IDE 1.8.0, Arduino Zero, Raspberry Pi, CMSIS-Atmel not available
I downloaded and installed IDE 1.8.0 on my Raspberry Pi 2 Model B running the latest Raspbian Jessie.
Works great with my UNO board.
I am unable to use it with my Zero board.
Under Board Manager I selected "Arduino SAMD Boards (32-bit ARM Cortex-M0+) by Arduino" when I clicked "Install" next to "1.6.11". I got the following error:
"Tool CMSIS-Atmel is not available for your operating system."
What can I do to fix or work around this?
I have submitted a bug report: CMSIS-Atmel not available on ARM Linux - cannot install latest SAMD boards · Issue #2 · arduino/ArduinoModule-CMSIS-Atmel · GitHub
Until an official fix is released you have two options:
  1. Use SAMD boards 1.6.8 or older. They do not use CMSIS-Atmel.
  2. Save the attached file to disk (but not in ~/.arduino15) and add
file:///wherever/you/put/it/package_xx_index.json
to Preferences > Additional Boards Manager URLs.
After that you should see
“Arduino SAMD Boards (32-bits ARM Cortex-M0+) by Arduino *** Workaround for ARM Linux/CMSIS-Atmel ***”
in the Boards Manager. (Just the versions that use CMSIS-Atmel.)
package_xx_index.json.txt (7.04 KB)
It has been fixed now, no workarounds necessary.
Great! Thank you. It all works now.
