IDE 2.3.2 showing startup issues
PS C:\Users\spara\AppData\Local\Programs\arduino-ide>  & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 20928
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/spara/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-07-05T02:21:07.730Z root INFO Backend Object.initialize: 9.2 ms [Finished 1.207 s after backend start]
2024-07-05T02:21:07.732Z root INFO Backend Object.configure: 7.6 ms [Finished 1.207 s after backend start]
2024-07-05T02:21:07.732Z root INFO Backend s.onStart: 3.5 ms [Finished 1.207 s after backend start]
2024-07-05T02:21:07.733Z root INFO Backend s.configure: 0.7 ms [Finished 1.250 s after backend start]
2024-07-05T02:21:07.735Z root INFO Backend d.onStart: 0.6 ms [Finished 1.250 s after backend start]
2024-07-05T02:21:07.736Z root INFO Backend d.configure: 0.3 ms [Finished 1.250 s after backend start]
2024-07-05T02:21:07.738Z root INFO Backend d.initialize: 43.1 ms [Finished 1.251 s after backend start]
2024-07-05T02:21:07.739Z root INFO Backend c.onStart: 0.6 ms [Finished 1.251 s after backend start]
2024-07-05T02:21:07.740Z root INFO Backend a.configure: 2.5 ms [Finished 1.253 s after backend start]
2024-07-05T02:21:07.744Z config INFO >>> Initializing CLI configuration...
2024-07-05T02:21:07.744Z root INFO Backend c.initialize: 1.0 ms [Finished 1.254 s after backend start]
2024-07-05T02:21:07.744Z root INFO Backend R.onStart: 1.5 ms [Finished 1.255 s after backend start]
2024-07-05T02:21:07.745Z config INFO Loading CLI configuration from c:\Users\spara\.arduinoIDE\arduino-cli.yaml...
2024-07-05T02:21:07.746Z daemon INFO Starting daemon from C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-cli.exe...
2024-07-05T02:21:07.747Z root INFO Backend a.initialize: 0.9 ms [Finished 1.257 s after backend start]
2024-07-05T02:21:07.747Z root INFO Backend w.onStart: 2.7 ms [Finished 1.259 s after backend start]
2024-07-05T02:21:07.747Z root INFO Backend r.configure: 4.2 ms [Finished 1.259 s after backend start]
2024-07-05T02:21:07.747Z discovery-log INFO start
2024-07-05T02:21:07.747Z discovery-log INFO start new deferred
2024-07-05T02:21:07.747Z root INFO Backend d.initialize: 1.1 ms [Finished 1.261 s after backend start]
2024-07-05T02:21:07.747Z root INFO Backend y.onStart: 4.8 ms [Finished 1.264 s after backend start]
2024-07-05T02:21:07.747Z root INFO Backend r.configure: 4.1 ms [Finished 1.265 s after backend start]
2024-07-05T02:21:07.747Z root INFO Backend a.onStart: 1.2 ms [Finished 1.267 s after backend start]
2024-07-05T02:21:07.747Z root INFO Backend h.configure: 1.1 ms [Finished 1.267 s after backend start]
2024-07-05T02:21:07.747Z root INFO Backend s.configure: 0.2 ms [Finished 1.268 s after backend start]
2024-07-05T02:21:07.747Z root INFO Backend l.configure: 0.1 ms [Finished 1.268 s after backend start]
2024-07-05T02:21:07.752Z root INFO Theia app listening on http://127.0.0.1:64770.
2024-07-05T02:21:07.753Z root INFO Finished starting backend application: 5.5 ms [Finished 1.273 s after backend start]
2024-07-05T02:21:07.754Z root WARN The local plugin referenced by local-dir:/c%3A/Users/spara/.arduinoIDE/plugins does not exist.
2024-07-05T02:21:07.754Z root WARN The local plugin referenced by local-dir:/c%3A/Users/spara/.arduinoIDE/extensions does not exist.
