IDE 1.6.0 Error Compiling
I just upgraded to the 1.6.0 IDE from 0021 and have a very basic error when trying to compile anything.
Anyone seen this? It appears to be unique to this laptop as I tried it on another and it compiled OK.
Here is the output from "blink".
Arduino: 1.6.0 (Windows 7), Board: "Arduino Micro"
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_MICRO -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8037 -DUSB_MANUFACTURER= -DUSB_PRODUCT="Arduino Micro" -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\micro C:\Users\Rob\AppData\Local\Temp\build1987345327900460104.tmp\Blink.cpp -o C:\Users\Rob\AppData\Local\Temp\build1987345327900460104.tmp\Blink.cpp.o
Error compiling.
I just observed the same problem on my system upgrading from version 1.0.6 to 1.6.0. The new version shows the same problem as described. I'm running Windows 7, 32 bit, and I tried to install using both the zip version and the installer version, but both ends up with the same problem. Version 1.0.6 works still perfect.
C:\Arduino.160/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Arduino.160\hardware\arduino\avr\cores\arduino -IC:\Arduino.160\hardware\arduino\avr\variants\standard C:\Users\Arne\AppData\Local\Temp\build34513421954879069.tmp\sketch_feb17a.cpp -o C:\Users\Arne\AppData\Local\Temp\build34513421954879069.tmp\sketch_feb17a.cpp.o
Error compiling.
Arduino: 1.6.0 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Blink.ino:18:21: fatal error: Arduino.h: No such file or directory
compilation terminated.
Error compiling.
I've been given this error notice even when I try to compile basic program.
Could you try to select an Arduino Uno board and see if it compiles (just compile, no upload of course) ?
If it works, that would be a very similar problem to mine: code that worked on previous versions of IDE now complains that a standard include file is missing - [FIXED] Code using SoftwareSerial on ATTiny won't compile on IDE 1.6 - Installation & Troubleshooting - Arduino Forum
Just my 2 cents
Vicne
Vicne:
If it works, that would be a very similar problem to mine: code that worked on previous versions of IDE now complains that a standard include file is missing - [FIXED] Code using SoftwareSerial on ATTiny won't compile on IDE 1.6 - IDE 1.x - Arduino Forum
Just my 2 cents
Vicne
Mine had compile error and Arduino.h missing. Even if I tried to compile arduino given example file I only get the same error result.
I have a different compilation error (below). The sketch copiled and ran correctly before downloading the new IDE. The error seems to relate to a call made from within the SD library, because there is no line in my code that explicitly calls #include <SPI.h>.
Arduino: 1.6.0 (Windows 7), Board: "Arduino Uno"
Build options changed, rebuilding all
Using library SD in folder: C:\Program Files (x86)\Arduino\libraries\SD
Using library Wire in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\libraries\SD\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire C:\Users\JREYNO~1\AppData\Local\Temp\build9217287351094844719.tmp\Ardulog_RTC_JCR_test_program.cpp -o C:\Users\JREYNO~1\AppData\Local\Temp\build9217287351094844719.tmp\Ardulog_RTC_JCR_test_program.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\libraries\SD\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire C:\Program Files (x86)\Arduino\libraries\SD\src\File.cpp -o C:\Users\JREYNO~1\AppData\Local\Temp\build9217287351094844719.tmp\SD\File.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\libraries\SD\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire C:\Program Files (x86)\Arduino\libraries\SD\src\SD.cpp -o C:\Users\JREYNO~1\AppData\Local\Temp\build9217287351094844719.tmp\SD\SD.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\libraries\SD\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp -o C:\Users\JREYNO~1\AppData\Local\Temp\build9217287351094844719.tmp\SD\utility\Sd2Card.cpp.o
C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp:26:17: fatal error: SPI.h: No such file or directory
#include <SPI.h>
Error compiling.
Well I have solved my own issue, anyway. Seems I now need to explicitly include the SPI library if I'm using the SD library. Then it compiles without errors.
snusmumriken:
How did you do that? can you please help, im new to arduino.
Add this to the top of you sketch
#include <SPI.h>
Or Tools:Import Lbrary, select SPI
Hello all!
I have a similar problem:
today I've installed the 1.6.0 (before a had 1.0.6 and work fine, no problems).
Now, when I compile a sketch a simple generic error message appear, with no details :disappointed_relieved:
This i my error message: "Errore durante la compilazione" (error during compyling)
This is my code:
  // initialize digital pin 13 as an output.
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // turn the LED off by making the voltage LOW
Someone can help me please?
Tanks,
Roberto.
I have download and installed arduino 1.6.0 ide (windows 7). I have a error message when I compile the example file. But I did not connect any kits. Just I want to connect proteus 8.0. so I need hex file only. The error message is
C:\Program Files\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard C:\Users\CMTES\AppData\Local\Temp\build8788625360128460962.tmp\Blink.cpp -o C:\Users\CMTES\AppData\Local\Temp\build8788625360128460962.tmp\Blink.cpp.o
Error compiling.
Anyone will give solution to me. My mail id : embedded.kannan@gmail.com
snusmumriken:
Thank you! Same problem here, same solution. I'm very grateful to you for posting your solution - I don't think I would have thought of it.
:slight_smile:
I had the same problem, when I compiled hello world basic program, it shows me very long list with error... Nothing work. Now, I try run Arduino as administrator by right click on icon and Arduino IDE run without compiling problem. Try if it works too, not just me.
Also I can not work with the new versions of IDE :frowning:
I tried again with V1.6.0 up to 1.6.5, but when I try to compile the sketch easier, I have an endless list of errors.
Returning to V1.0.6 all back to work. :o
My PC is Windows 7 64-bit, I am a user with administrator rights, and there is also installed Cygwin, but I renamed the folder and checked the contents of the environment variables, but does not change anything.
Attached the list of errors that I get compiling unmodified blink.ino on V1.6.5
Thanks to anyone who will help me.
errors.txt (8.79 KB)
