PS C:\Program Files\Arduino IDE> &".\Arduino IDE"
Arduino IDE 2.3.3
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.0.4" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-09-25T09:41:18.242Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3","cliVersion":"1.0.4","buildDate":"2024-09-25T09:41:18.242Z"}
Starting backend process. PID: 20608
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/jjmva/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-10-09T14:24:27.356Z root INFO Backend Object.initialize: 4.5 ms [Finished 0.474 s after backend start]
2024-10-09T14:24:27.357Z root INFO Backend Object.configure: 3.9 ms [Finished 0.474 s after backend start]
2024-10-09T14:24:27.357Z root INFO Backend a.onStart: 2.4 ms [Finished 0.475 s after backend start]
2024-10-09T14:24:27.358Z root INFO Backend a.configure: 0.4 ms [Finished 0.499 s after backend start]
2024-10-09T14:24:27.358Z root INFO Backend d.onStart: 0.2 ms [Finished 0.499 s after backend start]
2024-10-09T14:24:27.359Z root INFO Backend d.configure: 0.1 ms [Finished 0.499 s after backend start]
2024-10-09T14:24:27.360Z root INFO Backend d.initialize: 24.4 ms [Finished 0.499 s after backend start]
2024-10-09T14:24:27.360Z root INFO Backend c.onStart: 0.2 ms [Finished 0.499 s after backend start]
2024-10-09T14:24:27.360Z root INFO Backend s.configure: 1.2 ms [Finished 0.500 s after backend start]
2024-10-09T14:24:27.362Z config INFO >>> Initializing CLI configuration...
2024-10-09T14:24:27.362Z root INFO Backend c.initialize: 0.5 ms [Finished 0.501 s after backend start]
2024-10-09T14:24:27.362Z root INFO Backend x.onStart: 0.6 ms [Finished 0.501 s after backend start]
2024-10-09T14:24:27.363Z config INFO Loading CLI configuration from c:\Users\jjmva\.arduinoIDE\arduino-cli.yaml...
2024-10-09T14:24:27.363Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-10-09T14:24:27.363Z root INFO Backend s.initialize: 0.4 ms [Finished 0.502 s after backend start]
2024-10-09T14:24:27.363Z root INFO Backend w.onStart: 1.1 ms [Finished 0.503 s after backend start]
2024-10-09T14:24:27.363Z root INFO Backend r.configure: 1.8 ms [Finished 0.503 s after backend start]
2024-10-09T14:24:27.363Z discovery-log INFO start
2024-10-09T14:24:27.363Z discovery-log INFO start new deferred
2024-10-09T14:24:27.364Z root INFO Backend d.initialize: 0.4 ms [Finished 0.503 s after backend start]
2024-10-09T14:24:27.364Z root INFO Backend y.onStart: 1.8 ms [Finished 0.505 s after backend start]
2024-10-09T14:24:27.364Z root INFO Backend r.configure: 1.5 ms [Finished 0.505 s after backend start]
2024-10-09T14:24:27.364Z root INFO Backend s.onStart: 0.5 ms [Finished 0.506 s after backend start]
2024-10-09T14:24:27.364Z root INFO Backend h.configure: 0.5 ms [Finished 0.506 s after backend start]
2024-10-09T14:24:27.364Z root INFO Backend a.configure: 0.1 ms [Finished 0.507 s after backend start]
2024-10-09T14:24:27.364Z root INFO Backend l.configure: 0.1 ms [Finished 0.507 s after backend start]
2024-10-09T14:24:27.366Z root INFO Theia app listening on http://127.0.0.1:50271.
2024-10-09T14:24:27.366Z root INFO Finished starting backend application: 2.7 ms [Finished 0.509 s after backend start]
2024-10-09T14:24:27.367Z root WARN The local plugin referenced by local-dir:/c%3A/Users/jjmva/.arduinoIDE/plugins does not exist.
2024-10-09T14:24:27.367Z root WARN The local plugin referenced by local-dir:/c%3A/Users/jjmva/.arduinoIDE/extensions does not exist.
2024-10-09T14:24:27.367Z root WARN The local plugin referenced by local-dir:C:\Users\jjmva\.arduinoIDE\plugins does not exist.
2024-10-09T14:24:27.372Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["http://arduino.esp8266.com/stable/package_esp8266com_index.jsonebServer.git","https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json","ps://raw.githubusercontent.com/espressif/arduino-esp32/gh\u0002pages/package_esp32_index.json"]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\jjmva\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\jjmva\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\jjmva\\AppData\\Local\\Arduino15\\staging","user":"c:\\Users\\jjmva\\.arduinoIDE"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-10-09T14:24:27.372Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-10-09T14:24:27.372Z config INFO Loaded the CLI configuration.
Restoring workspace roots: c:\Users\jjmva\.arduinoIDE\4_digits_multiplexing\4_digits_multiplexing.ino
isTempSketch: false. Input was c:\Users\jjmva\.arduinoIDE\4_digits_multiplexing\4_digits_multiplexing.ino
2024-10-09T14:24:27.383Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/jjmva/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/jjmva/.arduinoIDE","additionalUrls":["http://arduino.esp8266.com/stable/package_esp8266com_index.jsonebServer.git","https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json","ps://raw.githubusercontent.com/espressif/arduino-esp32/gh\u0002pages/package_esp32_index.json"],"network":"none","locale":"en"}
2024-10-09T14:24:27.383Z config INFO Validating the CLI configuration...
2024-10-09T14:24:27.383Z config INFO The CLI config is valid.
2024-10-09T14:24:27.383Z config INFO <<< Initialized the CLI configuration.
