Hi
I have recently upgarded to IDE 2.1.0.
The issue I am facing, is that it is not automatically updating some libraries, nor they could be updated manually.
Next, the changes made in preferences are not saved. I could not add new board.
Hi
Does sound like some form of "permissions" error.
Is it your very own PERSONAL computer ?
Some of the information below may also be needed.
Please take a few moments to Learn and Use the Forum.
Hello, Welcome to the Arduino Forum. This guide explains how to get the best out of this forum. Please read and follow the instructions below. Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is frustrating for you and frustrating for us. The people who try to help with your project.
It will help you get the very best out of the forum in the future.
COMMON ISSUES
COMPUTER RELATED
ARDUINO SPECIFIC BOARDS
CREATE editor install locations.
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
Please provide the details. E.g. which operating system? What did you install (zip, ...)? If applicable, where did you install the IDE?
I'm quite sure that you would have gotten an error message. Post it here.
My OS is Windows 10, 64 bit
Yes, it is my own personal Laptop.
No error message. I just add the URL for the ATTiny boards and click OK.
When I open the Preferences again, the URL is not there.
Hi @abuhafss. I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
C:\Program Files\Arduino IDE
C:\Users\<username>\AppData\Local\Programs\Arduino IDE
(where <username>
is your Windows username)& ".\Arduino IDE"
<CODE/>
icon on the post composer toolbar.```
) to your reply to make sure the error messages are correctly formatted.Please let me know if you have any questions or problems while following those instructions.
PS C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
sing browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Abu-Hafss/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-06-01T20:32:40.900Z root INFO Backend Object.initialize: 39.8 ms [Finished 17.892 s after backend start]
2023-06-01T20:32:40.903Z root INFO Backend Object.configure: 31.3 ms [Finished 17.893 s after backend start]
2023-06-01T20:32:40.905Z root INFO Backend MessagingContribution.onStart: 16.4 ms [Finished 17.893 s after backend start]
2023-06-01T20:32:40.909Z root INFO Backend OSBackendApplicationContribution.configure: 2.8 ms [Finished 18.264 s after backend start]
2023-06-01T20:32:40.915Z root INFO Backend DefaultWorkspaceServer.onStart: 2.5 ms [Finished 18.265 s after backend start]
2023-06-01T20:32:40.924Z root INFO Backend PluginLocalizationBackendContribution.configure: 1.2 ms [Finished 18.266 s after backend start]
2023-06-01T20:32:40.931Z root WARN Backend PluginLocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 373.3 ms [Finished 18.268 s after backend start]
2023-06-01T20:32:40.933Z root INFO Backend TaskBackendApplicationContribution.onStart: 2.1 ms [Finished 18.268 s after backend start]
2023-06-01T20:32:40.944Z root INFO Backend ElectronTokenBackendContribution.configure: 8.1 ms [Finished 18.278 s after backend start]
2023-06-01T20:32:40.947Z config INFO >>> Initializing CLI configuration...
2023-06-01T20:32:40.952Z root INFO Backend PluginDeployerContribution.initialize: 2.9 ms [Finished 18.279 s after backend start]
2023-06-01T20:32:40.955Z root INFO Backend ConfigServiceImpl.onStart: 6.5 ms [Finished 18.284 s after backend start]
2023-06-01T20:32:40.962Z config INFO Loading CLI configuration from c:\Users\Abu-Hafss\.arduinoIDE\arduino-cli.yaml...
2023-06-01T20:32:40.970Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 2.0 ms [Finished 18.294 s after backend start]
2023-06-01T20:32:40.971Z root INFO Backend ArduinoDaemonImpl.onStart: 8.1 ms [Finished 18.301 s after backend start]
2023-06-01T20:32:40.971Z root INFO Backend NodeFileUploadService.configure: 19.0 ms [Finished 18.304 s after backend start]
2023-06-01T20:32:40.972Z daemon INFO Starting daemon from C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-06-01T20:32:40.974Z discovery-log INFO start
2023-06-01T20:32:40.978Z discovery-log INFO start new deferred
2023-06-01T20:32:40.978Z root INFO Backend HostedPluginLocalizationService.initialize: 4.8 ms [Finished 18.314 s after backend start]
2023-06-01T20:32:40.979Z root INFO Backend BoardDiscovery.onStart: 11.9 ms [Finished 18.322 s after backend start]
2023-06-01T20:32:40.980Z root INFO Backend FileDownloadEndpoint.configure: 9.5 ms [Finished 18.325 s after backend start]
2023-06-01T20:32:40.981Z root INFO Backend AuthenticationServiceImpl.onStart: 6.1 ms [Finished 18.340 s after backend start]
2023-06-01T20:32:40.981Z root INFO Backend PluginApiContribution.configure: 6.8 ms [Finished 18.341 s after backend start]
2023-06-01T20:32:41.002Z root INFO Backend HostedPluginReader.configure: 5.5 ms [Finished 18.349 s after backend start]
2023-06-01T20:32:41.004Z root INFO Backend HostedPluginReader.configure: 0.3 ms [Finished 18.351 s after backend start]
2023-06-01T20:32:41.005Z root INFO Backend PlotterBackendContribution.configure: 13.8 ms [Finished 18.372 s after backend start]
2023-06-01T20:32:41.030Z root INFO Theia app listening on http://localhost:53987.
2023-06-01T20:32:41.037Z root INFO Finished starting backend application: 57.4 ms [Finished 18.400 s after backend start]
2023-06-01T20:32:41.081Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Abu-Hafss/.arduinoIDE/plugins does not exist.
