thanks ,
this is what I got when compiling my sketch
FQBN: esp32:esp32:esp32
Using board 'esp32' from platform in folder: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3
Using core 'esp32' from platform in folder: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3
cmd /c if exist "D:\\EXT_ESP32_2024_4\\partitions.csv" COPY /y "D:\\EXT_ESP32_2024_4\\partitions.csv" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\partitions.csv"
cmd /c if not exist "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\partitions.csv" if exist "C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\variants\\esp32\\partitions.csv" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\partitions.csv"
cmd /c if not exist "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\partitions.csv" COPY "C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\tools\\partitions\\default.csv" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\partitions.csv"
cmd /c IF EXIST "D:\\EXT_ESP32_2024_4\\bootloader.bin" ( COPY /y "D:\\EXT_ESP32_2024_4\\bootloader.bin" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\EXT_ESP32_2024_4.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\variants\\esp32\\bootloader.bin" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\EXT_ESP32_2024_4.ino.bootloader.bin" ) ELSE ( "C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6\\esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\EXT_ESP32_2024_4.ino.bootloader.bin" "C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.6
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "D:\\EXT_ESP32_2024_4\\build_opt.h" COPY /y "D:\\EXT_ESP32_2024_4\\build_opt.h" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\build_opt.h"
cmd /c if not exist "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\build_opt.h" type nul > "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\build_opt.h"
cmd /c type nul > "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30/file_opts"
Detecting libraries used...
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for WiFiManager.h: [WiFiManager@2.0.17]
ResolveLibrary(WiFiManager.h)
-> candidates: [WiFiManager@2.0.17]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for WiFi.h: [WiFi@3.0.3]
ResolveLibrary(WiFi.h)
-> candidates: [WiFi@3.0.3]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for Network.h: [Networking@3.0.3]
ResolveLibrary(Network.h)
-> candidates: [Networking@3.0.3]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for Update.h: [Update@3.0.3]
ResolveLibrary(Update.h)
-> candidates: [Update@3.0.3]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for WebServer.h: [WebServer@3.0.3]
ResolveLibrary(WebServer.h)
-> candidates: [WebServer@3.0.3]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for FS.h: [FS@3.0.3]
ResolveLibrary(FS.h)
-> candidates: [FS@3.0.3]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\FS\src @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for DNSServer.h: [DNSServer@3.0.3]
ResolveLibrary(DNSServer.h)
-> candidates: [DNSServer@3.0.3]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\FS\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\DNSServer\src @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for AsyncUDP.h: [ESP32 Async UDP@3.0.3]
ResolveLibrary(AsyncUDP.h)
-> candidates: [ESP32 Async UDP@3.0.3]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\FS\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\DNSServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\AsyncUDP\src @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for ArduinoOTA.h: [ArduinoOTA@3.0.3]
ResolveLibrary(ArduinoOTA.h)
-> candidates: [ArduinoOTA@3.0.3]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\FS\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\DNSServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\AsyncUDP\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\ArduinoOTA\src @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for Adafruit_BMP280.h: [Adafruit BMP280 Library@2.6.8]
ResolveLibrary(Adafruit_BMP280.h)
-> candidates: [Adafruit BMP280 Library@2.6.8]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\FS\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\DNSServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\AsyncUDP\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\ArduinoOTA\src -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BMP280_Library @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for Adafruit_Sensor.h: [Adafruit Unified Sensor@1.1.14]
ResolveLibrary(Adafruit_Sensor.h)
-> candidates: [Adafruit Unified Sensor@1.1.14]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\FS\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\DNSServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\AsyncUDP\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\ArduinoOTA\src -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BMP280_Library -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_Unified_Sensor @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit BusIO@1.16.1]
ResolveLibrary(Adafruit_I2CDevice.h)
-> candidates: [Adafruit BusIO@1.16.1]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\FS\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\DNSServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\AsyncUDP\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\ArduinoOTA\src -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BMP280_Library -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_Unified_Sensor -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BusIO @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for Wire.h: [Wire@1.0 Wire@3.0.3]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0 Wire@3.0.3]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\FS\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\DNSServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\AsyncUDP\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\ArduinoOTA\src -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BMP280_Library -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_Unified_Sensor -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Wire\src @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for SPI.h: [SPI@3.0.3]
ResolveLibrary(SPI.h)
-> candidates: [SPI@3.0.3]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\FS\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\DNSServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\AsyncUDP\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\ArduinoOTA\src -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BMP280_Library -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_Unified_Sensor -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Wire\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\SPI\src @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for SHT1x-ESP.h: [SHT1x sensor library for ESPx@1.0.2]
ResolveLibrary(SHT1x-ESP.h)
-> candidates: [SHT1x sensor library for ESPx@1.0.2]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\FS\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\DNSServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\AsyncUDP\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\ArduinoOTA\src -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BMP280_Library -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_Unified_Sensor -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Wire\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\SPI\src -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\SHT1x_sensor_library_for_ESPx @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for ArtronShop_SHT45.h: [ArtronShop_SHT45@1.0.0]
ResolveLibrary(ArtronShop_SHT45.h)
-> candidates: [ArtronShop_SHT45@1.0.0]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\FS\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\DNSServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\AsyncUDP\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\ArduinoOTA\src -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BMP280_Library -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_Unified_Sensor -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Wire\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\SPI\src -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\SHT1x_sensor_library_for_ESPx -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\ArtronShop_SHT45\src @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Alternatives for AHT20.h: [AHT20@1.0.1]
