Can anyone please suggest which MKRZero pins to use for creating an I2S pass-through? I want to connect a SPH0645 I2S Mic and a UDA1334 I2S DAC stereo output simultaneously with MKRZero.
All examples related to I2S based Arduino Sound library only highlights A6 pin of MKRZero as DIN or DOUT. So I was wondering how can it be possible for input and output pcm channels stream on a single pin.
Kindly advice?
Cross posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes writing a detailed answer on this thread, without knowing that someone else already did the same in the other thread.
Repeated cross posting will result in a suspension from the forum.
In the future, please take some time to pick the forum section that best suits the topic of your question and then only post once to that forum section. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum section. It contains a lot of other useful information. Please read it.
