I2C void requestEvent(int howMany) random numbers and warning
I am trying to connect 5 arduinos & and OrangePi with I2C
in my current tests I am facing 2 issues
  1. when compiling I get the following warning
    C:\Users\Antony\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.14\libraries\Wire\src/Wire.h:73:10: note: initializing argument 1 of 'void TwoWire::onRequest(void ()())'
    void onRequest( void (
    )(void) );
2) and second and maybe relevant with the warning, Code in side 1
#include <Wire.h>
String msg = "";
int num =10000;
  Serial.begin(9600);  // start serial for output
  Wire.begin(8);                // join i2c bus with address #8
  Wire.onRequest(requestEvent); // register event
  Wire.beginTransmission(10);
  Wire.write("Hello from loop");
  Wire.endTransmission();
  delay(2000);
void requestEvent(int howMany) {
  Serial.print("I was requested to send");
  Serial.println(howMany);
  num = num +1;
  Serial.print("num value is:");
  Serial.println(num);
  String numfromstring = String(num);
  Wire.write(numfromstring.c_str());
I get random number on serial monitor i.e.:
I was requested to send-26108
I was requested to send772
I was requested to send-6396
I was requested to send-2812
I was requested to send1028
and on the other side ....
#include <Wire.h>
  Wire.begin(10);        // join i2c bus (address optional for master)
  Wire.onReceive(dataReceive);
  Wire.requestFrom(8, 5);    // request 5 bytes from slave device #8
  Serial.print("I received:");
  while (Wire.available()) { // slave may send less than requested
    char c = Wire.read(); // receive a byte as character
    Serial.print(c);         // print the character
  Serial.println("");
  delay(3500);
  Wire.write("Yo"); // respond with message of 6 bytes
 void dataReceive(int byteCount) {
 Serial.println("_");
any ideas?
I was expecting Serial.println(howMany); to print the number 5 to serial
any ideas?
Yes. You should head over to http://snippets-r-us.com for help with your snippets.
PaulS:
Hi, thank you for the notice,
I edited my first post and included all of my test code (I removed some comments only)
The handler registered for the onReceive event has a different signature from one registered for the onRequest event. You are supplying a onReceive handler to the onRequest event registrar.
PaulS:
Hi, thank you for your time,
I'm kind of newbie and didn't clearly understand what you meant.
I tried to remove completely the "Wire.onReceive(dataReceive);" and the "dataReceive" function but i get the same results.
