I connect two Arduinos together and would like to have a possibility to change I2C addresses.
Currently if I use wire.h library and initiate one of Arduino with Wire.begin(1);
which works fine. The issue is that as soon as would like to change I2C address and execute Wire.begin(2); and want to attach new receiveEvent/requestEvent, it does not work.
Can you please advise if there is any limitation in current Wire.h library (where I can find sources) for readdressing and if there is other implementation where I will be able to successfully readdress my device?
Thank you!
