Hello, I'm trying out my new TEA5767 FM radio and it doesnt want to work if i connect it to my arduino mega however it does work when i connect it to the uno.
pin layout:
GND -> GND
Vcc -> 5v
SDA -> SDA(pin 20)
SCL -> SCL(pin 21)
and for the uno i connect the i2c using pin a4 and a5
Have you used the I2C on the Mega board before ?
Which libary did you use ( a link to that library please ).
Pin 20 and 21 is okay : Wire - Arduino Reference
Can you make a photo of it ?
Koepel:
Hello, i have used i2c before but it didnt work aswell, but for that specific problem i found a libary that support different io pins(and now that works) so on pin 21 and 20 i never got it working.
I will do a test to see if the pins even work...
here is the picture:
(there are lots of other things connected to it so dont mind the big mess XD)
EDIT: The pins do work i tested it with a LED and it works.
EDIT 2: The pins also seem to give out a signal high when there is no code on the arduino at all, they will always give a high signal it seems.
You could try the i2c_scanner : Arduino Playground - I2cScanner
It should detect the TEA5767. If it can find nothing, the Mega board might be broken.
What kind of Mega board is it ? A "TDuino" or "ZDuino" or a Geeetech "IDuino" ? That is not an official Arduino Mega 2560 board.
Koepel:
You could try the i2c_scanner : Arduino Playground - HomePage
If you have a defective board, or if the ATmega2560 chip has been damaged, you need a new Mega board anyway.
Thank you for your help, it is indeed a Iduino. atleast now i know that what ever i try will not work, what arduino clone would you recommend? to poor for the real ones XD
Try Ebay or AliExpress. Buy a 'R3' version.
If you are going to buy a cheap clone, you might as well buy the cheapest one of them all. The very cheap boards have a CH340G usb-serial chip, you need to install a driver for that.
A clone with a funny name (ZDuino, IDuino) or no name at all is legal. However, a clone with the 'Arduino' name is not legal, because it was not made by Arduino and does not have the good quality components of a real Arduino board.
Koepel:
Perhaps you can spot the missing connection and solder it.
The SDA and SCL are also next to AREF, near the USB connector. Scroll down for the picture here : https://arduino-info.wikispaces.com/MegaQuickRef
Or this:
Another option is a software I2C on two digital pins, there is a SoftwareWire in the Library Manager.
