Ia6b ibus help plss
hello
I want to ask for help. I want to send Ibus signals from a 2560 mega panel to an ia6B receiver. I have seen several times the topic of wanting an autopilot for a fishing boat.
Maybe I am confused, but a transmitter sends a signal to a receiver like an iA6b that is connected to the 'hardware' by throttles, flaps, steering gear, etc.
I do not know what a 2560 mega panel is, but I will assume it is an MCU. You will need to attach some sort of UI and/or controls like a joystick to the MCU, which will decode the joystick and send that signal to the ia6B, which then sends a signal to the steering device.
Does that sound right?
I moved your topic to an appropriate forum category @zsolt9326 .
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Interesting but I do not have a clue as to what you are describing. You will probably get a decent answer if you post links to technical information on each of the hardware items. Explain what type of ibus signal we are talking about.
sorry, I'll try to be more detailed. I have an arduino 2650 mega panel with a GPS sensor connected to it. I can see the GPS data perfectly in the sors monitor with a test code. I want the 2560 mega panel to send the GPS data to the Ia6b receiver so that I can see the GPS data on the remote control. I'll post a picture of what it is, this is not my 2560 mega panel.
Normal to plonk an ibus receiver onto a flight controller then program through inav or similar for any autopilot.