2023-06-01T20:32:41.125Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Abu-Hafss/.arduinoIDE/extensions does not exist.
2023-06-01T20:32:41.132Z root WARN The local plugin referenced by local-dir:C:\Users\Abu-Hafss\.arduinoIDE\plugins does not exist.
Restoring workspace roots: h:\Users\Abu-Hafss\Electronics\Arduino\Codes\Counter_with_ATTiny
isTempSketch: false. Input was h:\Users\Abu-Hafss\Electronics\Arduino\Codes\Counter_with_ATTiny\Counter_with_ATTiny.ino
2023-06-01T20:32:41.473Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:41.553Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-06-01T20:32:41.569Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:41.607Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.8" with engines:
2023-06-01T20:32:41.620Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:41.624Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-06-01T20:32:41.636Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:41.642Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-06-01T20:32:41.692Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:41.755Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-06-01T20:32:41.829Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:41.866Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-06-01T20:32:41.873Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:41.874Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-06-01T20:32:41.892Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:41.906Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-06-01T20:32:41.909Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:41.922Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-06-01T20:32:41.928Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:41.941Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-06-01T20:32:41.942Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:41.947Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-06-01T20:32:41.956Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:41.958Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-06-01T20:32:41.964Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:41.971Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-06-01T20:32:41.973Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:41.975Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-06-01T20:32:41.980Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:41.993Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-06-01T20:32:41.997Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:42.004Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-06-01T20:32:42.007Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:42.019Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-06-01T20:32:42.024Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:42.024Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-06-01T20:32:42.035Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:42.039Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-06-01T20:32:42.042Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:42.060Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-06-01T20:32:42.061Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-01T20:32:42.069Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-06-01T20:32:42.111Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\staging","user":"H:\\Users\\Abu-Hafss\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-06-01T20:32:42.122Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-06-01T20:32:42.130Z config INFO Loaded the CLI configuration.
2023-06-01T20:32:50.120Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Abu-Hafss/AppData/Local/Arduino15","sketchDirUri":"file:///h%3A/Users/Abu-Hafss/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-06-01T20:32:50.123Z config INFO Validating the CLI configuration...
2023-06-01T20:32:50.153Z config INFO The CLI config is valid.
2023-06-01T20:32:50.155Z config INFO <<< Initialized the CLI configuration.
2023-06-01T20:32:50.349Z root INFO Resolve plugins list: 9389.3 ms [Finished 27.716 s after backend start]
2023-06-01T20:32:50.437Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 87.5 ms [Finished 27.806 s after backend start]
2023-06-01T20:32:50.470Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.8" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 33.2 ms [Finished 27.840 s after backend start]
2023-06-01T20:32:50.577Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 102.9 ms [Finished 27.943 s after backend start]
2023-06-01T20:32:50.611Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 36.8 ms [Finished 27.980 s after backend start]
2023-06-01T20:32:50.618Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 6.8 ms [Finished 27.987 s after backend start]
2023-06-01T20:32:51.660Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 1042.1 ms [Finished 29.030 s after backend start]
2023-06-01T20:32:53.164Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 1502.7 ms [Finished 30.533 s after backend start]
2023-06-01T20:32:54.540Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 1373.8 ms [Finished 31.907 s after backend start]
2023-06-01T20:32:54.548Z daemon INFO INFO[0000] Using config file: c:\Users\Abu-Hafss\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.32.2
INFO[0000] Executing `arduino-cli daemon`
2023-06-01T20:33:01.762Z daemon INFO Daemon is now listening on 127.0.0.1:53991
{"IP":"127.0.0.1","Port":"53991"}
2023-06-01T20:33:01.792Z daemon INFO Daemon is running.
2023-06-01T20:33:02.798Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 8255.3 ms [Finished 40.165 s after backend start]
2023-06-01T20:33:03.625Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 829.2 ms [Finished 40.994 s after backend start]
2023-06-01T20:33:03.678Z daemon INFO INFO[0009] Loading hardware from: C:\Users\Abu-Hafss\AppData\Local\Arduino15\packages
2023-06-01T20:33:04.211Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 585.5 ms [Finished 41.580 s after backend start]
2023-06-01T20:33:04.218Z daemon INFO INFO[0009] Loading package arduino from: C:\Users\Abu-Hafss\AppData\Local\Arduino15\packages\arduino\hardware
INFO[0009] Checking signature error="opening signature file: open C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
INFO[0009] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0009] Loaded platform platform="arduino:avr@1.8.6"
INFO[0009] Checking existence of 'tools' path: C:\Users\Abu-Hafss\AppData\Local\Arduino15\packages\arduino\tools
INFO[0009] Loading tools from dir: C:\Users\Abu-Hafss\AppData\Local\Arduino15\packages\arduino\tools
INFO[0009] Loaded tool tool="arduino:arduinoOTA@1.3.0"
INFO[0009] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0009] Loaded tool tool="arduino:avrdude@6.3.0-arduino17"
