I use OLED I2C module.
In I2C, the SCL is secured with A5 and the SDA with A4.
I want to use the same pin with the same radio module and OLED display.
Do you know how to change the fixed pins of a radio module or an OLED display?
If so, please teach me how.
If these modules don't have address jumpers you can:
- use an I2C multiplexer with each device on a separate I2C bus, or
- use a software I2C library. (source: markd833, gy-86 and ds3231 i2c address problem - #4 by markd833 - Networking, Protocols, and Devices - Arduino Forum)
I want to use the OLED I2C display with the TEA5767 radio module.
But their SCL/SDA pins are the same as A4/A5 each.
The libraries you use are Adafruit_GFX_Library, Adafruit_SSD1306, and TEA5767-master.
To use these two together, is there a way to change the fixed pin?
No, unless you want to try soft I2C
I2C is a bus so the A4 and A5 arduino pins can be shared with multiple devices including the TEA5767 and the display.
What else is using pins A4 and A5 in your project ?
Duplicate topics merged
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a timeout from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
As already mentioned, both devices can share the same bus assuming they have different I2C addresses.
That is indeed, the whole purpose of the I2C bus- all devices requiring it connect to the same two pins. They have individual addresses. If you have two of the same device, they will provide a means to be set to different addresses.
