I'm seeing either a hang and/or a crash when just adding a syntax error to a minimal sketch and clicking the check button. When it hangs, it hangs inside the "Save sketch folder as ..." which is blank.
Was IDE 1.6.3 tested on Ubuntu 15.04 or is it too early?
Steps to reproduce:
Using latest stable Ubuntu release 15.04 on a 64-bit laptop:
wastenot@dell1:~/arduino-1.6.3$ cat /etc/issue
Ubuntu 15.04 \n \l
Install Java using instructions at How To Install Java on Ubuntu 12.04 with Apt-Get | DigitalOcean
Java version:
$ wastenot@dell1:~$ which java
/usr/bin/java
wastenot@dell1:~$ java -version
Picked up JAVA_TOOL_OPTIONS: -javaagent:/usr/share/java/jayatanaag.jar
java version "1.7.0_79"
OpenJDK Runtime Environment (IcedTea 2.5.5) (7u79-2.5.5-0ubuntu1)
OpenJDK 64-Bit Server VM (build 24.79-b02, mixed mode)
Download arduino 1.6.3 and extract it. Then run it:
wastenot@dell1:~$ cd ./arduino-1.6.3/
wastenot@dell1:~/arduino-1.6.3$ ./arduino
Insert an #error pragma to cause an error to occur:
#error an error here
Sometimes it crashes right away before the "Save your sketch" pops up. When it does crash it consistently crashes like this:
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007f9d7bdfcfdd, pid=10530, tid=140314247022336
# JRE version: OpenJDK Runtime Environment (7.0_79-b14) (build 1.7.0_79-b14)
# Java VM: OpenJDK 64-Bit Server VM (24.79-b02 mixed mode linux-amd64 compressed oops)
# Derivative: IcedTea 2.5.5
# Distribution: Ubuntu Vivid Vervet (development branch), package 7u79-2.5.5-0ubuntu1
# Problematic frame:
# C [libjavagtk.so+0x8fdd]
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/wastenot/arduino-1.6.3/hs_err_pid10530.log
# If you would like to submit a bug report, please include
# instructions on how to reproduce the bug and visit:
# http://icedtea.classpath.org/bugzilla
./arduino: line 29: 10530 Aborted (core dumped) java -Dswing.defaultlaf=com.sun.java.swing.plaf.gtk.GTKLookAndFeel $SPLASH processing.app.Base --curdir $CURDIR "$@"
Thinking this might be due to the OpenJDK, I downloaded jre-8u45-linux-x64.tar.gz from https://java.com/en/download/linux_manual.jsp?locale=en and extracted it.
Then I set the PATH to point to the extracted oracle jre bin directory:
wastenot@dell1:~/arduino-1.6.3$ export PATH=$HOME/Downloads/jre1.8.0_45/bin:$PATH
wastenot@dell1:~/arduino-1.6.3$ which java
/home/wastenot/Downloads/jre1.8.0_45/bin/java
wastenot@dell1:~/arduino-1.6.3$ java -version
java version "1.8.0_45"
Java(TM) SE Runtime Environment (build 1.8.0_45-b14)
Java HotSpot(TM) 64-Bit Server VM (build 25.45-b02, mixed mode)
And retried the test. Again the crash looks similar:
Sketch uses 450 bytes (1%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
# SIGSEGV (0xb) at pc=0x00007f43cd3b7c84, pid=13373, tid=139927563380480
# JRE version: Java(TM) SE Runtime Environment (8.0_45-b14) (build 1.8.0_45-b14)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.45-b02 mixed mode linux-amd64 compressed oops)
# C [libpthread.so.0+0x9c84] pthread_mutex_lock+0x4
# /home/wastenot/arduino-1.6.3/hs_err_pid13373.log
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
./arduino: line 29: 13373 Aborted (core dumped) java -Dswing.defaultlaf=com.sun.java.swing.plaf.gtk.GTKLookAndFeel $SPLASH processing.app.Base --curdir $CURDIR "$@"