2024-10-09T14:24:27.400Z root INFO Resolve plugins list: 37.3 ms [Finished 0.542 s after backend start]
2024-10-09T14:24:27.477Z daemon INFO time="2024-10-09T16:24:27+02:00" level=info msg="arduino-cli version 1.0.4"
time="2024-10-09T16:24:27+02:00" level=info msg="Using config file: c:\\Users\\jjmva\\.arduinoIDE\\arduino-cli.yaml"
time="2024-10-09T16:24:27+02:00" level=info msg="Executing `arduino-cli daemon`"
2024-10-09T14:24:27.492Z daemon INFO Daemon is now listening on 127.0.0.1:50272
{"IP":"127.0.0.1","Port":"50272"}
2024-10-09T14:24:27.492Z daemon INFO Daemon is running.
2024-10-09T14:24:27.543Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Invalid additional URL: parse "ps://raw.githubusercontent.com/espressif/arduino-esp32/gh\x02pages/package_esp32_index.json": net/url: invalid control character in URL
2024-10-09T14:24:27.544Z daemon INFO time="2024-10-09T16:24:27+02:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
time="2024-10-09T16:24:27+02:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-10-09T14:24:27.819Z daemon INFO time="2024-10-09T16:24:27+02:00" level=info msg="Updating index" url="http://arduino.esp8266.com/stable/package_esp8266com_index.jsonebServer.git"
time="2024-10-09T16:24:27+02:00" level=info msg="Starting download" url="http://arduino.esp8266.com/stable/package_esp8266com_index.jsonebServer.git"
2024-10-09T14:24:27.868Z daemon INFO time="2024-10-09T16:24:27+02:00" level=info msg="Updating index" url="https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"
time="2024-10-09T16:24:27+02:00" level=info msg="Starting download" url="https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"
2024-10-09T14:24:27.931Z root ERROR Error occurred while initializing the core gRPC client provider Error: 14 UNAVAILABLE: read ECONNRESET
at t.callErrorFromStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:912720)
at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:940342)
at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:933364)
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1019505
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
at a.makeServerStreamRequest (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:940109)
at a.init (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1004397)
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:769856
at new Promise (<anonymous>)
at v.initInstance (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:769822)
at v.initInstanceWithFallback (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:768678)
at v.create (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:768583)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2024-10-09T14:24:27.932Z root ERROR Uncaught Exception: Error: 14 UNAVAILABLE: read ECONNRESET
2024-10-09T14:24:27.932Z root ERROR Error: 14 UNAVAILABLE: read ECONNRESET
for call at
2024-10-09T14:24:27.932Z daemon INFO time="2024-10-09T16:24:27+02:00" level=warning msg="unable to parse additional URL: ps://raw.githubusercontent.com/espressif/arduino-esp32/gh\x02pages/package_esp32_index.json"
2024-10-09T14:24:27.932Z daemon INFO panic: runtime error: invalid memory address or nil pointer dereference
[signal 0xc0000005 code=0x0 addr=0x8 pc=0x54fd54]
goroutine 40 [running]:
net/url.(*URL).String(0x0)
/usr/local/go/src/net/url/url.go:817 +0x34
github.com/arduino/arduino-cli/commands.(*arduinoCoreServerImpl).UpdateIndex.func1(...)
/home/build/commands/instances.go:536
github.com/arduino/arduino-cli/commands.(*arduinoCoreServerImpl).UpdateIndex(0xc0000090b0, 0xc0001f8740, {0x130b2e0, 0xc000184978})
/home/build/commands/instances.go:564 +0x79e
github.com/arduino/arduino-cli/commands.firstUpdate({0x1306468, 0xc0002de840}, {0x1316708, 0xc0000090b0}, 0xc0002deab0, 0xc000587ab0, 0xc000587610, {0xc00007e7a0, 0x3, 0x4})
/home/build/commands/instances.go:669 +0x437
github.com/arduino/arduino-cli/commands.(*arduinoCoreServerImpl).Init(0xc0000090b0, 0xc0001865a0, {0x130b9c0, 0xc0005875e0})
/home/build/commands/instances.go:193 +0x4e5
github.com/arduino/arduino-cli/rpc/cc/arduino/cli/commands/v1._ArduinoCoreService_Init_Handler({0xf6dd60, 0xc0000090b0}, {0x13094d8, 0xc0002ea000})
/home/build/rpc/cc/arduino/cli/commands/v1/commands_grpc.pb.go:1429 +0x10a
google.golang.org/grpc.(*Server).processStreamingRPC(0xc000470000, {0x1306468, 0xc0002de750}, {0x130d240, 0xc000002000}, 0xc0000ea240, 0xc000124720, 0x1a53c00, 0x0)
/go/pkg/mod/google.golang.org/grpc@v1.65.0/server.go:1673 +0x1208
google.golang.org/grpc.(*Server).handleStream(0xc000470000, {0x130d240, 0xc000002000}, 0xc0000ea240)
/go/pkg/mod/google.golang.org/grpc@v1.65.0/server.go:1794 +0xe3a
google.golang.org/grpc.(*Server).serveStreams.func2.1()
/go/pkg/mod/google.golang.org/grpc@v1.65.0/server.go:1029 +0x8b
created by google.golang.org/grpc.(*Server).serveStreams.func2 in goroutine 51
/go/pkg/mod/google.golang.org/grpc@v1.65.0/server.go:1040 +0x125
2024-10-09T14:24:27.934Z daemon INFO Daemon exited with exit code: 2.
2024-10-09T14:24:28.110Z root INFO Deploy plugins list: 37.3 ms [Finished 1.253 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-10-09T14:24:28.938Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 136.5 ms [Finished 1.499 s after frontend start]
2024-10-09T14:24:28.938Z root WARN A command editor.action.toggleStickyScroll is already registered.
Herewith you receive the output of my Power Shell 7 Hope you can hel me further. Thanks.