ResolveLibrary(AHT20.h)
-> candidates: [AHT20@1.0.1]
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\FS\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\DNSServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\AsyncUDP\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\ArduinoOTA\src -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BMP280_Library -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_Unified_Sensor -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Wire\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\SPI\src -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\SHT1x_sensor_library_for_ESPx -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\ArtronShop_SHT45\src -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\AHT20\src @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o nul
Using cached library dependencies for file: c:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager\WiFiManager.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src\AP.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src\STA.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src\WiFi.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src\WiFiAP.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src\WiFiGeneric.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src\WiFiMulti.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src\WiFiSTA.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src\WiFiScan.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src\NetworkClient.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src\NetworkEvents.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src\NetworkInterface.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src\NetworkManager.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src\NetworkServer.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src\NetworkUdp.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src\HttpsOTAUpdate.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src\Updater.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src\Parsing.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src\WebServer.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src\detail\mimetable.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\FS\src\FS.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\FS\src\vfs_api.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\DNSServer\src\DNSServer.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\AsyncUDP\src\AsyncUDP.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\ArduinoOTA\src\ArduinoOTA.cpp
Alternatives for ESPmDNS.h: [ESPmDNS@3.0.3]
ResolveLibrary(ESPmDNS.h)
-> candidates: [ESPmDNS@3.0.3]
Using cached library dependencies for file: c:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BMP280_Library\Adafruit_BMP280.cpp
Using cached library dependencies for file: c:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_Unified_Sensor\Adafruit_Sensor.cpp
Using cached library dependencies for file: c:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp
Using cached library dependencies for file: c:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp
Using cached library dependencies for file: c:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Wire\src\Wire.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\SPI\src\SPI.cpp
Using cached library dependencies for file: c:\Users\Ambro_PC\Documents\Arduino\libraries\SHT1x_sensor_library_for_ESPx\SHT1x-ESP.cpp
Using cached library dependencies for file: c:\Users\Ambro_PC\Documents\Arduino\libraries\ArtronShop_SHT45\src\ArtronShop_SHT45.cpp
Using cached library dependencies for file: c:\Users\Ambro_PC\Documents\Arduino\libraries\AHT20\src\AHT20.cpp
Using cached library dependencies for file: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\ESPmDNS\src\ESPmDNS.cpp
Generating function prototypes...
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/defines -ID:\EXT_ESP32_2024_4 -iprefix C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/include/ @C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/flags/includes -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-dc859c1e67\esp32/qio_qspi/include -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\cores\esp32 -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\variants\esp32 -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\FS\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\DNSServer\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\AsyncUDP\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\ArduinoOTA\src -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BMP280_Library -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_Unified_Sensor -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Wire\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\SPI\src -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\SHT1x_sensor_library_for_ESPx -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\ArtronShop_SHT45\src -Ic:\Users\Ambro_PC\Documents\Arduino\libraries\AHT20\src -IC:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\ESPmDNS\src @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/build_opt.h @C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/file_opts C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\sketch\EXT_ESP32_2024_4.ino.cpp -o C:\Users\Ambro_PC\AppData\Local\Temp\220918695\sketch_merged.cpp
C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Ambro_PC\AppData\Local\Temp\220918695\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/flags/cpp_flags" -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/flags/defines" "-ID:\\EXT_ESP32_2024_4" -iprefix "C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/include/" "@C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/flags/includes" "-IC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/qio_qspi/include" "-IC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\cores\\esp32" "-IC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\variants\\esp32" "-Ic:\\Users\\Ambro_PC\\Documents\\Arduino\\libraries\\WiFiManager" "-IC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\libraries\\WiFi\\src" "-IC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\libraries\\Network\\src" "-IC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\libraries\\Update\\src" "-IC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\libraries\\WebServer\\src" "-IC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\libraries\\FS\\src" "-IC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\libraries\\DNSServer\\src" "-IC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\libraries\\AsyncUDP\\src" "-IC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\libraries\\ArduinoOTA\\src" "-Ic:\\Users\\Ambro_PC\\Documents\\Arduino\\libraries\\Adafruit_BMP280_Library" "-Ic:\\Users\\Ambro_PC\\Documents\\Arduino\\libraries\\Adafruit_Unified_Sensor" "-Ic:\\Users\\Ambro_PC\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\libraries\\Wire\\src" "-IC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\libraries\\SPI\\src" "-Ic:\\Users\\Ambro_PC\\Documents\\Arduino\\libraries\\SHT1x_sensor_library_for_ESPx" "-Ic:\\Users\\Ambro_PC\\Documents\\Arduino\\libraries\\ArtronShop_SHT45\\src" "-Ic:\\Users\\Ambro_PC\\Documents\\Arduino\\libraries\\AHT20\\src" "-IC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\libraries\\ESPmDNS\\src" "@C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30/build_opt.h" "@C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30/file_opts" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\sketch\\EXT_ESP32_2024_4.ino.cpp" -o "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\sketch\\EXT_ESP32_2024_4.ino.cpp.o"
Compiling libraries...
