Hello,
When saving a code, the Arduino IDE freezes. Impossible to do anything.
Impossible to close the IDE, from the IDE page.
To close the IDE, I have to go in the "Tasker Manager", and deactivate "JAVA (TS) Platform SE Binary (32bit)
I uninstalled the IDE and reinstalled, no change.
Please suggest a solution.
Jean-Luc
Bonjour,
Lors de la sauvegarde d'un code, l'IDE Arduino se fige. Impossible de faire quoique se soit. Impossible de fermer l'IDE, depuis la page de IDE. Pour fermer l'IDE, je dois aller dans le "Tasker Manager", et désactiver "JAVA (TS) Platform SE Binary (32bit)
J'ai désinstallé l'IDE et réinstallé, pas de changement.
Try running the arduino_debug.exe. which is located in the Arduino installation folder, which is in C:\Program Files (x86)\Arduino\ by default. Depending on the output then you can proceed to the following options:
Hello,
It seems, I found a solution.
I uninstalled the Arduino IDE with REVO Uninstaller, after that, I installed again Arduino IDE.
Uninstalled IDE with Windows uninstaller doesn't run corretly.
I work with the new installation since 1 hour without problem.
Regards
Jean-Luc Liège Belgium