INFO[0009] Loading package builtin from: C:\Users\Abu-Hafss\AppData\Local\Arduino15\packages\builtin
INFO[0009] Checking existence of 'tools' path: C:\Users\Abu-Hafss\AppData\Local\Arduino15\packages\builtin\tools
INFO[0009] Loading tools from dir: C:\Users\Abu-Hafss\AppData\Local\Arduino15\packages\builtin\tools
INFO[0009] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0009] Loaded tool tool="builtin:mdns-discovery@1.0.9"
INFO[0009] Loaded tool tool="builtin:serial-discovery@1.4.0"
INFO[0009] Loaded tool tool="builtin:serial-monitor@0.13.0"
INFO[0009] Checking signature index="C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0009] Adding libraries dir dir="C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
INFO[0009] Loading libraries index file index="C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\library_index.json"
2023-06-01T20:33:04.980Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 767.9 ms [Finished 42.348 s after backend start]
2023-06-01T20:33:06.074Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 1093.9 ms [Finished 43.444 s after backend start]
2023-06-01T20:33:07.063Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 984.4 ms [Finished 44.428 s after backend start]
2023-06-01T20:33:07.083Z daemon INFO INFO[0012] Adding libraries dir dir="C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0012] Adding libraries dir dir="H:\\Users\\Abu-Hafss\\Arduino\\libraries" location=user
2023-06-01T20:33:07.455Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 395.5 ms [Finished 44.824 s after backend start]
2023-06-01T20:33:08.244Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 789.3 ms [Finished 45.614 s after backend start]
2023-06-01T20:33:09.003Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 758.0 ms [Finished 46.372 s after backend start]
2023-06-01T20:33:09.873Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 869.9 ms [Finished 47.242 s after backend start]
2023-06-01T20:33:10.768Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 895.6 ms [Finished 48.138 s after backend start]
2023-06-01T20:33:11.227Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 458.2 ms [Finished 48.596 s after backend start]
2023-06-01T20:33:12.035Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 729.2 ms [Finished 49.326 s after backend start]
2023-06-01T20:33:12.037Z root INFO Deploy plugins list: 9389.3 ms [Finished 49.405 s after backend start]
2023-06-01T20:33:13.827Z discovery-log INFO start request start watch
2023-06-01T20:33:13.830Z discovery-log INFO start requested start watch
2023-06-01T20:33:13.834Z discovery-log INFO start resolved watching
2023-06-01T20:33:13.847Z daemon INFO INFO[0019] starting discovery builtin:mdns-discovery process
2023-06-01T20:33:13.852Z daemon INFO INFO[0019] starting discovery builtin:serial-discovery process
2023-06-01T20:33:14.408Z daemon INFO INFO[0020] started discovery builtin:serial-discovery process
2023-06-01T20:33:14.411Z daemon INFO INFO[0020] sending command HELLO 1 "arduino-cli 0.32.2" to discovery builtin:serial-discovery
2023-06-01T20:33:14.483Z daemon INFO INFO[0020] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
2023-06-01T20:33:14.490Z daemon INFO INFO[0020] sending command START_SYNC to discovery builtin:serial-discovery
2023-06-01T20:33:14.510Z daemon INFO INFO[0020] from discovery builtin:serial-discovery received message type: start_sync, message: OK
2023-06-01T20:33:14.575Z daemon INFO INFO[0020] started discovery builtin:mdns-discovery process
INFO[0020] sending command HELLO 1 "arduino-cli 0.32.2" to discovery builtin:mdns-discovery
2023-06-01T20:33:14.654Z daemon INFO INFO[0020] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
2023-06-01T20:33:14.656Z daemon INFO INFO[0020] sending command START_SYNC to discovery builtin:mdns-discovery
2023-06-01T20:33:14.662Z daemon INFO INFO[0020] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-06-01T20:33:25.570Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 7209.3 ms [Finished 43.980 s after frontend start]
2023-06-01T20:33:25.633Z root WARN Frontend commands.onStart took longer than the expected maximum 100 milliseconds: 174.3 ms [Finished 44.157 s after frontend start]
2023-06-01T20:33:25.948Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 317.8 ms [Finished 44.477 s after frontend start]
2023-06-01T20:33:26.196Z root WARN Frontend h.onStart took longer than the expected maximum 100 milliseconds: 121.7 ms [Finished 44.659 s after frontend start]
2023-06-01T20:33:26.220Z root WARN Frontend h.onStart took longer than the expected maximum 100 milliseconds: 110.6 ms [Finished 44.770 s after frontend start]
2023-06-01T20:33:26.420Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <h:\Users\Abu-Hafss\Electronics\Arduino\Codes\Counter_with_ATTiny\Counter_with_ATTiny.ino>, response: <h:\Users\Abu-Hafss\Electronics\Arduino\Codes\Counter_with_ATTiny>.
2023-06-01T20:33:26.678Z root ERROR Uncaught Exception:
2023-06-01T20:33:26.679Z root ERROR Error: EPERM: operation not permitted, open 'c:\Users\Abu-Hafss\.arduinoIDE\recentworkspace.json'
2023-06-01T20:33:26.847Z root WARN Frontend c.onStart took longer than the expected maximum 100 milliseconds: 520.2 ms [Finished 45.432 s after frontend start]
2023-06-01T20:33:33.019Z root INFO Start frontend contributions: 9403.1 ms [Finished 45.529 s after frontend start]
2023-06-01T20:33:33.022Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-06-01T20:33:33.287Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a] Waiting for backend deployment: 6182.9 ms [Finished 51.633 s after frontend start]
2023-06-01T20:33:37.115Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932) starting instance
2023-06-01T20:33:40.364Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a] Sync of 21 plugins: 7314.8 ms [Finished 58.951 s after frontend start]
2023-06-01T20:33:55.480Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-06-01T20:33:55.488Z root INFO >>> Restoring the layout state...
2023-06-01T20:33:55.502Z root INFO ------- SERIALIZED LAYOUT DATA -------
2023-06-01T20:33:55.508Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///h%3A/Users/Abu-Hafss/Electronics/Arduino/Codes/Counter_with_ATTiny/Counter_with_ATTiny.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":83,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":0}},"pinned":[false],"size":238,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":true,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":268},"rightPanel":{"type":"sidepanel","items":[]}}
2023-06-01T20:33:55.513Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2023-06-01T20:33:59.459Z root INFO <<< The layout has been successfully restored.
