Ic acs71020 arduino full code needed
i need arduino code for energy metering ic acs71020. if anyone have this code and run kindly
Your post was MOVED to its current location as it is more suitable.
Your EMAIL was also removed !
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Internet broke down on at your end???
a quick search returned many results!
CONVENIENT AND ISOLATED POWER MEASUREMENTS VIA SPI OR
I2C USING ACS71020/ACS37800 POWER MONITORING ICS
- See Appendix B
hope that helps....
Sir I have already this code but it didn't work don't know why. I had tried many time. If anyone had tested any other code then send kindly
Your title "full code needed" sounds very demanding.
inbetween the lines I hear you shouting
"hurry up! Send me working code as soon as possible !"
I guess this was not your intention to sound like this.
additionally your avatar
Looks like a man 35 to 40 years old very good clothing and styling that looks like having enough money to engage a software-developper.
Most likely this picture does not show yourself.
All the gaps that you left open by writing so little about yourself and your project become filled with assumings. The demanding words "full code needed" give all the assumings a negative bias.
So if you are not a egoistically demanding person take the time to write a posting where you introduce yourself with your knowledge-level about electronics and programming and what you have done on your own to come closer to your aim to - yeah - what shall your device do? Yes of course powermetering but what is powermetered ? For what purpose? or at least what did you find as code. Even if it is not working code what can
you
provide as information that helps potential helpers to help?
best regards Stefan