2024-07-05T02:21:07.754Z root WARN The local plugin referenced by local-dir:C:\Users\spara\.arduinoIDE\plugins does not exist.
2024-07-05T02:21:07.920Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["http://arduino.esp8266.com/stable/package_esp8266com_index.json","https://dl.espressif.com/dl/package_esp32_index.json"]},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\spara\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\spara\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\spara\\AppData\\Local\\Arduino15\\staging","user":"c:\\Users\\spara\\OneDrive\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"network":{"proxy":"http://_/","user_agent_ext":"daemon"},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-07-05T02:21:07.920Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-07-05T02:21:07.920Z config INFO Loaded the CLI configuration.
2024-07-05T02:21:08.030Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/spara/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/spara/OneDrive/Documents/Arduino","additionalUrls":["http://arduino.esp8266.com/stable/package_esp8266com_index.json","https://dl.espressif.com/dl/package_esp32_index.json"],"network":{"protocol":"http","hostname":"_","password":"","username":"","port":""},"locale":"en"}
2024-07-05T02:21:08.030Z config INFO Validating the CLI configuration...
2024-07-05T02:21:08.031Z config INFO The CLI config is valid.
2024-07-05T02:21:08.031Z config INFO <<< Initialized the CLI configuration.
2024-07-05T02:21:08.049Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Using config file: c:\\Users\\spara\\.arduinoIDE\\arduino-cli.yaml"
2024-07-05T02:21:08.050Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-07-05T07:51:08+05:30" level=info msg="Executing `arduino-cli daemon`"
2024-07-05T02:21:08.060Z daemon INFO Daemon is now listening on 127.0.0.1:64771
{"IP":"127.0.0.1","Port":"64771"}
2024-07-05T02:21:08.060Z daemon INFO Daemon is running.
2024-07-05T02:21:08.112Z root INFO Resolve plugins list: 366.8 ms [Finished 1.632 s after backend start]
2024-07-05T02:21:08.125Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Checking signature" index="c:\\Users\\spara\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\spara\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-07-05T02:21:08.129Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Missing signature file" index="c:\\Users\\spara\\AppData\\Local\\Arduino15\\package_esp8266com_index.json"
2024-07-05T02:21:08.129Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Missing signature file" index="c:\\Users\\spara\\AppData\\Local\\Arduino15\\package_esp32_index.json"
2024-07-05T02:21:08.130Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Loading hardware from: c:\\Users\\spara\\AppData\\Local\\Arduino15\\packages"
2024-07-05T02:21:08.131Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Loading package arduino from: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2024-07-05T02:21:08.132Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Missing signature file" index="C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
2024-07-05T02:21:08.135Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-07-05T07:51:08+05:30" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
2024-07-05T02:21:08.136Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-07-05T07:51:08+05:30" level=info msg="Loaded platform" platform="arduino:renesas_uno@1.2.0"
2024-07-05T02:21:08.136Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Checking existence of 'tools' path: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-07-05T07:51:08+05:30" level=info msg="Loading tools from dir: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2024-07-05T02:21:08.137Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2024-07-05T02:21:08.137Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2024-07-05T02:21:08.137Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2024-07-05T02:21:08.137Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2024-07-05T02:21:08.137Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Loaded tool" tool="arduino:bossac@1.9.1-arduino5"
2024-07-05T02:21:08.138Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-07-05T07:51:08+05:30" level=info msg="Loaded tool" tool="arduino:openocd@0.11.0-arduino2"
time="2024-07-05T07:51:08+05:30" level=info msg="Loading package builtin from: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-07-05T02:21:08.139Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Checking existence of 'tools' path: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-07-05T07:51:08+05:30" level=info msg="Loading tools from dir: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-07-05T02:21:08.139Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-07-05T02:21:08.140Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.8"
2024-07-05T02:21:08.141Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.5"
time="2024-07-05T07:51:08+05:30" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.12.0"
2024-07-05T02:21:08.142Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Loading package esp8266 from: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
2024-07-05T02:21:08.174Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-07-05T07:51:08+05:30" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.2"
2024-07-05T02:21:08.174Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Checking existence of 'tools' path: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2024-07-05T07:51:08+05:30" level=info msg="Loading tools from dir: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
2024-07-05T02:21:08.175Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
2024-07-05T02:21:08.175Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
2024-07-05T02:21:08.175Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
2024-07-05T02:21:08.175Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
2024-07-05T02:21:08.179Z daemon INFO time="2024-07-05T07:51:08+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip"
Opening channel for service path '/services/electron-window'.