2023-06-01T20:34:00.403Z root INFO Initialize the workbench layout: 4073.9 ms [Finished 78.049 s after frontend start]
2023-06-01T20:34:00.424Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-06-01T20:34:00.444Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][marus25.cortex-debug]: Loaded contributions.
2023-06-01T20:34:00.449Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][arduino.vscode-arduino-tools]: Loaded contributions.
2023-06-01T20:34:00.457Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][vscode.cpp]: Loaded contributions.
2023-06-01T20:34:00.472Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][vscode.json]: Loaded contributions.
2023-06-01T20:34:00.473Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][vscode.json-language-features]: Loaded contributions.
2023-06-01T20:34:00.475Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-bg]: Loaded contributions.
2023-06-01T20:34:00.483Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
2023-06-01T20:34:00.490Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
2023-06-01T20:34:00.492Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
2023-06-01T20:34:00.500Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
2023-06-01T20:34:00.502Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-hu]: Loaded contributions.
2023-06-01T20:34:00.508Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
2023-06-01T20:34:00.516Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
2023-06-01T20:34:00.519Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-ko]: Loaded contributions.
2023-06-01T20:34:00.559Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
2023-06-01T20:34:00.586Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-pl]: Loaded contributions.
2023-06-01T20:34:00.609Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
2023-06-01T20:34:00.624Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
2023-06-01T20:34:00.633Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
2023-06-01T20:34:00.636Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-uk]: Loaded contributions.
2023-06-01T20:34:00.655Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
2023-06-01T20:34:00.675Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a] Load contributions of 21 plugins: 917.3 ms [Finished 78.978 s after frontend start]
2023-06-01T20:34:01.132Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-06-01T20:34:01.154Z root WARN a registered grammar configuration for 'cpp' language is overridden
2023-06-01T20:34:01.956Z root ERROR Request markAsRecentlyOpened failed with error: EPERM: operation not permitted, open 'c:\Users\Abu-Hafss\.arduinoIDE\recent-sketches.json'
2023-06-01T20:34:07.214Z root INFO Frontend application start: 41864.9 ms [Finished 104.553 s after backend start]
2023-06-01T20:34:07.316Z root INFO Replace loading indicator with ready workbench UI (animation): 1521.3 ms [Finished 80.512 s after frontend start]
2023-06-01T20:34:07.451Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-06-01T20:34:07.501Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
Checking for update
Update for version 2.1.0 is not available (latest version: 2.1.0, downgrade is allowed).
2023-06-01T20:34:13.448Z daemon INFO INFO[0079] Required tool tool="arduino:arduinoOTA@1.3.0"
2023-06-01T20:34:13.452Z daemon INFO INFO[0079] Required tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0079] Required tool tool="arduino:avrdude@6.3.0-arduino17"
2023-06-01T20:34:13.776Z daemon INFO INFO[0079] Required tool tool="arduino:arduinoOTA@1.3.0"
2023-06-01T20:34:13.839Z daemon INFO INFO[0079] Required tool tool="arduino:arduinoOTA@1.3.0"
2023-06-01T20:34:13.855Z daemon INFO INFO[0079] Required tool tool="arduino:avrdude@6.3.0-arduino17"
2023-06-01T20:34:14.795Z fwuploader ERROR Error: Error executing "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-fwuploader.exe" firmware list --format json: saving downloaded index https://downloads.arduino.cc/arduino-fwuploader/boards/module_firmware_index.json.gz: open C:\Users\Abu-Hafss\AppData\Local\Temp\fwuploader\module_firmware_index.json: Access is denied.
at ChildProcess.<anonymous> (C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\exec-util.js:53:31)
at ChildProcess.emit (node:events:394:28)
at Process.ChildProcess._handle.onexit (node:internal/child_process:290:12)
2023-06-01T20:34:14.807Z root ERROR Request updatableBoards failed with error: Error executing "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-fwuploader.exe" firmware list --format json: saving downloaded index https://downloads.arduino.cc/arduino-fwuploader/boards/module_firmware_index.json.gz: open C:\Users\Abu-Hafss\AppData\Local\Temp\fwuploader\module_firmware_index.json: Access is denied.
2023-06-01T20:34:17.703Z root ERROR ---- !!!SLOW!!! DURATION: search took 4842.037 ms. Args: [{"type":"Updatable"}] ----
2023-06-01T20:34:17.747Z fwuploader ERROR Error: Error executing "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-fwuploader.exe" firmware list --format json: saving downloaded index https://downloads.arduino.cc/arduino-fwuploader/boards/module_firmware_index.json.gz: open C:\Users\Abu-Hafss\AppData\Local\Temp\fwuploader\module_firmware_index.json: Access is denied.
2023-06-01T20:34:17.748Z root ERROR Request updatableBoards failed with error: Error executing "C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-fwuploader.exe" firmware list --format json: saving downloaded index https://downloads.arduino.cc/arduino-fwuploader/boards/module_firmware_index.json.gz: open C:\Users\Abu-Hafss\AppData\Local\Temp\fwuploader\module_firmware_index.json: Access is denied.
