I2C Waterproof Temperature Probes
I have been using the DS18b20 in a 3-wire configuration, but moving forward it would be easier to have a sensor on the I2C bus so as to simplify the wiring, programming, and communication. Anyone know of sources or manufacturers of I2C bus waterproof temperature probes?
adwsystems:
... moving forward it would be easier to have a sensor on the I2C bus so as to simplify the wiring, .....
Doesn't that mean going from 3 wires to 4? GND, SDA, SCL, & Vcc
It may reduce pin count and indeed programmatic complexity.
JohnLincoln:
Actually going from VCC, GND, SDA, SCL, and One-Wire to just VCC, GND, SDA, and SCL. Not only eliminating the one-wire connection from the cable, but also from the entire project and the pull-up resistor.
But the question is not how to design my project, but where to get the parts...providing they even exist.
