Hi everyone,
i have a question about i2c variable in this example:
Code for Master:
#include <Wire.h>
Wire.begin(); // join i2c bus (address optional for master)
byte x = 0;
Wire.beginTransmission(8); // transmit to device #8
Wire.write("x is "); // sends five bytes
Wire.write(x); // sends one byte
Wire.endTransmission(); // stop transmitting
x++;
Code for the Slave:
#include <Wire.h>
int a = 0;
Wire.begin(8); // join i2c bus with address #8
Wire.onReceive(receiveEvent); // register event
Serial.begin(9600); // start serial for output
delay(100);
while (!a) {
delay(1);
Serial.println("out!");
a = 0;
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany) {
while (1 < Wire.available()) { // loop through all but the last
char c = Wire.read(); // receive byte as a character
Serial.print(c); // print the character
int x = Wire.read(); // receive byte as an integer
Serial.println(x); // print the integer
a++;
If i comment the "delay(1)" in the Slave code, the variable "a" not change. Why that happen?
Is that code being called from setup or loop? Nope. So it must be being called by an interrupt. There are lots of interrupts besides the ones on pins 2 and 3. This is the one that fires when there is new I2C data.
Delta_G:
Is that code being called from setup or loop? Yes. So it must not be being called by an interrupt. Can this statement be inferred from the above quotation?
is not calling receiveEvent. It's just passing the callback function pointer to the library, which will call them from an ISR.
I think the reference pages for Wire.onReceive() and Wire.onRequest() should mention that the callback function will be called from an ISR with a link to the attachInterrupt() reference page, which describes the limitations/recommendations for ISR code.
GolamMostafa:
In the following sketch, I am calling upon the delay(1000) function from loop(); the program is blinking L (the built-in LED of UNO). However, we know that the delay() function works on TC0 interrupt -- a fact that can be established by including cli() instruction in the setup.
GolamMostafa:
We are working on the OP's code. This coded has absolutely nothing to do with the question we are working on for @markcalaway. If you have questions about how delay works then post your own thread. Please don't hijack and derail this one. Have a little bit of consideration for others Golam.
Delta_G:
markcalaway:
Even the delay(1) is under comment, the variable a is changed from 0 to 1 (Fig-1); but, it is not seen by the loop(). In order to make it available to the loop(), Post#1 has suggested to declare the variable a as volatile taking into account that void onReceive() is an 'interrupt context event handler', and it has solved the problem for the OP (Fig-2).
Figure-1: (with //delay(1) under comment; int a= 0)
Figure-2: (with //delay(1) under comment; volatile int a = 0)
If the delay(1) is kept in the loop(), there is no need to impose volatile modifier on the variable a; the value of the variable (a) is changed from 0 to 1 and the loop() finds it alright (Fig-3).
Figure-3: (with delay(1) in loop); int a = 0)
The dilemma remains unresolved -- is void onReceive() an 'interrupt context event handler' or a 'non-interrupt event handler'. Also, the role of the delay(1) in the loop() is not understood at all in respect of controlling the value of the variable a.
GolamMostafa:
There is no dilemma, read the source code (the ultimate documentation). Wire.cpp, Wire.h, twi.c, and twi.h clearly show that the function called via the pointer passed to Wire.onReceive() is called from ‘ISR(TWI_vect)’ -- Assuming Uno Board. Thus, it’s absolutely in the interrupt context.
gfvalvo:
ISR(TWI_vect){} is called upon again and again to read arrived data byte (s) from TWDR Register and store them onto the Arduino unseen FIFO Buffer. After that, the control goes to the void onReceive() handler to give the user an opportunity to bring out the received data bytes from the unseen FIFO Buffer and put them into user variables for processing.
It is noticed in OP's code that the delay(1) updates the variable a even the variable was not declared as volatile.
Multiple issues. My post merely refuted your claim that there was a 'dilemma' regarding the context in which the callback function is called. There clearly is not.
Regarding the delay() and 'volatile':
You'd have to dig into the final assembly code produced by the optimizing compiler. Using 'volatile' forces the compiler to use the variable's memory location (rather than a value saved in a register) for every access. Not using 'volatile' gives the compiler freedom to do what it wants. Perhaps adding the delay() makes the value of 'a' no longer available in a register.
Point is, it's stupid to ask why things happen the way they do when you've clearly violated the rules. It's like asking why strange and indeterminate things happen when you over-run an array. Do it the right way (in this case use 'volatile') and you won't have to worry about it.
EDIT:
Well, it may not be "stupid", but it is pointless.
Again @Golam, please stop derailing threads because you don't understand how code works. If you have questions then start a thread. Please be respectful of the OP and keep your crazy stuff on another thread. If you have questions about how code works then start your own thread and ask them. But please do not add confusion to the OP by displaying your ignorance on his or her thread.
gfvalvo:
EDIT:
Delta_G:
Who will give the opinion if the above two reactions are in-line or conflicting?
I don't even know what you mean by that sentence. I'm going to report this and hope that maybe one of the mods will help you understand what I mean when I'm asking you to be respectful of the OP and keep this to your own thread. Maybe one of the mods will split it off for you.