2023-06-01T20:34:17.767Z daemon INFO INFO[0083] Updating libraries index
2023-06-01T20:34:17.773Z daemon INFO INFO[0083] Updating index url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-06-01T20:34:17.784Z daemon INFO INFO[0083] Starting download url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-06-01T20:34:17.798Z root INFO core-client-provider [platform-index]
2023-06-01T20:34:17.830Z root INFO core-client-provider [library-index]
2023-06-01T20:34:17.835Z daemon INFO INFO[0083] Starting download url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2023-06-01T20:34:18.918Z daemon INFO INFO[0084] Loading hardware from: C:\Users\Abu-Hafss\AppData\Local\Arduino15\packages
2023-06-01T20:34:18.924Z daemon INFO INFO[0084] Loading package arduino from: C:\Users\Abu-Hafss\AppData\Local\Arduino15\packages\arduino\hardware
2023-06-01T20:34:18.996Z daemon INFO INFO[0084] Checking signature error="opening signature file: open C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
2023-06-01T20:34:19.013Z daemon INFO INFO[0084] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
2023-06-01T20:34:19.015Z daemon INFO INFO[0084] Loaded platform platform="arduino:avr@1.8.6"
INFO[0084] Checking existence of 'tools' path: C:\Users\Abu-Hafss\AppData\Local\Arduino15\packages\arduino\tools
INFO[0084] Loading tools from dir: C:\Users\Abu-Hafss\AppData\Local\Arduino15\packages\arduino\tools
2023-06-01T20:34:19.022Z daemon INFO INFO[0084] Loaded tool tool="arduino:arduinoOTA@1.3.0"
INFO[0084] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2023-06-01T20:34:19.025Z daemon INFO INFO[0084] Loaded tool tool="arduino:avrdude@6.3.0-arduino17"
2023-06-01T20:34:19.036Z daemon INFO INFO[0084] Loading package builtin from: C:\Users\Abu-Hafss\AppData\Local\Arduino15\packages\builtin
2023-06-01T20:34:19.043Z daemon INFO INFO[0084] Checking existence of 'tools' path: C:\Users\Abu-Hafss\AppData\Local\Arduino15\packages\builtin\tools
INFO[0084] Loading tools from dir: C:\Users\Abu-Hafss\AppData\Local\Arduino15\packages\builtin\tools
2023-06-01T20:34:19.049Z daemon INFO INFO[0084] Loaded tool tool="builtin:ctags@5.8-arduino11"
2023-06-01T20:34:19.051Z daemon INFO INFO[0084] Loaded tool tool="builtin:mdns-discovery@1.0.9"
2023-06-01T20:34:19.054Z daemon INFO INFO[0084] Loaded tool tool="builtin:serial-discovery@1.4.0"
2023-06-01T20:34:19.056Z daemon INFO INFO[0084] Loaded tool tool="builtin:serial-monitor@0.13.0"
2023-06-01T20:34:19.190Z daemon INFO INFO[0084] Checking signature index="C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2023-06-01T20:34:19.201Z daemon INFO INFO[0084] sending command QUIT to discovery builtin:serial-discovery
2023-06-01T20:34:19.206Z daemon INFO INFO[0084] from discovery builtin:serial-discovery received message type: quit, message: OK
INFO[0084] killing discovery builtin:serial-discovery process
INFO[0084] Discovery event channel closed builtin:serial-discovery. Exiting goroutine.
2023-06-01T20:34:19.232Z daemon INFO INFO[0084] Closed and removed discovery builtin:serial-discovery
2023-06-01T20:34:19.234Z daemon INFO INFO[0084] sending command QUIT to discovery builtin:mdns-discovery
INFO[0084] from discovery builtin:mdns-discovery received message type: quit, message: OK
INFO[0084] killing discovery builtin:mdns-discovery process
2023-06-01T20:34:19.241Z daemon INFO INFO[0084] Closed and removed discovery builtin:mdns-discovery
INFO[0084] starting discovery builtin:serial-discovery process
2023-06-01T20:34:19.248Z daemon INFO INFO[0084] Discovery event channel closed builtin:mdns-discovery. Exiting goroutine.
2023-06-01T20:34:19.680Z daemon INFO INFO[0085] started discovery builtin:serial-discovery process
INFO[0085] sending command HELLO 1 "arduino-cli 0.32.2" to discovery builtin:serial-discovery
2023-06-01T20:34:19.756Z daemon INFO INFO[0085] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
2023-06-01T20:34:19.759Z daemon INFO INFO[0085] sending command START_SYNC to discovery builtin:serial-discovery
INFO[0085] from discovery builtin:serial-discovery received message type: start_sync, message: OK
2023-06-01T20:34:19.782Z daemon INFO INFO[0085] starting discovery builtin:mdns-discovery process
2023-06-01T20:34:20.656Z daemon INFO INFO[0086] started discovery builtin:mdns-discovery process
INFO[0086] sending command HELLO 1 "arduino-cli 0.32.2" to discovery builtin:mdns-discovery
2023-06-01T20:34:20.722Z daemon INFO INFO[0086] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
2023-06-01T20:34:20.724Z daemon INFO INFO[0086] sending command START_SYNC to discovery builtin:mdns-discovery
2023-06-01T20:34:20.746Z daemon INFO INFO[0086] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
2023-06-01T20:34:20.780Z daemon INFO INFO[0086] Adding libraries dir dir="C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
2023-06-01T20:34:20.789Z daemon INFO INFO[0086] Loading libraries index file index="C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\library_index.json"
2023-06-01T20:34:21.104Z root WARN A command arduino-include-library--DS1307RTC:Michael Margolis is already registered.
