Dear Arduino-fellows,
I'm just a custom-made PCB with an ATMEGA328P that works quite reliably.
I've hooked up a SHT21 temperature/humidity sensor from sensirion with following library:
The pullups are 5.1kOhm for both SDA and SCL to VCC (checked), no shorts between GND, VCC, SDA or SCL (checked).
My problem is that occasionally (rarely but very frustrating), the code stucks at opening the I2C communication. I'm using an I2C scanner to check if the sensor is plugged in each time before measuring:
for (address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
Serial.print("Scanning address: ");
Serial.print(address);
Serial.print(", ");
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address < 16)
Serial.print("0");
Serial.println(address, HEX);
byte sensoraddress = address;
if (sensoraddress == 64)
state = 1;
Serial.print("SHT21 from sensirion found with internal address ");
Serial.println(sensoraddress);
nDevices++;
else if (error == 4)
Serial.print("Unknown error at address 0x");
if (address < 16)
Serial.print("0");
The code clearly hangs after Wire.beginTransmission. The problem only seems to occur when I plug off the sensor and plug it back (but not always).
Have you got any ideas?
