IDE 2.03 How to automatically put a starting brace on the next line
The autoformat command puts the starting brace on the same line on a "loop", "setup", "if", "while" and so on statements. How can I make it put the starting brace on the next line. Visual Studio lets you do this, in fact, that's how it used to be.
Welcome to the forum
IDE 2.0 uses clang formatting
Try this formatting file as a starting point
# documentation on clang-format in general
# https://releases.llvm.org/14.0.0/tools/clang/docs/ClangFormatStyleOptions.html
#default Arduino 2.0 format originally from
#https://docs.arduino.cc/software/ide-v2/tutorials/ide-v2-customize-auto-formatter
Language: Cpp
# LLVM is the default style setting, used when a configuration option is not set here
BasedOnStyle: LLVM
AccessModifierOffset: -2
AlignAfterOpenBracket: Align
AlignConsecutiveAssignments: false
AlignConsecutiveBitFields: false
AlignConsecutiveDeclarations: false
AlignConsecutiveMacros: false
AlignEscapedNewlines: DontAlign
AlignOperands: Align
AlignTrailingComments: true
AllowAllArgumentsOnNextLine: true
AllowAllConstructorInitializersOnNextLine: true
AllowAllParametersOfDeclarationOnNextLine: true
AllowShortBlocksOnASingleLine: Always
AllowShortCaseLabelsOnASingleLine: true
AllowShortEnumsOnASingleLine: true
AllowShortFunctionsOnASingleLine: Empty
AllowShortIfStatementsOnASingleLine: Always
AllowShortLambdasOnASingleLine: Empty
AllowShortLoopsOnASingleLine: true
AlwaysBreakAfterDefinitionReturnType: None
AlwaysBreakAfterReturnType: None
AlwaysBreakBeforeMultilineStrings: false
AlwaysBreakTemplateDeclarations: No
BinPackArguments: true
BinPackParameters: true
# Only used when "BreakBeforeBraces" set to "Custom"
BraceWrapping:
  AfterCaseLabel: false
  AfterClass: false
  AfterControlStatement: Never
  AfterEnum: false
  AfterFunction: true
  AfterNamespace: false
  #AfterObjCDeclaration:
  AfterStruct: false
  AfterUnion: false
  AfterExternBlock: false
  BeforeCatch: false
  BeforeElse: false
  BeforeLambdaBody: false
  BeforeWhile: false
  IndentBraces: false
  SplitEmptyFunction: false
  SplitEmptyRecord: false
  SplitEmptyNamespace: false
# Java-specific
#BreakAfterJavaFieldAnnotations:
BreakBeforeBinaryOperators: NonAssignment
# bbb BreakBeforeBraces: Attach
BreakBeforeBraces: Allman
BreakBeforeTernaryOperators: true
BreakConstructorInitializers: BeforeColon
BreakInheritanceList: BeforeColon
BreakStringLiterals: false
ColumnLimit: 0
# "" matches none
CommentPragmas: ""
CompactNamespaces: false
ConstructorInitializerAllOnOneLineOrOnePerLine: true
ConstructorInitializerIndentWidth: 2
ContinuationIndentWidth: 2
Cpp11BracedListStyle: false
DeriveLineEnding: true
DerivePointerAlignment: true
DisableFormat: false
# Docs say "Do not use this in config files". The default (LLVM 11.0.1) is "false".
#ExperimentalAutoDetectBinPacking:
FixNamespaceComments: false
ForEachMacros: []
IncludeBlocks: Preserve
IncludeCategories: []
# "" matches none
IncludeIsMainRegex: ""
IncludeIsMainSourceRegex: ""
IndentCaseBlocks: true
IndentCaseLabels: true
IndentExternBlock: Indent
IndentGotoLabels: false
IndentPPDirectives: None
#bbb IndentWidth: 2
IndentWidth: 4
IndentWrappedFunctionNames: false
InsertTrailingCommas: None
# Java-specific
#JavaImportGroups:
# JavaScript-specific
#JavaScriptQuotes:
#JavaScriptWrapImports
# bbb KeepEmptyLinesAtTheStartOfBlocks: true
KeepEmptyLinesAtTheStartOfBlocks: false
MacroBlockBegin: ""
MacroBlockEnd: ""
# Set to a large number to effectively disable
# bbb MaxEmptyLinesToKeep: 10000000
NamespaceIndentation: None
NamespaceMacros: []
# Objective C-specific
#ObjCBinPackProtocolList:
#ObjCBlockIndentWidth:
#ObjCBreakBeforeNestedBlockParam:
#ObjCSpaceAfterProperty:
#ObjCSpaceBeforeProtocolList
PenaltyBreakAssignment: 1
PenaltyBreakBeforeFirstCallParameter: 1
PenaltyBreakComment: 1
PenaltyBreakFirstLessLess: 1
PenaltyBreakString: 1
PenaltyBreakTemplateDeclaration: 1
PenaltyExcessCharacter: 1
PenaltyReturnTypeOnItsOwnLine: 1
# Used as a fallback if alignment style can't be detected from code (DerivePointerAlignment: true)
PointerAlignment: Right
RawStringFormats: []
ReflowComments: false
SortIncludes: false
SortUsingDeclarations: false
SpaceAfterCStyleCast: false
SpaceAfterLogicalNot: false
SpaceAfterTemplateKeyword: false
SpaceBeforeAssignmentOperators: true
SpaceBeforeCpp11BracedList: false
SpaceBeforeCtorInitializerColon: true
SpaceBeforeInheritanceColon: true
SpaceBeforeParens: ControlStatements
SpaceBeforeRangeBasedForLoopColon: true
SpaceBeforeSquareBrackets: false
SpaceInEmptyBlock: false
SpaceInEmptyParentheses: false
SpacesBeforeTrailingComments: 2
SpacesInAngles: false
SpacesInCStyleCastParentheses: false
SpacesInConditionalStatement: false
SpacesInContainerLiterals: false
SpacesInParentheses: false
SpacesInSquareBrackets: false
Standard: Auto
StatementMacros: []
#bbb TabWidth: 2		# see IndentWidth
TabWidth: 4
TypenameMacros: []
# Default to LF if line endings can't be detected from the content (DeriveLineEnding).
UseCRLF: false
UseTab: Never
WhitespaceSensitiveMacros: []