2023-06-01T20:34:21.124Z daemon INFO INFO[0086] Required tool tool="arduino:arduinoOTA@1.3.0"
2023-06-01T20:34:21.131Z daemon INFO INFO[0086] Required tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0086] Required tool tool="arduino:avrdude@6.3.0-arduino17"
2023-06-01T20:34:21.150Z root WARN A command arduino-include-library--Time:Michael Margolis is already registered.
2023-06-01T20:34:22.341Z daemon INFO INFO[0087] Adding libraries dir dir="C:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15\\libraries" location=ide
2023-06-01T20:34:22.352Z daemon INFO INFO[0087] Adding libraries dir dir="H:\\Users\\Abu-Hafss\\Arduino\\libraries" location=user
2023-06-01T20:34:31.295Z root ERROR Failed to update platform, library indexes.
2023-06-01T20:34:34.896Z daemon INFO INFO[0100] Required tool tool="arduino:arduinoOTA@1.3.0"
INFO[0100] Required tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2023-06-01T20:34:34.911Z daemon INFO INFO[0100] Required tool tool="arduino:avrdude@6.3.0-arduino17"
[10788:0602/013435.061:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is
2023-06-01T20:34:35.165Z root ERROR Error: Could not find menu with menu-path: ["menubar","1_file","0_sketch","2_examples","3_user_libs","SevSeg"].
at t.unregisterSubmenu (file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:8210643)
at Object.<anonymous> (file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:8020254)
at Object.e.dispose (file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:2273444)
at t.DisposableCollection.dispose (file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:2273161)
at file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:8022869
at o (file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:9484197)
at e.exports._next (file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:9483983)
at file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:9484222
2023-06-01T20:34:35.181Z root ERROR Error: Could not find menu with menu-path: ["menubar","1_file","0_sketch","2_examples","3_user_libs","Time","Processing"].
2023-06-01T20:34:35.201Z root ERROR Error: Could not find menu with menu-path: ["menubar","1_file","0_sketch","2_examples","3_user_libs","DS1307RTC"].
2023-06-01T20:34:39.678Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): PluginManagerExtImpl/init()
2023-06-01T20:34:39.697Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(cortex-debug@1.5.1 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.750Z root INFO [hosted-plugin: 9932] Debugger contribution has been registered: cortex-debug
2023-06-01T20:34:39.764Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(vscode-arduino-tools@0.0.2-beta.8 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.770Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(cpp@1.52.1 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.778Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(json@1.46.1 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.784Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(json-language-features@1.46.1 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.789Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.796Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(vscode-language-pack-cs@1.53.2 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.802Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(vscode-language-pack-de@1.53.2 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.807Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(vscode-language-pack-es@1.53.2 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.817Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(vscode-language-pack-fr@1.53.2 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.827Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.834Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(vscode-language-pack-it@1.53.2 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.839Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(vscode-language-pack-ja@1.53.2 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.846Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(vscode-language-pack-ko@1.53.2 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.849Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.854Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(vscode-language-pack-pl@1.53.2 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.857Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(vscode-language-pack-pt-BR@1.53.2 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.868Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(vscode-language-pack-ru@1.53.2 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.876Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(vscode-language-pack-tr@1.53.2 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(9932): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.880Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): initializing(vscode-language-pack-zh-hans@1.53.2 with C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-06-01T20:34:39.894Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): PluginManagerExtImpl/loadPlugin(C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2023-06-01T20:34:48.370Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): PluginManagerExtImpl/loadPlugin(C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
2023-06-01T20:34:48.586Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][marus25.cortex-debug]: Started plugin.
2023-06-01T20:34:48.611Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][arduino.vscode-arduino-tools]: Started plugin.
2023-06-01T20:34:48.612Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][vscode.cpp]: Started plugin.
2023-06-01T20:34:48.614Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][vscode.json]: Started plugin.
2023-06-01T20:34:48.617Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][vscode.json-language-features]: Started plugin.
2023-06-01T20:34:48.622Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-bg]: Started plugin.
2023-06-01T20:34:48.625Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-cs]: Started plugin.
2023-06-01T20:34:48.627Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-de]: Started plugin.
2023-06-01T20:34:48.636Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-es]: Started plugin.
2023-06-01T20:34:48.642Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-fr]: Started plugin.
2023-06-01T20:34:48.644Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-hu]: Started plugin.
2023-06-01T20:34:48.646Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-it]: Started plugin.
2023-06-01T20:34:48.649Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-ja]: Started plugin.
2023-06-01T20:34:48.651Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-ko]: Started plugin.
2023-06-01T20:34:48.656Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-nl]: Started plugin.
2023-06-01T20:34:48.658Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-pl]: Started plugin.
2023-06-01T20:34:48.660Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
2023-06-01T20:34:48.663Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-ru]: Started plugin.
2023-06-01T20:34:48.665Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-tr]: Started plugin.
2023-06-01T20:34:48.679Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-uk]: Started plugin.