Compiling library "WiFiManager"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\WiFiManager\WiFiManager.cpp.o
Compiling library "WiFi"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\WiFi\WiFi.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\WiFi\STA.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\WiFi\WiFiGeneric.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\WiFi\WiFiMulti.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\WiFi\WiFiAP.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\WiFi\AP.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\WiFi\WiFiSTA.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\WiFi\WiFiScan.cpp.o
Compiling library "Networking"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\Network\NetworkClient.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\Network\NetworkManager.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\Network\NetworkInterface.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\Network\NetworkEvents.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\Network\NetworkServer.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\Network\NetworkUdp.cpp.o
Compiling library "Update"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\Update\HttpsOTAUpdate.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\Update\Updater.cpp.o
Compiling library "WebServer"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\WebServer\detail\mimetable.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\WebServer\WebServer.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\WebServer\Parsing.cpp.o
Compiling library "FS"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\FS\vfs_api.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\FS\FS.cpp.o
Compiling library "DNSServer"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\DNSServer\DNSServer.cpp.o
Compiling library "ESP32 Async UDP"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\AsyncUDP\AsyncUDP.cpp.o
Compiling library "ArduinoOTA"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\ArduinoOTA\ArduinoOTA.cpp.o
Compiling library "Adafruit BMP280 Library"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\Adafruit_BMP280_Library\Adafruit_BMP280.cpp.o
Compiling library "Adafruit Unified Sensor"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\Adafruit_Unified_Sensor\Adafruit_Sensor.cpp.o
Compiling library "Adafruit BusIO"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp.o
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp.o
Compiling library "Wire"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\Wire\Wire.cpp.o
Compiling library "SPI"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\SPI\SPI.cpp.o
Compiling library "SHT1x sensor library for ESPx"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\SHT1x_sensor_library_for_ESPx\SHT1x-ESP.cpp.o
Compiling library "ArtronShop_SHT45"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\ArtronShop_SHT45\ArtronShop_SHT45.cpp.o
Compiling library "AHT20"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\AHT20\AHT20.cpp.o
Compiling library "ESPmDNS"
Using previously compiled file: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30\libraries\ESPmDNS\ESPmDNS.cpp.o
Compiling core...
cmd /c echo -DARDUINO_CORE_BUILD > "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30/file_opts"
Using precompiled core: C:\Users\Ambro_PC\AppData\Local\Temp\arduino\cores\986476d71a3d6fe451d02ac29c0d76a6\core.a
cmd /c type nul > "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30/file_opts"
Linking everything together...
"C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" "@C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/flags/ld_flags" "@C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/flags/ld_scripts" "-Wl,--Map=C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30/EXT_ESP32_2024_4.ino.map" "-LC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/lib" "-LC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/ld" "-LC:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/qio_qspi" -Wl,--wrap=esp_panic_handler -Wl,--start-group "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\sketch\\EXT_ESP32_2024_4.ino.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\WiFiManager\\WiFiManager.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\WiFi\\AP.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\WiFi\\STA.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\WiFi\\WiFi.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\WiFi\\WiFiAP.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\WiFi\\WiFiGeneric.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\WiFi\\WiFiMulti.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\WiFi\\WiFiSTA.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\WiFi\\WiFiScan.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\Network\\NetworkClient.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\Network\\NetworkEvents.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\Network\\NetworkInterface.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\Network\\NetworkManager.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\Network\\NetworkServer.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\Network\\NetworkUdp.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\Update\\HttpsOTAUpdate.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\Update\\Updater.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\WebServer\\Parsing.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\WebServer\\WebServer.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\WebServer\\detail\\mimetable.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\FS\\FS.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\FS\\vfs_api.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\DNSServer\\DNSServer.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\AsyncUDP\\AsyncUDP.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\ArduinoOTA\\ArduinoOTA.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\Adafruit_BMP280_Library\\Adafruit_BMP280.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\Adafruit_Unified_Sensor\\Adafruit_Sensor.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\SHT1x_sensor_library_for_ESPx\\SHT1x-ESP.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\ArtronShop_SHT45\\ArtronShop_SHT45.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\AHT20\\AHT20.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\ESPmDNS\\ESPmDNS.cpp.o" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\cores\\986476d71a3d6fe451d02ac29c0d76a6\\core.a" "@C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32/flags/ld_libs" -Wl,--end-group -Wl,-EL -o "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30/EXT_ESP32_2024_4.ino.elf"
"C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB --elf-sha256-offset 0xb0 -o "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30/EXT_ESP32_2024_4.ino.bin" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30/EXT_ESP32_2024_4.ino.elf"
esptool.py v4.6
Creating esp32 image...
