Wiki
Here is a code snippet for the I2C SRAM 47L16
The code can be used in your own projects. No extra library is used, but the necessary functions are here.
* example for 47L16 | 47C16 SRAM with shadow EEPROM
* work like a I2C EEPROM
* has more write cycles and is faster.
* https://ww1.microchip.com/downloads/en/DeviceDoc/47L04_47C04_47L16_47C16_DS20005371D.pdf
* like I2C EEPROM
* pin 2 A1
* pin 3 A2
* pin 4 GND
* pin 5 SDA
* pin 6 SCL
* pin 8 2.7 - 3.6 V 47L## | 4.5 - 5.5 V 47C##
* diffrend
* pin 1 10 uF Cap
* pin 7 high = save to EEPROM
* If the settings for bit 2 are set then the IC saves to the EEPROM when the voltage drops.
* The same happens when a high is set at pin 7
* When the voltage is applied again, the values ββare written back into the SRAM
* Both are possible via software
#include <Wire.h>
#define EEPROM_I2C_ADDRESS 0x50
#define EERAM_CONTROL_ADDRESS 0x18
// Function to write to EEPROOM
void writeEEPROM(int eeaddress, long vala, uint8_t lange)
{ // byte = 1, int = 2; long = 4 ; zahler und subZahler = 6
// Begin transmission to I2C EEPROM
Wire.beginTransmission(EEPROM_I2C_ADDRESS);
// Send memory address as two 8-bit bytes
Wire.write((int)(eeaddress >> 8)); // MSB
Wire.write((int)(eeaddress & 0xFF)); // LSB
// Send data to be stored
Wire.write(vala & 255); vala = vala /256 ;
if (lange >1 ) { Wire.write(vala & 255); vala = vala /256 ; }
if (lange >2 ) { Wire.write(vala & 255); vala = vala /256 ;
Wire.write(vala & 255); }
/* if (lange >4 ) { Wire.write(subZahler & 255);
Wire.write(subZahler / 255); } */
Wire.endTransmission(); // End the transmission
delay(50); // Add delay for EEPROM,
} // writeEEPROM4(int eeaddress, unsigned long vala)
unsigned long readEEPROM(int eeaddress, uint8_t lange) {
uint8_t tea = 0; uint8_t teb = 0; uint8_t tec = 0; uint8_t ted = 0;
uint8_t sea = 0; uint8_t seb = 0;
Wire.requestFrom(EEPROM_I2C_ADDRESS, lange); // Request 4 byte of data at current memory address
while(Wire.available()) {// slave may send less than requested
tea = Wire.read(); // Read the data and assign to variable
if (lange >1 ) { teb = Wire.read(); }
if (lange >2 ) { tec = Wire.read(); }
if (lange >3 ) { ted = Wire.read(); }
/* if (lange >4 ) { sea = Wire.read(); // zweiten Wert mit lesen
seb = Wire.read();
if (eeaddress == 2 ) {
subZahler = (seb*256 + sea);
// Return the data as function output
unsigned long out = teb*256 + tec;
out = out*256 + teb;
out = out*256 + tea;
return out ;
} // readEEPROM( unsigned long, 4 Byte
void saveSRAM2EEPROM() {
Wire.beginTransmission(EERAM_CONTROL_ADDRESS);
Wire.write(85);
Wire.write(51);
delay(10);
void saveEEPROM2SRAM() {
Wire.write(85);
Wire.write(221);
delay(10);
void writeSRAMstatus( uint8_t rdata) {
Wire.write(0);
Wire.write(rdata);
delay(20);
} // writeSRAMstatus( nur byte
void readSRAMstatus() { // byte
uint8_t rdata = 0xFF;
Wire.write(0);
Wire.requestFrom(EERAM_CONTROL_ADDRESS,1);
if (Wire.available()) rdata = Wire.read();
if (rdata == 255 ) { Serial.println("Lesefehler"); return ;}
Serial.println(F(" Status Register "));
Serial.println(F("1M--BBBSE M= mmodified S= Auto-Store E= HS Pin"));
Serial.println(rdata + 256,BIN); // 9. Bit in front cheat then the length is suitable
//Serial.println(rdata);
if (rdata & 128) { Serial.println(F("modified"));
saveSRAM2EEPROM();
if (rdata & 2) { Serial.println(F("Auto Store aktiv"));}
if (rdata & 1) { Serial.println(F("HS pin gespeichert"));}
rdata=(rdata/4) & 7 ;
if (rdata > 0) {
Serial.println(F("Speicherschutz eingeschaltet !")); }
Serial.println(); Serial.println();
//return rdata;
} // readEEPROM( nur byte
* Status Register
* 76543210
* A00BBBAE
* M PPPSV
* 210EE
* N
* T
* AM 1 = SRAM array has been modified
* 0 = SRAM array has not been modified
* 0
* 0
* BP2 - BP0 = 000 = Entire array is unprotected
* 001 = Upper 1/64 of array is write-protected
* 010 = Upper 1/32 of array is write-protected
* 011 = Upper 1/16 of array is write-protected
* 100 = Upper 1/8 of array is write-protected
* 101 = Upper 1/4 of array is write-protected
* 110 = Upper 1/2 of array is write-protected
* 111 = Entire array is write-protected
* ASE 1 = Auto-Store feature is enabled
* 0 = Auto-Store feature is disabled
* EVENT 1 = An event was detected on the HS pin
* HardwareStore 0 = No event was detected on the HS pin
Wire.begin(SDA,SCL) ; //
Wire.setClock(400000); // Set the I2C SCL to 400kHz
Serial.begin(115200); // Serielle Schnittstelle initialisieren
// write to SRAM
uint8_t i = 123 ;
writeEEPROM(0, i, 1) ;
// /\ where to put
// /\ how long in byte
uint16_t j = 2022 ;
writeEEPROM(1, j, 2) ;
uint32_t k = 4444 ;
writeEEPROM(3, k, 4) ;
// save SARM to EEPROM
saveSRAM2EEPROM();
// restore EEPROM to SRMA
saveEEPROM2SRAM();
// set parameter
writeSRAMstatus(2);
// read parameter
readSRAMstatus();
// read SRAM
k = readEEPROM(3, 4)
// /\ where to read
