IDE 2.0 is running but I don't see the application Window
hello to all. I experience following issue: after an error, I could not more open the Arduino IDE. It was visible in the taskbar and hoovering over it showed a small open windows but it was not more possible to open a wide window. I deinstalled and reinstalled the IDE version 2.03 and later the version 2.04 and all this also after deleteing the Arduino IDE and Arduino 15 folders. Nothing helped. I still cant acces the IDE.
Did you have a dual monitor setup and the IDE was on the second monitor?
Assuming that this is Windows
  1. Select the IDE in the taskbar.
  2. Press <alt><spaces>.
  3. Press <cursor down> once.
  4. Press <enter>.
  5. Use the cursor keys to move the application to the primary monitor.
You can practice with an application that is visible to get the feel for it.
This topic has nothing to do with avrdude, stk500 or bootloaders and therefore has been moved to a more suitable location on the forum.
I've modified your topic title to reflect the subject.