Merged 27 ELF sections
Successfully created esp32 image.
"C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\tools\\gen_esp32part.exe" -q "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30/partitions.csv" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30/EXT_ESP32_2024_4.ino.partitions.bin"
cmd /c if exist "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\Insights" "C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3\\tools\\gen_insights_package.exe" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30" EXT_ESP32_2024_4.ino "D:\\EXT_ESP32_2024_4"
cmd /c if exist "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\libraries\\ESP_SR" if exist "C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32\\esp_sr\\srmodels.bin" COPY /y "C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-dc859c1e67\\esp32\\esp_sr\\srmodels.bin" "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30\\srmodels.bin"
"C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6/esptool.exe" --chip esp32 merge_bin -o "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30/EXT_ESP32_2024_4.ino.merged.bin" --fill-flash-size 4MB --flash_mode keep --flash_freq keep --flash_size keep 0x1000 "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30/EXT_ESP32_2024_4.ino.bootloader.bin" 0x8000 "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30/EXT_ESP32_2024_4.ino.partitions.bin" 0xe000 "C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.3/tools/partitions/boot_app0.bin" 0x10000 "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30/EXT_ESP32_2024_4.ino.bin"
esptool.py v4.6
Wrote 0x400000 bytes to file C:\Users\Ambro_PC\AppData\Local\Temp\arduino\sketches\55F0939C48B5368283530BEF93AD2D30/EXT_ESP32_2024_4.ino.merged.bin, ready to flash to offset 0x0
Multiple libraries were found for "Wire.h"
Used: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Wire
Not used: C:\Users\Ambro_PC\Documents\Arduino\libraries\Wire
Using library WiFiManager at version 2.0.17 in folder: C:\Users\Ambro_PC\Documents\Arduino\libraries\WiFiManager
Using library WiFi at version 3.0.3 in folder: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WiFi
Using library Networking at version 3.0.3 in folder: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Network
Using library Update at version 3.0.3 in folder: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Update
Using library WebServer at version 3.0.3 in folder: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\WebServer
Using library FS at version 3.0.3 in folder: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\FS
Using library DNSServer at version 3.0.3 in folder: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\DNSServer
Using library ESP32 Async UDP at version 3.0.3 in folder: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\AsyncUDP
Using library ArduinoOTA at version 3.0.3 in folder: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\ArduinoOTA
Using library Adafruit BMP280 Library at version 2.6.8 in folder: C:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BMP280_Library
Using library Adafruit Unified Sensor at version 1.1.14 in folder: C:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_Unified_Sensor
Using library Adafruit BusIO at version 1.16.1 in folder: C:\Users\Ambro_PC\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 3.0.3 in folder: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\Wire
Using library SPI at version 3.0.3 in folder: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\SPI
Using library SHT1x sensor library for ESPx at version 1.0.2 in folder: C:\Users\Ambro_PC\Documents\Arduino\libraries\SHT1x_sensor_library_for_ESPx
Using library ArtronShop_SHT45 at version 1.0.0 in folder: C:\Users\Ambro_PC\Documents\Arduino\libraries\ArtronShop_SHT45
Using library AHT20 at version 1.0.1 in folder: C:\Users\Ambro_PC\Documents\Arduino\libraries\AHT20
Using library ESPmDNS at version 3.0.3 in folder: C:\Users\Ambro_PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.3\libraries\ESPmDNS
"C:\\Users\\Ambro_PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-size" -A "C:\\Users\\Ambro_PC\\AppData\\Local\\Temp\\arduino\\sketches\\55F0939C48B5368283530BEF93AD2D30/EXT_ESP32_2024_4.ino.elf"
Sketch uses 1098265 bytes (83%) of program storage space. Maximum is 1310720 bytes.
Global variables use 49996 bytes (15%) of dynamic memory, leaving 277684 bytes for local variables. Maximum is 327680 bytes.
