Hola a todos muchachos estoy teniendo problemas al inciar con el icomsatv1.1, al parecer la tarjeta no reconoce el comando if (gsmAccess.begin(PINNUMBER) == GSM_READY) ya que no lo descubre y el programa queda ahi, lo que corri es lo siguiente
#include <GSM.h>
// PIN Number
#define PINNUMBER "1508"
// initialize the library instance
GSM gsmAccess; // include a 'true' parameter for debug enabled
GSMVoiceCall vcs;
String remoteNumber = "51xxxxxxxxx"; // the number you will call
char charbuffer[20];
// initialize serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.println("Make Voice Call");
// connection state
boolean notConnected = true;
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while (notConnected)
notConnected = false;
Serial.println("Not connected");
Serial.println("GSM initialized.");
Serial.println("Enter phone number to call.");
// add any incoming characters to the String:
while (Serial.available() > 0)
char inChar = Serial.read();
// if it's a newline, that means you should make the call:
if (inChar == '\n')
// make sure the phone number is not too long:
if (remoteNumber.length() < 20)
// let the user know you're calling:
Serial.print("Calling to : ");
Serial.println(remoteNumber);
// Call the remote number
remoteNumber.toCharArray(charbuffer, 20);
// Check if the receiving end has picked up the call
if (vcs.voiceCall(charbuffer))
Serial.println("Call Established. Enter line to end");
// Wait for some input from the line
while (Serial.read() != '\n' && (vcs.getvoiceCallStatus() == TALKING));
// And hang up
vcs.hangCall();
Serial.println("Call Finished");
remoteNumber = "";
Serial.println("That's too long for a phone number. I'm forgetting it");
remoteNumber = "";
// add the latest character to the message to send:
if (inChar != '\r')
remoteNumber += inChar;
no se si alguien pueda ayudarme a encontrar una solucion a esto, adicionalmente el datasheet que tengo del modulo no me es muy claro alguien que me pueda ayudar
