IBusServo and BNO055
Hello.
ESP32 DevKit v1 board.
I'm trying to combine the IBusServo example from the IBusBM library, with the Bno055 compass.
Separately each one runs ok, adding Compass ... randomly blocks IBusServo or restart board.
How do you think it can be solved...!
If I solve this problem I will add IBusSensor.
#include <IBusBM.h>
// ================================== IBus Servo
IBusBM IBusServo;
HardwareSerial Serial_1(1);
// ================================== Compass
#include "BNO055_support.h"
#include <Wire.h>
#define ADDRESS 0x28
struct bno055_t myBNO;
struct bno055_euler   Yau;
double Compass;
unsigned long lastTime  = 0;
// ================================== I2C
#define SDA_0  19  //
#define SCL_0  21  //
  Wire.begin(SDA_0, SCL_0);
  BNO_Init(&myBNO);
  bno055_set_operation_mode(OPERATION_MODE_NDOF);
  IBusServo.begin(Serial_1);
  Serial_1.begin(115200, SERIAL_8N1, 4, 15);
  // ========================= Compas
  if ((millis() - lastTime) >= 100) //To stream at 10Hz without using additional timers
    lastTime = millis();
    bno055_read_euler_hrp(&Yau);
    Compass = Yau.h / 16.00;  //Convert to degrees
  Serial.print(" Ch 0 = ");
  Serial.print(IBusServo.readChannel(0));
  Serial.print(" Compass = ");
  Serial.println(Compass);
Solved...I used another BNO library ...In tests for now...
Hello... I was happy for nothing, I monitored on the PC from evening to morning for 12-14 hours.
The board restarted 5 times... the problem... not solved.
Something about the idea...!!
Hello..
After a few days...I found the solution.
I read more carefully the description of the IBusBM library and there is the solution.
Issue closed.
