I have a project where I read temperature from a Si7051 sensor using I2C. To set parameters in this project I use a rotary encoder, and when I turn the encoder CCW +1 clicks the temp sensor running on I2C stops working, last thing it does is setting the temp to around -323.
This does not happen when I turn CW, or when I use the pushbutton on the encoder, and only the I2C stops working, my DS18B20s keep working and so does serial to the Nextion display.
Any help would be really splendid, and yes my program structure is horrible :o)
This is example for ClosedCube Si7051 ±0.1°C Digital Temperature Sensor breakout board
Initial Date: 15-May-2016
Hardware connections for Arduino Mega:
VDD to 3.3V DC
SCL to 21
SDA to 20
GND to common ground
Written by AA for ClosedCube
MIT License
#include <Wire.h>
#include "ClosedCube_Si7051.h"
#include <Encoder.h>
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 3
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Addresses of 3 DS18B20s
uint8_t sensor1[8] = { 0x28, 0xF2, 0x21, 0x0A, 0x06, 0x00, 0x00, 0xFD };
uint8_t sensor2[8] = { 0x28, 0xFF, 0xC1, 0xAE, 0x4E, 0x04, 0x00, 0xE5 };
//uint8_t sensor3[8] = { 0x28, 0x61, 0x64, 0x12, 0x3F, 0xFD, 0x80, 0xC6 }; // Spare sensor
ClosedCube_Si7051 si7051;
int Kp=2, Ki=5, Kd=1; //PID variables start-up values
float SetTemp;
const int buttonPin = 2; // the number of the pushbutton pin
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
int MaxTemp = 25;
Encoder myEnc(18, 19);
sensors.setResolution(sensor1, 9);
sensors.setResolution(sensor2, 9);
// sensors.setResolution(sensor3, 9);
sensors.begin();
pinMode(18, INPUT_PULLUP); // initialize the pushbutton pin as an input
pinMode(19, INPUT_PULLUP); // initialize the pushbutton pin as an input pinMode(2, INPUT_PULLUP);
pinMode(buttonPin, INPUT_PULLUP); // initialize the pushbutton pin as an input
pinMode(10, OUTPUT); // sets the digital pin 10 as output
//Serial.begin(9600);
Serial3.begin(9600);
si7051.begin(0x40); // default I2C address is 0x40 and 14-bit measurement resolution
// switch (si7051.readFirmwareVersion())
// case 0xFF:
// Serial.println("version 1.0");
// break;
// case 0x20:
// Serial.println("version 2.0");
// break;
// default:
// Serial.println("unknow");
// break;
int oldPosition = -999; //rotary encoder
int realPosition;
int pid_p_bit; //ensures PID values arent overwritten by encoder.h value
int pid_i_bit; //ensures PID values arent overwritten by encoder.h value
int pid_d_bit; //ensures PID values arent overwritten by encoder.h value
int t_max_bit;
int test_1 = 11;
int test_2 = 22;
int test_3 = 33;
//************** DS18S20 **********************
sensors.requestTemperatures();
//-------------------PID STATE
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == LOW && buttonPushCounter < 4) {
buttonPushCounter++;
} else if (buttonState == LOW && buttonPushCounter == 4)
{ buttonPushCounter = 0;
// if the current state is LOW then the button went from on to off:
// Delay a little bit to avoid bouncing
delay(50);
// save the current state as the last state, for next time through the loop
lastButtonState = buttonState;
//*****************BUTTON STOP
int temp_pos;
int newPosition = myEnc.read()/4; //rotary encoder
if (newPosition != oldPosition) { //rotary encoder
oldPosition = newPosition; //rotary encoder
Serial.println(newPosition); //rotary encoder
} //rotary encoder
//********************************************SWITCH - CASE
switch (buttonPushCounter) {
case 0: // no input allowed
pid_p_bit = 0; // resets pid value protection bit
pid_i_bit = 0; // resets pid value protection bit
pid_d_bit = 0; // resets pid value protection bit
t_max_bit = 0;
myEnc.write(temp_pos);
case 1: // P input allowed
if( pid_p_bit == 0 )
temp_pos = newPosition;
pid_p_bit = 1;
if (newPosition != temp_pos)
Kp += (newPosition % temp_pos);
case 2: // I input allowed
if( pid_i_bit == 0 )
pid_i_bit = 1;
Ki += (newPosition % temp_pos);
case 3: // D input allowed
if( pid_d_bit == 0 )
pid_d_bit = 1;
Kd += (newPosition % temp_pos);
case 4: // T Max input allowed
if( t_max_bit == 0 )
t_max_bit = 1;
MaxTemp += (newPosition % temp_pos);
float T_floatx100; //converting float to int
int T_intx100; //converting float to int
T_floatx100 = si7051.readTemperature()*100; //converting float to int, multiply x100
T_intx100 = (int) T_floatx100; //converting float to int
int T_Left_int; //converting float to int
int T_Right_int; //converting float to int
float T_Left_float = sensors.getTempC(sensor1);
T_Left_int = (int) T_Left_float; //converting float to int
float T_Right_float = sensors.getTempC(sensor2);
T_Right_int = (int) T_Right_float; //converting float to int
// ********* Temperature alarm
if (T_intx100 > (MaxTemp*100))
digitalWrite(10, HIGH); // sets the digital pin 10 on
else if (T_intx100 < (MaxTemp*100))
digitalWrite(10, LOW); // sets the digital pin 10 off
Serial3.print("x1.val="); //declare which Nextion variable will receive
Serial3.print(T_intx100); // value sent to Nextion
Serial3.write(0xff); //remember to do this 3 times when sending to Nextion
Serial3.print("n0.val="); // state
Serial3.print(buttonPushCounter);
Serial3.print("n1.val="); // should be PID, Kp
Serial3.print(Kp);
//delay(100);
