int deviceaddress, unsigned int eeaddress ) {
byte rdata = 0xFF;
Wire.requestFrom(deviceaddress,1);
if (Wire.available()) rdata = Wire.receive();
return rdata;
// maybe let's not read more than 30 or 32 bytes at a time!
void i2c_eeprom_read_buffer( int deviceaddress, unsigned int eeaddress, byte *buffer, int length ) {
Wire.requestFrom(deviceaddress,length);
int c = 0;
for ( c = 0; c < length; c++ )
if (Wire.available()) buffer[c] = Wire.receive();
Wire.begin();
i2c_eeprom_write_byte(0x50, 1, 0xaa);
Serial.println("waiting");
byte temp = i2c_eeprom_read_byte(0x50, 1);
Serial.println(temp);
delay(2000);
Ive tried change the : i2c_eeprom_write_byte(0x50, 1, 0xaa); to : i2c_eeprom_write_byte(0x50, 2, 0xaa);
but it wont write to the second bit!! It writes well to the first but now the second or third. How can i go about to make it right beyond the 1st bit. Also was does the 0x50 represent?
Thanks,
Spooky
