ICS & XML parsing
I'm looking to create a device that would need to parse both ICS (Internet Calendars) and XML (Weather Data). I find it surprising that nobody is doing this already, but I can't find any examples or libraries anywhere on either of these.. I'm sure it's not the easiest task to do, but I'm willing to write my own, I'd just prefer not to recreate the wheel if it's already been done. Can anyone out there point me to examples on either of these? Thanks in advance!!
Below is some internet weather data code. You might search the forum for "weather" to see other code.
// Include description files for other libraries used (if any)
#include <SPI.h>
#include <Ethernet.h>
// Define Constants
// Max string length may have to be adjusted depending on data to be extracted
#define MAX_STRING_LEN  20
// Setup vars
char tagStr[MAX_STRING_LEN] = "";
char dataStr[MAX_STRING_LEN] = "";
char tmpStr[MAX_STRING_LEN] = "";
char endTag[3] = {'<', '/', '\0'};
int len;
// Flags to differentiate XML tags from document elements (ie. data)
boolean tagFlag = false;
boolean dataFlag = false;
// Ethernet vars
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 102 };
byte server[] = { 140, 90, 113, 200 }; // www.weather.gov
// Start ethernet client
EthernetClient client;
  Serial.println("Starting WebWx");
  Serial.println("connecting...");
  Ethernet.begin(mac, ip);
  if (client.connect(server, 80)) {
    Serial.println("connected");
    client.println("GET /xml/current_obs/KRDU.xml HTTP/1.0");
    client.println();
    delay(2000);
    Serial.println("connection failed");
  // Read serial data in from web:
  while (client.available()) {
    serialEvent();
  if (!client.connected()) {
    Serial.println("Disconnected");
    Serial.println("==================================");
    Serial.println("");
    client.stop();
    // Time until next update
    //Serial.println("Waiting");
    for (int t = 1; t <= 15; t++) {
      delay(60000); // 1 minute
      //Serial.println("Reconnected");
      client.println();
      delay(2000);
      Serial.println("Reconnect failed");
// Process each char from web
void serialEvent() {
   // Read a char
	 char inChar = client.read();
   //Serial.print(".");
   if (inChar == '<') {
      addChar(inChar, tmpStr);
      tagFlag = true;
      dataFlag = false;
   } else if (inChar == '>') {
      if (tagFlag) {
         strncpy(tagStr, tmpStr, strlen(tmpStr)+1);
      // Clear tmp
      clearStr(tmpStr);
      tagFlag = false;
      dataFlag = true;
   } else if (inChar != 10) {
      if (tagFlag) {
         // Add tag char to string
         // Check for </XML> end tag, ignore it
         if ( tagFlag && strcmp(tmpStr, endTag) == 0 ) {
            clearStr(tmpStr);
            tagFlag = false;
            dataFlag = false;
      if (dataFlag) {
         // Add data char to string
         addChar(inChar, dataStr);
   // If a LF, process the line
   if (inChar == 10 ) {
      Serial.print("tagStr: ");
      Serial.println(tagStr);
      Serial.print("dataStr: ");
      Serial.println(dataStr);
      // Find specific tags and print data
      if (matchTag("<temp_f>")) {
	      Serial.print("Temp: ");
         Serial.print(dataStr);
      if (matchTag("<relative_humidity>")) {
	      Serial.print(", Humidity: ");
      if (matchTag("<pressure_in>")) {
	      Serial.print(", Pressure: ");
         Serial.println("");
      // Clear all strings
      clearStr(tmpStr);
      clearStr(tagStr);
      clearStr(dataStr);
      // Clear Flags
      tagFlag = false;
      dataFlag = false;
// Other Functions //
// Function to clear a string
void clearStr (char* str) {
   int len = strlen(str);
   for (int c = 0; c < len; c++) {
      str[c] = 0;
//Function to add a char to a string and check its length
void addChar (char ch, char* str) {
   char *tagMsg  = "<TRUNCATED_TAG>";
   char *dataMsg = "-TRUNCATED_DATA-";
   // Check the max size of the string to make sure it doesn't grow too
   // big.  If string is beyond MAX_STRING_LEN assume it is unimportant
   // and replace it with a warning message.
   if (strlen(str) > MAX_STRING_LEN - 2) {
      if (tagFlag) {
         clearStr(tagStr);
         strcpy(tagStr,tagMsg);
      if (dataFlag) {
         clearStr(dataStr);
         strcpy(dataStr,dataMsg);
      // Clear the temp buffer and flags to stop current processing
      clearStr(tmpStr);
      tagFlag = false;
      dataFlag = false;
      // Add char to string
      str[strlen(str)] = ch;
// Function to check the current tag for a specific string
boolean matchTag (char* searchTag) {
   if ( strcmp(tagStr, searchTag) == 0 ) {
      return true;
      return false;
I've actually read that already and it is definitely a help, so thank you however I was just surprised that nobody has written any libraries for it yet.. oh well, off to coding I go!
You might check TextFinder below.
http://playground.arduino.cc/Code/TextFinder