2024-07-05T02:21:10.904Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:dfu-discovery@0.1.2 tool: Get "https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip": proxyconnect tcp: dial tcp: lookup _: no such host
2024-07-05T02:21:10.905Z daemon INFO time="2024-07-05T07:51:10+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip"
Opening channel for service path '/services/ide-updater'.
2024-07-05T02:21:11.472Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 457.2 ms [Finished 3.480 s after frontend start]
2024-07-05T02:21:11.481Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-07-05T02:21:12.015Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 380.1 ms [Finished 4.046 s after frontend start]
2024-07-05T02:21:13.357Z root INFO Deploy plugins list: 366.8 ms [Finished 6.878 s after backend start]
2024-07-05T02:21:13.563Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:mdns-discovery@1.0.9 tool: Get "https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip": proxyconnect tcp: dial tcp: lookup _: no such host
2024-07-05T02:21:13.564Z daemon INFO time="2024-07-05T07:51:13+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.1_Windows_64bit.zip"
2024-07-05T02:21:16.261Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-discovery@1.4.1 tool: Get "https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.1_Windows_64bit.zip": proxyconnect tcp: dial tcp: lookup _: no such host
2024-07-05T02:21:16.261Z daemon INFO time="2024-07-05T07:51:16+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.14.1_Windows_64bit.zip"
2024-07-05T02:21:18.954Z daemon INFO time="2024-07-05T07:51:18+05:30" level=info msg="Loading tools from dir: c:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-07-05T02:21:18.955Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-monitor@0.14.1 tool: Get "https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.14.1_Windows_64bit.zip": proxyconnect tcp: dial tcp: lookup _: no such host
2024-07-05T02:21:18.955Z daemon INFO time="2024-07-05T07:51:18+05:30" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-07-05T07:51:18+05:30" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.8"
time="2024-07-05T07:51:18+05:30" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.5"
time="2024-07-05T07:51:18+05:30" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.12.0"
2024-07-05T02:21:18.956Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:dfu-discovery not installed
2024-07-05T02:21:18.958Z daemon INFO time="2024-07-05T07:51:18+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
2024-07-05T02:21:18.960Z daemon INFO time="2024-07-05T07:51:18+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.2.0\\libraries" location=platform
2024-07-05T02:21:18.963Z daemon INFO time="2024-07-05T07:51:18+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" location=platform
time="2024-07-05T07:51:18+05:30" level=info msg="Loading libraries index file" index="c:\\Users\\spara\\AppData\\Local\\Arduino15\\library_index.json"
2024-07-05T02:21:19.287Z daemon INFO time="2024-07-05T07:51:19+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\spara\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-07-05T02:21:19.288Z daemon INFO time="2024-07-05T07:51:19+05:30" level=info msg="Adding libraries dir" dir="c:\\Users\\spara\\OneDrive\\Documents\\Arduino\\libraries" location=user
2024-07-05T02:21:19.861Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:dfu-discovery not installed
2024-07-05T02:21:19.862Z daemon INFO time="2024-07-05T07:51:19+05:30" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-07-05T02:21:19.865Z daemon INFO time="2024-07-05T07:51:19+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-07-05T02:21:19.868Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-07-05T02:21:22.571Z daemon INFO time="2024-07-05T07:51:22+05:30" level=info msg="Updating index" url="http://arduino.esp8266.com/stable/package_esp8266com_index.json"
2024-07-05T02:21:22.571Z daemon INFO time="2024-07-05T07:51:22+05:30" level=info msg="Starting download" url="http://arduino.esp8266.com/stable/package_esp8266com_index.json"
2024-07-05T02:21:22.572Z root INFO core-client-provider [platform-index] Downloading index: package_esp8266com_index.json
2024-07-05T02:21:25.273Z daemon INFO time="2024-07-05T07:51:25+05:30" level=info msg="Updating index" url="https://dl.espressif.com/dl/package_esp32_index.json"
2024-07-05T02:21:25.274Z daemon INFO time="2024-07-05T07:51:25+05:30" level=info msg="Starting download" url="https://dl.espressif.com/dl/package_esp32_index.json"
2024-07-05T02:21:25.276Z root INFO core-client-provider [platform-index] Downloading index: package_esp32_index.json
2024-07-05T02:21:27.987Z root ERROR Failed to update platform indexes. Error: 13 INTERNAL: Some indexes could not be updated.
