IDE 1.7.10 has no Borad Manager listed
IDE 1.7.10 TOOls/Board menu has not Board Manager on top
how to add the Board Manager to this IDE?
latest IDE 1.8 Install shows lot of error to Install for Java components?
Also posted to the issue tracker:
I've already responded regarding the 1.7.10 issue on your issue report but I think this is a good place for us to do preliminary investigation of the mysterious "lot of error" you mention. If we determine they are caused by a bug in the Arduino IDE then you can proceed to report them on the Arduino IDE issue tracker but maybe we can resolve them here without having to involve the Arduino developers.
Please install Arduino IDE 1.8.5 from http://www.arduino.cc/en/Main/Software and then post the full text of all error messages you encounter as well as any additional information that might be helpful.
pert:
https://github.com/arduino/Arduino/issues/6917
I’ve already responded regarding the 1.7.10 issue on your issue report but I think this is a good place for us to do preliminary investigation of the mysterious “lot of error” you mention. If we determine they are caused by a bug in the Arduino IDE then you can proceed to report them on the Arduino IDE issue tracker but maybe we can resolve them here without having to involve the Arduino developers.
Wow, pert, I went to sleep for a few months after installing V1.6.9 and already we’re up to V 1.8.5.
Mate, I’ve got to ask, is there any real benefit in upgrading at this point, or should I sit on my hands for a bit longer?
V1.6.9 still works fine for me, and is very stable. I’m worried that upgrading will result in some earlier stuff not working when I provide firmware upgrades to customers. (Not that I have many customers - I’ve well and truly reached retirement age, but I must look after my people as long as possible. :slight_smile: )
Glad to see you back on the forum OldSteve!
The jump from 1.6.x to 1.8.x happened after arduino.cc and arduino.org were merged back together. arduino.org had been using the 1.7.x versions for their IDE so .cc skipped right over 1.7 to 1.8. That’s why wolvel is finding the Boards Manager feature missing from 1.7.10 even though it has been in the .cc IDE since somewhere around 1.6.4. Even though the 1.7 IDE has a higher version number actually it was based on an old 1.6 version and not significantly improved from that point.
Probably the biggest change that has happened since the 1.6.9 release is an upgrade of the Arduino AVR Boards toolchain. That added a higher level of compiler optimization (LTO) which can significantly reduce your sketch size in some cases. There was some growing pains, but that was actually related to the AVRDUDE version upgrade rather than the compiler and that was resolved in 1.6.11. The main problems I’ve seen people encountering with the new compiler version are limited to macOS.
There have also been a bunch of minor bug fixes and enhancements but that might not matter to you if you’re not having any problems with 1.6.9. There have also been some new bugs introduced along the way but 1.8.5 has been pretty good. I can’t think of any serious new problems with it.
They’re actually working on 1.9.0 right now. That will have some significant changes, including a reworking of the sketch preprocessor. You may remember what happened the last time they did that in 1.6.6 but hopefully this time around it won’t be so painful. They’re trying to get beta testers for that version but I don’t know how many people are actually doing it. You can find the download for it in the beta section of the Software download page. There have been some bug reports on the beta but it doesn’t look too bad so far.
Hello sir! i am having problem to install Esp8266 board manager on portable Arduino Ide1.6.5-r5, i have tried
many methods such as to download from board manager by adding portable folder in Arduino installation
folder,also add additional board manager i-e
URL"http://arduino.esp8266.com/stable/package_esp8266com_index.json"during installation through board
manager unfortunately i get an error "error dowloading
https://github.com/esp8266/Arduino/releases/download/2.3.0/esp8266-2.3.0.zip" beside that i manually
downloaded the package but don’t know the exact directory for the package Thanks in advance!
pert:
The jump from 1.6.x to 1.8.x happened after arduino.cc and arduino.org were merged back together. arduino.org had been using the 1.7.x versions for their IDE so .cc skipped right over 1.7 to 1.8. That's why wolvel is finding the Boards Manager feature missing from 1.7.10 even though it has been in the .cc IDE since somewhere around 1.6.4. Even though the 1.7 IDE has a higher version number actually it was based on an old 1.6 version and not significantly improved from that point.
Probably the biggest change that has happened since the 1.6.9 release is an upgrade of the Arduino AVR Boards toolchain. That added a higher level of compiler optimization (LTO) which can significantly reduce your sketch size in some cases. There was some growing pains, but that was actually related to the AVRDUDE version upgrade rather than the compiler and that was resolved in 1.6.11. The main problems I've seen people encountering with the new compiler version are limited to macOS.
There have also been a bunch of minor bug fixes and enhancements but that might not matter to you if you're not having any problems with 1.6.9. There have also been some new bugs introduced along the way but 1.8.5 has been pretty good. I can't think of any serious new problems with it.
They're actually working on 1.9.0 right now. That will have some significant changes, including a reworking of the sketch preprocessor. You may remember what happened the last time they did that in 1.6.6 but hopefully this time around it won't be so painful. They're trying to get beta testers for that version but I don't know how many people are actually doing it. You can find the download for it in the beta section of the Software download page. There have been some bug reports on the beta but it doesn't look too bad so far.
Thanks for the info pert. I'll stick with 1.6.9 just for the moment, but will probably upgrade after 1.9.0 is released, if it sounds like there are no problems with it. Otherwise, I'll wait until V1.9.1.
