ICMPPing versus EthernetUdp
Hello
My system : Arduino Ethernet.
My IDE version : 1:1.0.5+dfsg2-2
The problem:
My program:
I have removed all unnecessary lines.
LOOP
Get the time from a timeserver.
Do it a second time.
Then ping a other server.
After the ping routine I get a SUCCES back. That works.
Continue the program it stops on the line:
Serial.println(" end write “);
** Udp.endPacket();**
Serial.println(” sendNTPpacket return");
The printlines are for debug reason.
My output on the monitor:
QUOTE
LOOP
counter = 1
enter sendNTPpacket 132.163.4.101
start NTP: write packetBuffer,NTP_PACKET_SIZE
end write
time server return
Udp
The UTC time is 1427644102
LOOP
counter = 2
end write
time server return
Udp
The UTC time is 1427644113
LOOP
counter = 3
ICMPEchoReply = 192.168.178.200
ICMPEchoReply = SUCCESS
wait 10 sec
go on
end write
UNQUOTE
After the line “end write” nothing happens anymore.
So, What went wrong. How to solve it.
Many thanks for your time.
Have a nice day
NTP_Ping_test.ino.txt (4.61 KB)
I have never used the ICMPPing library. You may have a conflict between the udp sends. Add this function to your sketch and call this before and after the ping. Insure all is ok with your sockets.
#include <utility/w5100.h>
byte socketStat[MAX_SOCK_NUM];
void ShowSockStatus()
  for (int i = 0; i < MAX_SOCK_NUM; i++) {
    Serial.print(F("Socket#"));
    Serial.print(i);
    uint8_t s = W5100.readSnSR(i);
    socketStat[i] = s;
    Serial.print(F(":0x"));
    Serial.print(s,16);
    Serial.print(F(" "));
    Serial.print(W5100.readSnPORT(i));
    Serial.print(F(" D:"));
    uint8_t dip[4];
    W5100.readSnDIPR(i, dip);
    for (int j=0; j<4; j++) {
      Serial.print(dip[j],10);
      if (j<3) Serial.print(".");
    Serial.print(F("("));
    Serial.print(W5100.readSnDPORT(i));
    Serial.println(F(")"));
The status codes:
0x0 = available
0x14 = tcp socket waiting for a connection
0x17 = tcp socket connected
0x1C = tcp socket connected waiting for close
0x22 = udp
Hallo Tim.
Thanks for the reply.
I made thwe change, results:
QUOTE
counter = 1
end write
time server return
Udp
The UTC time is 1427725721
LOOP
counter = 2
SockStatus 1
Socket#0:0x22 8888 D:132.163.4.101(123)
Socket#1:0x0 0 D:0.0.0.0(0)
Socket#2:0x0 0 D:0.0.0.0(0)
Socket#3:0x0 0 D:0.0.0.0(0)
SockStatus 2
Socket#0:0x0 0 D:192.168.178.200(0)
wait 10 sec
go on
end write
UNQUOTE
I think I solved it.
The UDP routine uses socket 0.
The ping routine uses also socket 0.
I changed the line 14(SOCKET pingSocket = 0;)
into
SOCKET pingSocket = 2;
Now it loops.
Now testing the compleet program
Manny thanks for your help.
Henk
That seems odd that the code doesn't check that socket 0 is being used. It should pick an unused socket. Just a thought, but what if you had a web server running on socket 0? I wonder if it would stop the server?
edit: Where did you get the ICMPPing library? I would like to test it.
