IDE 1.6.4 will not run on
Guys
Can anyone help?
I have installed 1.6.4 for the first time. I have never used Arduino before and have no previous IDE installs. The driver install worked 1st time. The Arduino Green Power light is on and is powered by the USB cable. The "L" LED is flashing.
When I double click the Arduino IDE icon on my desktop sometimes the splash screen appears for 1 sec then dissapears. Running the IDE exe from Command prompt does nothing.
I have ran the arduino debug exe and the following message appeared.
"Error occured during innitialisation of VM
Could not reserve enough space for 524288KB object heap"
Arduino Info
Original Arduino UNO R3
Operating System Info
Windows 7 Ultimate (x64) Service Pack 1 (build 7601)
Install Language: English (United States)
System Locale: English (United Kingdom)
Installed: 1/22/2012 4:00:03 PM
Processor Info
2.10 gigahertz Intel Celeron Dual-Core
64 kilobyte primary memory cache
1024 kilobyte secondary memory cache
64-bit ready
Multi-core (2 total)
Not hyper-threaded
Java Version
Oracle Corporation - Java Platform SE Auto Updater Version 2.8.25.18
Oracle Corporation - Java(TM) Platform SE 8 U25 Version 8.0.250.18
Oracle Corporation - Java(TM) Platform SE 8 Version 8.0.25.18
Can anyone help me get my Arduino running?
Thanks
Update...
I ran this at the command line: arduino.exe --l4j-debug
I then opened the log file that was generated using: launch4j.log
This is what is there when the notepad opens - any ideas?
Version: 3.7
CmdLine: C:\Program Files (x86)\Arduino\arduino.exe --l4j-debug
WOW64: yes
Working dir: C:\Program Files (x86)\Arduino.
Bundled JRE: java
Check launcher: C:\Program Files (x86)\Arduino\java\bin\javaw.exe (OK)
Loading: C:\Program Files (x86)\Arduino\arduino.l4j.ini
Add classpath: lib\antlr.jar
Add classpath: lib\apple.jar
Add classpath: lib\arduino-core.jar
Add classpath: lib\bcpg-jdk15on-152.jar
Add classpath: lib\bcprov-jdk15on-152.jar
Add classpath: lib\commons-codec-1.7.jar
Add classpath: lib\commons-compress-1.8.jar
Add classpath: lib\commons-exec-1.1.jar
Add classpath: lib\commons-httpclient-3.1.jar
Add classpath: lib\commons-lang3-3.3.2.jar
Add classpath: lib\commons-logging-1.0.4.jar
Add classpath: lib\ecj.jar
Add classpath: lib\guava-18.0.jar
Add classpath: lib\jackson-annotations-2.2.3.jar
Add classpath: lib\jackson-core-2.2.3.jar
Add classpath: lib\jackson-databind-2.2.3.jar
Add classpath: lib\jackson-module-mrbean-2.2.3.jar
Add classpath: lib\java-semver-0.8.0.jar
Add classpath: lib\jmdns-3.4.1.jar
Add classpath: lib\jna.jar
Add classpath: lib\jsch-0.1.50.jar
Add classpath: lib\jssc-2.8.0.jar
Add classpath: lib\pde.jar
Launcher: C:\Program Files (x86)\Arduino\java\bin\javaw.exe
Launcher args: -splash:./lib/splash.png -Dsun.java2d.d3d=false -Xms128M -Xmx512M -classpath "lib;lib\antlr.jar;lib\apple.jar;lib\arduino-core.jar;lib\bcpg-jdk15on-152.jar;lib\bcprov-jdk15on-152.jar;lib\commons-codec-1.7.jar;lib\commons-compress-1.8.jar;lib\commons-exec-1.1.jar;lib\commons-httpclient-3.1.jar;lib\commons-lang3-3.3.2.jar;lib\commons-logging-1.0.4.jar;lib\ecj.jar;lib\guava-18.0.jar;lib\jackson-annotations-2.2.3.jar;lib\jackson-core-2.2.3.jar;lib\jackson-databind-2.2.3.jar;lib\jackson-module-mrbean-2.2.3.jar;lib\java-semver-0.8.0.jar;lib\jmdns-3.4.1.jar;lib\jna.jar;lib\jsch-0.1.50.jar;lib\jssc-2.8.0.jar;lib\pde.jar" processing.app.Base
Args length: 640/32768 chars
Exit code: 0
Solved:
  1. Enabled all of my Windows Services
  2. Disabled kaspersky Internet Security
Works fine
