ICE 2BS01 Chip For 12v Square Wave
I'm not very experienced in this area so please excuse my terminology. I'm aware that a 555 chip would be ideal for creating a 12v pulse, but I cannot find one on any of the circuit boards I have lying around. I did, however find an 8 pin chip labeled ICE 2BS01. This is what I could find for a pinout (see photo). I already have a 12v and a 5v power supply. If 5v is necessary, I can just add a relay. This would not be an issue. I also have various capacitors and resistors, so I'm sure I'll have everything I need if this chip will work. I am trying to make a 12v square wave to pulse a fuel injector while it is in an ultrasonic jewelry cleaner, so 250-500hz and a 50% duty cycle would be ideal.
Where does the Arduino fit in (this is an Arduino forum).
Leo..
Oh my bad...I thought since it said general electronics that anything goes. Can someone help me out anyway? I'd really appreciate it. I don't even need a schematic, but just a simple yes or no as to whether or not this can be done. Wouldn't mind a schematic though, or at least a link to a forum that would be willing to help me. I've been considering looking in to an Arduino, but being shunned from the forum like this is a bit discouraging...
Excuse me if I'm wrong, but it didn't take me long to find this thread that has no mention of an Arduino...just a general electronics question that could be applied to an Arduino, as could mine...what gives?
http://forum.arduino.cc/index.php?topic=565320.0
Sorry, didn't want to scare you away like that.
I just think that we should keep general non-Arduino questions out of an Arduino funded forum.
The other poster already having a history of using Arduinos could have made a difference (this is your first post).
The ICE2BS01G seems to be a switchmode power supply driver chip.
Seems not suitable for 500Hz 50% PWM.
A 555 would indead be easy, and also gives a reasonable drive current if needed.
An Arduino can also generate a 500Hz square wave with just two or thee lines of code
A simple transistor with a couple of resistors could change that 5volt signal into a 12volt signal.
Leo..
Ok that's understandable. One more quick question if I may. Would a cheap alarm clock be a good place to find a 555 chip? I've read that 555's are pretty outdated and most things now use surface mounted components. I have an alarm clock here that's probably 15 years old that I never use. Is it worth tearing into?
Doubt that you can find a 555 in an alarm clock.
The 555 timer is more like a hobby item, and not frequently used (anymore) in consumer devices.
That said, I recently used the MIC1557 (tiny 5-pin 555) in a beambreak project.
Time to order some through-hole 555s, an Uno and breadboard to experiment,
and some $2 Nanos for the final projects.
Leo..
Alright thanks for the help. Much appreciated.
How much current is required to open the injector?
Tom... :slight_smile:
