iyad
June 11, 2016, 10:09pm
1
HI
---------------------MASTER-------------------
#include <Wire.h>
int volt;
int volt1;
Wire.begin();
Wire.beginTransmission(5);
int available = Wire.requestFrom(5,2);
if (available == 2)
volt = (Wire.read() << 8)| (Wire.read());
Serial.print("volt =");
Serial.println(volt);
Wire.endTransmission();
delay (100);
if (available == 2)
volt1 = (Wire.read() << 8)| (Wire.read());
Serial.print("volt1 =");
Serial.println(volt1);
-------------------------------------SLAVE--------------------------------
#include <Wire.h>
int volt;
int volt1;
byte c[2];
byte b[2];
Wire.begin(5);
Wire.onRequest(requestEvent);
//volt = analogRead(0);
//Serial.println (volt);
//delay(1000);
void requestEvent()
c[0] = highByte(volt);
c[1] = lowByte(volt);
Wire.write(c,2);
delay (100);
volt1 = analogRead(1);
b[0] = highByte(volt1);
b[1] = lowByte(volt1);
Wire.write(b,2);
delay(100);
Values are wrong when read
Does someone can help
thanks
Have you looked at the slave sender and master reader examples that come with the Wire library? Please read the "how to use the forum" and "how to ask a programming question" stickies. You will see how to properly format and post code (without ).
iyad
June 11, 2016, 10:57pm
3
sorry
-------------------master----------------
#include <Wire.h>
int volt;
int volt1;
Wire.begin();
if (available == 2)
volt = (Wire.read() << 8 ) | (Wire.read());
delay (100);
if (available == 2)
volt1 = (Wire.read() << 8 ) | (Wire.read());
-----------------slave-----------------
#include <Wire.h>
int volt;
int volt1;
byte c[2];
byte b[2];
Wire.begin(5);
//delay(1000);
void requestEvent()
Wire.write(c,2);
delay (100);
Wire.write(b,2);
delay(100);
thanks
Those are quote tags, not code tags. You should go back and edit the original message and delete the subsequent one.
This works for me. The master sends a write to the slave to set which "register" you want for the readFrom.
Master:
#include <Wire.h>
Wire.begin(); // join i2c bus (address optional for master)
byte x = 0;
Wire.beginTransmission(13); // transmit to device #13
Wire.write(x); // sends one byte
Wire.endTransmission(); // stop transmitting
delayMicroseconds(100);
if(Wire.requestFrom(13, 2) > 0) { // request 2 bytes from slave device #13
while(Wire.available()) // slave may send less than requested
char c = Wire.read(); // receive a byte as character
Serial.print(c,DEC); // print the character
Serial.print(" ");
else {
Serial.println(F("Fail"));
x++;
if(x > 3) x = 0;
Slave:
#include <Wire.h>
// these are the "registers"
byte array[8] = {2,4,6,8,10,12,14,16};
volatile byte regReq = 0;
volatile byte* rtnPtr;
Wire.begin(13);
Wire.onReceive(receiveEvent);
void receiveEvent(int byteCount)
regReq = Wire.read();
rtnPtr = &array[regReq*2];
void requestEvent()
Wire.write((byte*)rtnPtr,2);