    at t.callErrorFromStatus (C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:763461)
    at Object.onReceiveStatus (C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:791078)
    at Object.onReceiveStatus (C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:784102)
    at C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:870224
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
    at s.makeServerStreamRequest (C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:790845)
    at s.updateIndex (C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:855121)
    at C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:623733
    at C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:624081
    at new Promise (<anonymous>)
    at E.doUpdateIndex (C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:624060)
    at E.updatePlatformIndex (C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:623705)
    at E.updateIndex (C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:623073)
    at E.initInstanceWithFallback (C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:621317)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2024-07-05T02:21:28.018Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Checking signature" index="c:\\Users\\spara\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\spara\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-07-05T02:21:28.021Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Missing signature file" index="c:\\Users\\spara\\AppData\\Local\\Arduino15\\package_esp8266com_index.json"
2024-07-05T02:21:28.022Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Missing signature file" index="c:\\Users\\spara\\AppData\\Local\\Arduino15\\package_esp32_index.json"
2024-07-05T02:21:28.023Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loading hardware from: c:\\Users\\spara\\AppData\\Local\\Arduino15\\packages"
2024-07-05T02:21:28.025Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loading package arduino from: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2024-07-05T02:21:28.028Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Missing signature file" index="C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
2024-07-05T02:21:28.032Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-07-05T07:51:28+05:30" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
2024-07-05T02:21:28.034Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-07-05T07:51:28+05:30" level=info msg="Loaded platform" platform="arduino:renesas_uno@1.2.0"
time="2024-07-05T07:51:28+05:30" level=info msg="Checking existence of 'tools' path: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2024-07-05T02:21:28.034Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loading tools from dir: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2024-07-05T02:21:28.035Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2024-07-05T02:21:28.035Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2024-07-05T02:21:28.035Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2024-07-05T02:21:28.036Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2024-07-05T02:21:28.036Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loaded tool" tool="arduino:bossac@1.9.1-arduino5"
2024-07-05T02:21:28.037Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
2024-07-05T02:21:28.037Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loaded tool" tool="arduino:openocd@0.11.0-arduino2"
2024-07-05T02:21:28.038Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loading package builtin from: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-07-05T02:21:28.038Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Checking existence of 'tools' path: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-07-05T07:51:28+05:30" level=info msg="Loading tools from dir: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-07-05T02:21:28.039Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-07-05T02:21:28.041Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.8"
2024-07-05T02:21:28.042Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.5"
2024-07-05T02:21:28.042Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.12.0"
2024-07-05T02:21:28.043Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loading package esp8266 from: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
2024-07-05T02:21:28.067Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-07-05T07:51:28+05:30" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.2"
2024-07-05T02:21:28.067Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Checking existence of 'tools' path: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2024-07-05T07:51:28+05:30" level=info msg="Loading tools from dir: C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
2024-07-05T02:21:28.067Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
2024-07-05T02:21:28.067Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
