I2C with PCF8574 for HD44780 LCD module
As in Arduino UNO I’ve included
#include <PCF8574_HD44780_I2C.h>
PCF8574_HD44780_I2C lcd(0x3F,16,2);
but I have the errors below highligthed in bold, if I include or do not wire.h.
Any suggestion?
ATTENZIONE: la libreria Wire dichiara di funzionare sulle architetture samd e potrebbe non essere compatibile con la tua scheda che utilizza l’architettura samd_beta
In file included from C:\Users\morsani\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21.h:69:0,
from C:\Users\morsani\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd.h:105,
from C:\Users\morsani\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/sam.h:540,
from C:\Users\morsani\AppData\Local\Arduino15\packages\arduino\hardware\samd_beta\1.6.25\cores\arduino/WVariant.h:22,
from C:\Users\morsani\AppData\Local\Arduino15\packages\arduino\hardware\samd_beta\1.6.25\variants\mkrvidor4000/variant.h:24,
from C:\Users\morsani\AppData\Local\Arduino15\packages\arduino\hardware\samd_beta\1.6.25\libraries\Wire/Wire.h:24,
from C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.h:16,
from C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.cpp:11:
C:\Users\morsani\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21g18a.h:226:0: warning: “LITTLE_ENDIAN” redefined
#define LITTLE_ENDIAN 1
In file included from c:\users\morsani\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\sys\types.h:67:0,
from c:\users\morsani\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\stdio.h:61,
from C:\Users\morsani\AppData\Local\Arduino15\packages\arduino\hardware\samd_beta\1.6.25\cores\arduino/Print.h:23,
from C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.h:15,
c:\users\morsani\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\machine\endian.h:17:0: note: this is the location of the previous definition
#define LITTLE_ENDIAN _LITTLE_ENDIAN
C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.cpp: In member function ‘void PCF8574_HD44780_I2C::begin(uint8_t, uint8_t, uint8_t)’:
C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.cpp:82:13: error: ‘_BV’ was not declared in this scope
write4bits(_BV(P4) | _BV(P5));
C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.cpp:82:13: note: suggested alternative: ‘_B’
_B
In file included from C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.cpp:11:0:
C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.cpp: In member function ‘void PCF8574_HD44780_I2C::backlight()’:
C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.h:29:23: error: ‘_BV’ was not declared in this scope
#define LCD_BACKLIGHT _BV(P3) // Led ON
C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.cpp:215:16: note: in expansion of macro ‘LCD_BACKLIGHT’
_backlightval=LCD_BACKLIGHT;
C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.h:29:23: note: suggested alternative: ‘_B’
C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.cpp: In member function ‘virtual size_t PCF8574_HD44780_I2C::write(uint8_t)’:
C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.h:33:12: error: ‘_BV’ was not declared in this scope
#define Rs _BV(P0) // Register select
C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.cpp:228:14: note: in expansion of macro ‘Rs’
send(value, Rs);
C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.h:33:12: note: suggested alternative: ‘_B’
send(value, Rs);
C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.cpp: In member function ‘void PCF8574_HD44780_I2C::pulseEnable(uint8_t)’:
C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.h:31:12: error: ‘_BV’ was not declared in this scope
#define En _BV(P2) // Enable
C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.cpp:256:24: note: in expansion of macro ‘En’
expanderWrite(_data | En); // En high
C:\Users\morsani\Documents\Arduino\libraries\PCF8574_HD44780_I2C\PCF8574_HD44780_I2C.h:31:12: note: suggested alternative: ‘_B’
exit status 1
Errore durante la compilazione per la scheda Arduino MKR Vidor 4000.
Is it trying to use AVR library for ARM Cortex M0?
If I remember right _BV is only defined for AVR
Yes, it could be, it is, but I cannot find a similar library specified for SAMD (_beta).
Do tou where I can find it?
Thanks once more for your help Limba.
Found a solution to the _BV undefined.
Put a
#define _BV(x) bit(x)
on PCF8574_HD44780_I2C.h file to resolve the undefined.
Now the display on I2C works.