2023-06-01T20:34:48.682Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
2023-06-01T20:34:48.716Z root INFO [hosted-plugin: 9932] PLUGIN_HOST(9932): PluginManagerExtImpl/loadPlugin(C:\Users\Abu-Hafss\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2023-06-01T20:34:49.117Z root INFO [hosted-plugin: 9932] Debug configuration provider has been registered: cortex-debug, trigger: 1
2023-06-01T20:34:49.158Z root INFO [hosted-plugin: 9932] GDB server console created
2023-06-01T20:34:49.286Z root INFO [8c53073b-ef0a-469f-bced-2c7d94d9951a] Start of 21 plugins: 48782.8 ms [Finished 127.861 s after frontend start]
2023-06-01T20:34:49.379Z daemon INFO INFO[0115] Required tool tool="arduino:arduinoOTA@1.3.0"
INFO[0115] Required tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2023-06-01T20:34:49.423Z daemon INFO INFO[0115] Required tool tool="arduino:avrdude@6.3.0-arduino17"
2023-06-01T20:34:49.514Z daemon INFO INFO[0115] Required tool tool="arduino:arduinoOTA@1.3.0"
2023-06-01T20:34:49.520Z daemon INFO INFO[0115] Required tool tool="arduino:avrdude@6.3.0-arduino17"
2023-06-01T20:34:49.557Z root INFO Starting language server: arduino:avr:nano:cpu=atmega328old
2023-06-01T20:34:53.148Z daemon INFO INFO[0118] Required tool tool="arduino:arduinoOTA@1.3.0"
INFO[0118] Required tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2023-06-01T20:34:53.150Z daemon INFO INFO[0118] Required tool tool="arduino:avrdude@6.3.0-arduino17"
2023-06-01T20:34:53.204Z daemon INFO INFO[0118] Required tool tool="arduino:arduinoOTA@1.3.0"
2023-06-01T20:34:53.206Z daemon INFO INFO[0118] Required tool tool="arduino:avrdude@6.3.0-arduino17"
2023-06-01T20:34:59.191Z root INFO >>> Starting library package installation...
2023-06-01T20:34:59.193Z discovery-log INFO stop
2023-06-01T20:34:59.201Z discovery-log INFO >>> Stopping boards watcher...
2023-06-01T20:34:59.203Z discovery-log INFO Canceling boards watcher...
2023-06-01T20:34:59.205Z discovery-log INFO disposing requesting cancel
2023-06-01T20:34:59.207Z discovery-log INFO disposing canceled
2023-06-01T20:34:59.220Z discovery-log INFO error received
2023-06-01T20:34:59.221Z discovery-log INFO cancel error received!
2023-06-01T20:34:59.223Z discovery-log INFO stop received event: either end or cancel
2023-06-01T20:34:59.236Z discovery-log INFO stop stopped
2023-06-01T20:34:59.242Z discovery-log INFO received end
2023-06-01T20:34:59.253Z daemon INFO INFO[0124] boards watcher stream closed
2023-06-01T20:35:04.381Z discovery-log INFO start
2023-06-01T20:35:04.382Z discovery-log INFO start new deferred
2023-06-01T20:35:04.387Z root ERROR Request install failed with error: 3 INVALID_ARGUMENT: The library DS1307RTC has multiple installations:
- H:\Users\Abu-Hafss\Arduino\libraries\DS1307RTC
- H:\Users\Abu-Hafss\Arduino\libraries\DS1307RTC-master
Automatic library install can't be performed in this case, please manually remove all duplicates and retry.
2023-06-01T20:35:04.394Z discovery-log INFO start request start watch
2023-06-01T20:35:04.398Z discovery-log INFO start requested start watch
2023-06-01T20:35:04.399Z discovery-log INFO start resolved watching
2023-06-01T20:35:04.606Z root INFO >>> Starting library package installation...
2023-06-01T20:35:04.608Z discovery-log INFO stop
2023-06-01T20:35:04.613Z discovery-log INFO >>> Stopping boards watcher...
2023-06-01T20:35:04.620Z discovery-log INFO Canceling boards watcher...
2023-06-01T20:35:04.623Z discovery-log INFO disposing requesting cancel
2023-06-01T20:35:04.625Z discovery-log INFO disposing canceled
2023-06-01T20:35:04.630Z discovery-log INFO error received
2023-06-01T20:35:04.635Z discovery-log INFO cancel error received!
2023-06-01T20:35:04.641Z discovery-log INFO stop received event: either end or cancel
2023-06-01T20:35:04.643Z discovery-log INFO stop stopped
2023-06-01T20:35:04.649Z discovery-log INFO received end
2023-06-01T20:35:04.660Z root ERROR Error: 3 INVALID_ARGUMENT: The library DS1307RTC has multiple installations:
at y.<computed> (file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:10597215)
at B (file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:10591814)
at Array.n [as read] (file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:10592970)
at J (file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:10597125)
at B (file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:10591731)
at I (file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:10589546)
at Te.unpack (file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:10588636)
at Te.decode (file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:10589334)
at t.MsgPackMessageDecoder.decode (file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:2329095)
at t.MsgPackMessageDecoder.parse (file:///C:/Users/Abu-Hafss/AppData/Local/Programs/Arduino%20IDE/resources/app/lib/bundle.js:2:2329126)
2023-06-01T20:35:04.665Z daemon INFO INFO[0130] boards watcher stream closed
2023-06-01T20:35:09.432Z discovery-log INFO start
2023-06-01T20:35:09.433Z discovery-log INFO start new deferred
2023-06-01T20:35:09.442Z root ERROR Request install failed with error: 3 INVALID_ARGUMENT: The library SevSeg has multiple installations:
- H:\Users\Abu-Hafss\Arduino\libraries\SevSeg
- H:\Users\Abu-Hafss\Arduino\libraries\SevSeg-master
2023-06-01T20:35:09.443Z discovery-log INFO start request start watch
2023-06-01T20:35:09.447Z discovery-log INFO start requested start watch
2023-06-01T20:35:09.448Z discovery-log INFO start resolved watching
2023-06-01T20:35:09.561Z root INFO >>> Starting library package installation...
2023-06-01T20:35:09.563Z discovery-log INFO stop
2023-06-01T20:35:09.575Z discovery-log INFO >>> Stopping boards watcher...
