I have a small domotics project where I open the outside door through the intercom.
The intercom is digital so I need to emulate the pushing of two buttons: enable the intercom and press the open button.
I am doing it right now with a relay module but its too big for place it inside of the intercom, and therefor is hanging outside...
These relays basically set to GND and output for the intercom controller, that is normally at 5v. The currect is therefore very low.
I am trying to find an IC to replace these two relays.
Made some tests with the 4066, but the resistance in the output sometimes generates issues.
I have seen that maybe the MAX4644 could be an option, but have no chance to test it.
Essentially what I need is an IC that acts as a relay for very low currents. I know that there are other options like the MOSFETs/opto couplers, but I believe that a IC that matched the requirements could be easier to implement.
Hello why not just use 2 pins on a 5v mcu, if you need it to be small maybe attiny85?
Just have the pins set to input and when you need to push the buttons just change it to output and it will ground the pin, and then just change back to input to release the button.
swe-dude:
Just a thought.
Best of luck!
I am using a Esp8266 that has 3,3V in the output...I though about it, but If I connect it to the GPIO, I would burn it...
The output to low just grounds the pin, so the voltage differential is almost 0, you have to worry about the current your system draws and see if it’s not too much.
ragtap:
Just to be clear, aren't you confusing voltage and current? Being 5v doesn't imply the current is low.
tadashimori:
I know that the current is very low because I read it in the intercom microchip datasheet. I know that current can be hi even with 5 volts.
Additionally, the 4066 supports very low currents, and have never broke any output from the IC.
ragtap:
Ok, I just wanted to confirm if that "Therefore" was about the 5v or about the intercom.
If I'm not mistaken, from the datasheet, the 4066 supports only 10ma.
It's good to check the current anyway, just to be sure, but the Esp8266 can support up to 15ma.
ragtap:
Come to think about it, you'll face the exact same problem with the Esp8266, but the internal resistance is lower (about 50 ohms) instead of the 180 ohms of the 4066
Why isn't the optocoupler a good idea again? It is basically a switch, has about the same internal resistance, and you protect your Esp8266.
tadashimori:
An optocoupler is also of course an option. Is just that is requieres double cabling and it might be more complicated to find (max. current output for 8266 is 12mA) ... any suggestions?
Often you can replace simple buttons by optocouplers - safe (no electrical contract), and will work assuming the current through those buttons is no more than a few mA. If more than that, it's becoming harder - your comment on the use of the 4066 suggests this actually may be the case, but details are missing.
The moment you connect your project to those buttons directly you also need to know the actual voltage level of the poles of the buttons. With that I don't mean the voltage difference when off, but whether the low end of the button is at ground potential, and whether the low sides of both buttons are indeed connected, etc.
Paul__B:
Note that when referring to a "4066", we must be talking about a 74HC4066, not a CD4066 which has much higher "on" resistance.
If pulling to ground, just use a transistor. A bipolar would do, a logic level FET is better and nowadays, almost as cheap.
If you really want proper advice, you need to provide the circuit relating to the intercom device and the information you have on its microcontroller.
I was able to measure the exact current that passes trough the points I want to emulate:14 μA and 5 Volts DC.
Ideally, would need 0 Ω on resistance, but it could be slightly more.
Note that all electronic switches (like the 74HC4066) can only switch things within their own supply range.
If the chip is powered with 3.3volt, then the load must also be <3.3volt and >ground.
Can't switch something 'floating' (no ground shared with the chip).
If you want to switch something not galvanically connected, then use an opto coupler (or opto fet).
Leo..
Wawa:
Leo..
The 74HC4066 is connected to a 5v source. Grounds are now connected. What I essentially need is a relay inside of a IC that would be able to have very low "on" resistance, accepts maximum 14 micro amps and able to switch the status with 3,3 volts.
ragtap:
thanx!
You can use a dual opto coupler, run the inputs in series and the outputs in parallel, assuming there's enough voltage headroom to drive the two in series from 3.3V.
Try this is a medical part from Ablic the HDL6M06503A/B which has a 2.7 Ohm resistance when turned on. Some of the Key Features are:
High-integration facilitates downsizing and cost reduction
32-channel integration provides downdizing and cost reduction of your systems.
Signal voltage-independent low on-resistance for better image quality
Stable 8Ω on-resistance in the range of ±100V ultrasound signal achieves better image quality.
Single 5V power supply for very low power dissipation
A single 5V power supply achieves 14mW at 50kHz all 32-channel switching, and provides a safety design to your systems. Especially suitable for in-probe applications.
Unique pin configuration for efficient PCB wiring
The unique pin-out of poles on one side and throws on the other side reduces the number of board layers, and consequently contributes to compact, low-cost, and light-weight systems. The link is: High-Voltage Analog Switches - ABLIC Inc. Another solution is Maxum, try this link: https://www.maximintegrated.com/en/products/analog/analog-switches-multiplexers/MAX4968B.html
This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
ragtap:
ragtap:
Can't do that.
The ESP8266 usues 3.3volt logic. All I/O must also be powered from the 3.3volt supply of the ESP if you don't want to fry the ESP.
Also means you can't switch anything that's outside 3.3volt/GND.
ragtap:
A 5volt DIL reed relay, powered from 5volt, and switched with an NPN signal transistor.
That will give you full isolation between the ESP and the device, and the common reed switch should have a very low problem-free contact resistance.
Leo..
ragtap:
Any suggestions will be welcome.
Thanx!
No, you don't need 0 Ohm. That is silly.
This is going to a digital input of some kind. That will have a threshold. Maybe anything under 1.4V will be treated as "button pressed". You could have hundreds of ohms, maybe even thousands of ohms and still get less than 1.4V
Use an optocoupler if you are concerned about isolation. Otherwise connect direct to your (5V only) Arduino.
14 uA will have a 1.4V drop at 100 kOhm. So if you keep your resistance below that value you should be able get the thing to switch. You can just try it by connecting a resistor across the contacts, see what happens. This assumes your 14 uA value is correct, it sounds really low to me.
An optocoupler will also have a voltage drop due to the output transistor. Normally not an issue. Again, do try it out, see what happens.
ragtap:
Oh for goodness sake!
Do you have a common ground on the control input and the ESP8266?
Yes? Use a 74HC4066 as the switch, though a simple transistor would be entirely adequate.
The 74HC4066 will respond correctly to the 3.3 V logic while powered at 5 V.
If you have a common ground, there is no need for an optocoupler.
The "on" resistance of the 74HC4066 is 60 Ohms or less. To hold down to 100 mV it will pass 0.1/60 = 1.6 mA which seems plenty more than 14 µA (two orders of magnitude) which is the actual current you measured when you connected the microamps range of your DVM directly across the switch contacts.
