IDE 2.0.0 Keeps prompting for the same library update
Every time I launch IDE 2.0.0 I get a prompt to update the Adafruit DotStar Library
It says the currently installed version is 1.1.5, with the update as 1.2.1
When I click install there's a popup that says that the Adafruit DotStar 1.2.1 Library has a dependency that is Adafruit BusIO, which isn't currently installed.
I select Install All the output window displays
Already installed Adafruit DotStar@1.2.1
Already installed Adafruit BusIO@1.13.2
If I close & reopen IDE 2.0.0. I get prompted to update the same library again. IDE 1.8.19 shows no such update & both libraries installed at the latest versions
See Library updates - Install All
Thanks for the pointer.
The was a arduino_374575 folder that contained the Adafruit DotStar library @1.1.5 as well as a Adafruit_DotStar folder containing the 1.2.1 library.
I deleted the first folder & that seems to have sorted it as IDE 2.0.0 is now reporting the correct version.
I am glad it worked. I sorted mine out by searching for the offending library names as suggested by @ptillisch and deleting duplicates, most of which were those with random names like yours