2024-07-05T02:21:28.068Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
time="2024-07-05T07:51:28+05:30" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
2024-07-05T02:21:28.068Z daemon INFO time="2024-07-05T07:51:28+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip"
2024-07-05T02:21:30.748Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:dfu-discovery@0.1.2 tool: Get "https://downloads.arduino.cc/discovery/dfu-discovery/dfu-discovery_v0.1.2_Windows_64bit.zip": proxyconnect tcp: dial tcp: lookup _: no such host
2024-07-05T02:21:30.748Z daemon INFO time="2024-07-05T07:51:30+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip"
2024-07-05T02:21:33.463Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:mdns-discovery@1.0.9 tool: Get "https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.9_Windows_64bit.zip": proxyconnect tcp: dial tcp: lookup _: no such host
2024-07-05T02:21:33.464Z daemon INFO time="2024-07-05T07:51:33+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.1_Windows_64bit.zip"
2024-07-05T02:21:36.158Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-discovery@1.4.1 tool: Get "https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.1_Windows_64bit.zip": proxyconnect tcp: dial tcp: lookup _: no such host
2024-07-05T02:21:36.159Z daemon INFO time="2024-07-05T07:51:36+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.14.1_Windows_64bit.zip"
2024-07-05T02:21:38.840Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: downloading builtin:serial-monitor@0.14.1 tool: Get "https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.14.1_Windows_64bit.zip": proxyconnect tcp: dial tcp: lookup _: no such host
2024-07-05T02:21:38.840Z daemon INFO time="2024-07-05T07:51:38+05:30" level=info msg="Loading tools from dir: c:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-07-05T07:51:38+05:30" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-07-05T07:51:38+05:30" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.8"
2024-07-05T02:21:38.840Z daemon INFO time="2024-07-05T07:51:38+05:30" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.5"
2024-07-05T02:21:38.841Z daemon INFO time="2024-07-05T07:51:38+05:30" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.12.0"
2024-07-05T02:21:38.841Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:dfu-discovery not installed
2024-07-05T02:21:38.843Z daemon INFO time="2024-07-05T07:51:38+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" location=platform
2024-07-05T02:21:38.846Z daemon INFO time="2024-07-05T07:51:38+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
2024-07-05T02:21:38.848Z daemon INFO time="2024-07-05T07:51:38+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\spara\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.2.0\\libraries" location=platform
time="2024-07-05T07:51:38+05:30" level=info msg="Loading libraries index file" index="c:\\Users\\spara\\AppData\\Local\\Arduino15\\library_index.json"
2024-07-05T02:21:39.142Z daemon INFO time="2024-07-05T07:51:39+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\spara\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-07-05T02:21:39.143Z daemon INFO time="2024-07-05T07:51:39+05:30" level=info msg="Adding libraries dir" dir="c:\\Users\\spara\\OneDrive\\Documents\\Arduino\\libraries" location=user
2024-07-05T02:21:39.517Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-07-05T02:21:39.517Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
    at C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:622877
    at E.evaluateErrorStatus (C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:622893)
    at async a.<anonymous> (C:\Users\spara\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\main.js:2:622563)
please help me to sort it out
Hi @aravindspratap.
There is a bug in Arduino IDE that causes it to get an invalid configuration if you set the preferences to cause Arduino IDE to access the Internet through a proxy server, and then later change the preferences back to "No proxy". This error indicates that your Arduino IDE preferences are in this bad state.
I'll provide instructions you can follow to fix the configuration:
  1. Select File > Quit from the Arduino IDE menus if it is running.
  2. Delete the file at the following path:
    C:\Users\<username>\.arduinoIDE\
    (where <username> is your Windows username)
    :warning: Please be careful when deleting things from your computer. When in doubt, back up!
  3. Start Arduino IDE.
Arduino IDE should now start up fully and be functional as usual.
Note that the file you deleted is also used to store other IDE preferences. These will all have been reset to the default values. If you had customized either the "Sketchbook location"
or "Additional Boards Manager URLs" preferences, you'll need to select File > Preferences from the Arduino IDE menus and then set those preferences once again.
Please let me know if you have any questions or problems while following those instructions.
