ICSP & ATTINY - Potential problem?
Hey guys, this is my first (and possibly silly) question.
I've design a Attiny breakout board, dedicated to controlling MOSFET Transistors (designed for demonstrating the basics to newbies). However, I wish to program them via ICSP.
I have 2 tiny SMT Transistors + 10k Resistors connected to pin 0 and pin 1. My question is, will this disrupt programming the board via ICSP? As far I as can read online, it can potentially skew the CLOCK and DATA signals - but there's nothing exact.
Any advice or workarounds (assuming the above is a problem) would be greatly appreciated.
Cheers!
0 & 1 are connected to the gates of the MOSFETs? They should [edit: Not] present a problem for the programmer.
Can you post the schematic you're planning to use?
I think this would be okay, if you put the ISP connection on the chip-side of the resistor in series with the gate (you do have a resistor in series with the gate, right?), but I would not get boards made like that without testing it.
@Crossroads - 0 & 1 are connected to the gates.
@Drazzy - 10k Resistors are indeed at the gates - it isconnected chip side. I'll be running it on a breadboard first. I do not have a schematic at the moment, I'm still tinkering - but I will have a full schematic by the end of the week, subject to my results.
Thank you for your help, guys!
If I run into trouble, I'll be back.
