I am trying to set optimisation for speed (O3). I change all the Os is platform.txt file to O3 found in ...\arduino-1.6.8\hardware\arduino\avr.
However when I compile is it still should as compiling with Os optimisation.
I recently installed the latest update for boards and this is when this problem issues appeared. before that it was compliling with O3 optimisation just fine.
When I switched from 1.6.7 to 1.6.8, changed platform.txt in 1.6.8 folder, the issue was still there as well.
sherzaad:
When you installed the boards update you also installed a new, unmodified, platform.txt so that's the one you need to edit. It is located at Arduino15\packages\arduino\hardware\avr\1.6.10\platform.txt. Even though Arduino IDE 1.6.8 includes Arduino AVR Boards 1.6.10 the one in the Arduino15 folder overrides it. The Arduino15 folder is found at C:\Users(username)\AppData\Local\Arduino15 or you can also locate it at File > Preferences > More preferences can be edited directly in the file.
