I connect my Arduino Uno R3 with Spakfun 9Dof IMU board which has ICM-20948 on it. I also install the BreakOut library from Sparkfun. I am able to run a few example without turning on DMP. I try to run example 6 with DMP and 9 Quaternion Orientation. To do that, I uncomment line 29 in ICM_20948_C.h as instruction. However, the compiler return following error:
Sketch uses 34972 bytes (108%) of program storage space. Maximum is 32256 bytes.
Global variables use 1075 bytes (52%) of dynamic memory, leaving 973 bytes for local variables. Maximum is 2048 bytes.
Sketch too big; see https://support.arduino.cc/hc/en-us/articles/360013825179 for tips on reducing it.
Compilation error: Error: 2 UNKNOWN: text section exceeds available space in board
I tried to remove print out messages but it still does not have enough space for the sketch. Do you have any idea that can help me get over this situation?
