I2S
Hi there,
I'm trying to get my Arduino MKR WiFi 1010 to receive data from a 2 channel 24 bit ADC. The ADC communicates with I2S and the MKR WiFi is I2S compatible. The frequrency has to be very accurate, so an external clock from a timing module handles the ADC to run at 48 kHz. Now to my question. How does the I2S.read() work??
I2S.begin(I2S_PHILIPS_MODE, 24);
int sample = 0;
char data[3];
void myInterrupt(){               //Triggered by the external clock??
   sample = I2S.read();           //How can this read a whole integer??
   data[0]=(sample & 0xff);
   data[1]=(sample>>8 & 0xff);
   data[2]=(sample>>16 & 0xff);
   **The data is then sent through WiFi to another unit**
Are you sure you don't mean I2C rather than I2S?
Please post a complete program.
When posting code please use the code button </>
so your code looks like this
and is easy to copy to a text editor See How to use the Forum
Also please use the AutoFormat tool to indent your code for easier reading.
...R
No, I think I mean I2S.
Thanks anyway.
mjohansson95:
...How does the I2S.read() work??
from github(ArduinoCore-samd/libraries/I2S/src at master · arduino/ArduinoCore-samd · GitHub):
int I2SClass::read(void* buffer, size_t size)
  if (_state != I2S_STATE_RECEIVER) {
    enableReceiver();
  uint8_t enableInterrupts = ((__get_PRIMASK() & 0x1) == 0);
  // disable interrupts,
  __disable_irq();
  int read = _doubleBuffer.read(buffer, size);
  if (_dmaTransferInProgress == false && _doubleBuffer.available() == 0) {
    // no DMA transfer in progress, start a receive process
    _dmaTransferInProgress = true;
    DMA.transfer(_dmaChannel, i2sd.data(_deviceIndex), _doubleBuffer.data(), _doubleBuffer.availableForWrite());
    // switch to the next buffer for user output (will be empty)
    _doubleBuffer.swap();
  if (enableInterrupts) {
    // re-enable the interrupts
    __enable_irq();
  return read;
Thank you!!
mjohansson95:
http://www.arduino.cc/en/Reference/I2S
There is a separate section of the Forum for MKR Boards where I don't go so I would not have wasted my time with a silly question and you would not have had to waste your time answering it.
I am suggesting to the Moderator to move your Thread to that section.
...R
Robin2:
...R
Well, since I2S is not only for the MKR boards I didn't want to limit my answers. You don't have to be so rude about it.
mjohansson95:
Apologies. I was feeling frustrated.
...R
