Hey Everyone,
So I've got a pulse output from a pump that I need to count and display.
I have 2 Arduinos (ATMEGA 328's).
The one arduino reads the pulses and add's the to variable x.
The other arduino requests the pulse count (via I2C) and then does further calculations(Haven't got that far yet).
Here is the I2C slave sketch:
#include <Wire.h>
long x;
byte ch;
const int PUMP = 13;
const int TRIG = 2;
int StaTe = 0;
pinMode(PUMP, OUTPUT);
pinMode(TRIG, INPUT);
Wire.begin(9);
StaTe = digitalRead(TRIG);
if(StaTe == HIGH) {
x++;
digitalWrite(PUMP, HIGH);
delay(100);
digitalWrite(PUMP, LOW);
Wire.beginTransmission(10);
ch = Wire.read();
if(ch == 1) {
Wire.write(x);
else {
Wire.endTransmission();
And here is the I2C Master Sketch:
#include <Wire.h>
byte cH = 1; //set to 1 so the slave device will send x
long val;
Wire.begin(10);
Wire.beginTransmission(9);
Wire.write(cH);
val = Wire.read();
Serial.println(val);
It needs to be over 2 arduino's because the master device will delay for 3 hours and the update the figures.
I'm not great at this but I think I've made a mistake by giving the master a number(10). Maybe you can't send data from a slave I2C device? It's reading -1 on the serial monitor even if I add a pulse on the slave.
Any help would much appreciated