2023-06-01T20:35:09.577Z discovery-log INFO Canceling boards watcher...
2023-06-01T20:35:09.579Z discovery-log INFO disposing requesting cancel
2023-06-01T20:35:09.581Z discovery-log INFO disposing canceled
2023-06-01T20:35:09.593Z discovery-log INFO error received
2023-06-01T20:35:09.593Z discovery-log INFO cancel error received!
2023-06-01T20:35:09.596Z discovery-log INFO stop received event: either end or cancel
2023-06-01T20:35:09.603Z discovery-log INFO stop stopped
2023-06-01T20:35:09.607Z discovery-log INFO received end
2023-06-01T20:35:09.613Z root ERROR Error: 3 INVALID_ARGUMENT: The library SevSeg has multiple installations:
2023-06-01T20:35:09.620Z daemon INFO INFO[0135] boards watcher stream closed
2023-06-01T20:35:13.865Z discovery-log INFO start
2023-06-01T20:35:13.866Z discovery-log INFO start new deferred
2023-06-01T20:35:13.870Z root ERROR Request install failed with error: 3 INVALID_ARGUMENT: The library Time has multiple installations:
- H:\Users\Abu-Hafss\Arduino\libraries\Time
- H:\Users\Abu-Hafss\Arduino\libraries\Time-master
2023-06-01T20:35:13.877Z discovery-log INFO start request start watch
2023-06-01T20:35:13.882Z discovery-log INFO start requested start watch
2023-06-01T20:35:13.883Z discovery-log INFO start resolved watching
2023-06-01T20:35:13.977Z root ERROR Error: 3 INVALID_ARGUMENT: The library Time has multiple installations:
2023-06-01T20:35:49.861Z config INFO Updating daemon with 'data': {
"board_manager": {
"additional_urls": [
"https://raw.githubusercontent.com/damellis/attiny/ide-1.6.x-boards-manager/package_damellis_attiny_index.json"
"build_cache": {
"compilations_before_purge": 10,
"ttl": "720h0m0s"
"daemon": {
"port": "50051"
"directories": {
"data": "c:\\Users\\Abu-Hafss\\AppData\\Local\\Arduino15",
"user": "h:\\Users\\Abu-Hafss\\Arduino"
"library": {
"enable_unsafe_install": false
"logging": {
"file": "",
"format": "text",
"level": "info"
"metrics": {
"addr": ":9090",
"enabled": true
"output": {
"no_color": false
"sketch": {
"always_export_binaries": false
"updater": {
"enable_notification": true
"locale": "en",
"network": {}
2023-06-01T20:35:49.996Z root ERROR Request setConfiguration failed with error: 2 UNKNOWN: open c:\Users\Abu-Hafss\.arduinoIDE\arduino-cli.yaml: Access is denied.
2023-06-01T20:36:30.148Z config INFO Updating daemon with 'data': {
"board_manager": {
"build_cache": {
"ttl": "720h0m0s"
"daemon": {
"port": "50051"
"directories": {
"library": {
"logging": {
"file": "",
"format": "text",
"level": "info"
"metrics": {
"addr": ":9090",
"enabled": true
"output": {
"no_color": false
"sketch": {
"updater": {
"locale": "en",
"network": {}
2023-06-01T20:36:30.226Z root ERROR Request setConfiguration failed with error: 2 UNKNOWN: open c:\Users\Abu-Hafss\.arduinoIDE\arduino-cli.yaml: Access is denied.
2023-06-01T20:36:59.589Z root WARN Widget was activated, but did not accept focus after 2000ms: boards-list-widget
2023-06-01T20:37:15.202Z config INFO Updating daemon with 'data': {
"board_manager": {
"build_cache": {
"ttl": "720h0m0s"
"daemon": {
"port": "50051"
"directories": {
"library": {
"logging": {
"file": "",
"format": "text",
"level": "info"
"metrics": {
"addr": ":9090",
"enabled": true
"output": {
"no_color": false
"sketch": {
"updater": {
"locale": "en",
"network": {}
2023-06-01T20:37:15.272Z root ERROR Request setConfiguration failed with error: 2 UNKNOWN: open c:\Users\Abu-Hafss\.arduinoIDE\arduino-cli.yaml: Access is denied.
2023-06-01T20:37:29.733Z config INFO Updating daemon with 'data': {
"board_manager": {
"build_cache": {
"ttl": "720h0m0s"
"daemon": {
"port": "50051"
"directories": {
"library": {
"logging": {
"file": "",
"format": "text",
"level": "info"
"metrics": {
"addr": ":9090",
"enabled": true
"output": {
"no_color": false
"sketch": {
"updater": {
"locale": "en",
"network": {}
2023-06-01T20:37:29.784Z root ERROR Request setConfiguration failed with error: 2 UNKNOWN: open c:\Users\Abu-Hafss\.arduinoIDE\arduino-cli.yaml: Access is denied.
By the way, I highly appreciate your detailed step-by-step guidance.
We can see the error occurring here when Arduino IDE attempts to save your preferences. Unfortunately it doesn't tell us why it is not able to save. Do you have any idea why Arduino IDE would not be able to write to the file at this path?:
Well, I have no idea about that.
As mentioned in my first post, the libraries are also not updating. Maybe this can give you some clue.
If no solution, then probably I should switch back to an older version.
This is easily solved. The problem is you have multiple installations of the same library:
You must delete the folders that contain the redundant library installations. Once you have done that you will be able to use Library Manager.
