IDE 2.3.3 not open window
Hi.
I trying to open Arduino IDE 2.3.3 but doesn't work. The icon appears, but the window doesn't.
Here is the PowerSheel code:
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.3
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.0.4" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-09-25T09:41:18.242Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3","cliVersion":"1.0.4","buildDate":"2024-09-25T09:41:18.242Z"}
Starting backend process. PID: 8872
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/xxx/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-11-04T18:02:14.564Z root INFO Backend Object.initialize: 6.8 ms [Finished 1.181 s after backend start]
2024-11-04T18:02:14.565Z root INFO Backend Object.configure: 5.5 ms [Finished 1.181 s after backend start]
2024-11-04T18:02:14.565Z root INFO Backend a.onStart: 2.8 ms [Finished 1.182 s after backend start]
2024-11-04T18:02:14.566Z root INFO Backend a.configure: 0.4 ms [Finished 1.219 s after backend start]
2024-11-04T18:02:14.567Z root INFO Backend d.onStart: 0.3 ms [Finished 1.219 s after backend start]
2024-11-04T18:02:14.568Z root INFO Backend d.configure: 0.2 ms [Finished 1.219 s after backend start]
2024-11-04T18:02:14.570Z root INFO Backend d.initialize: 37.2 ms [Finished 1.219 s after backend start]
2024-11-04T18:02:14.570Z root INFO Backend c.onStart: 0.4 ms [Finished 1.219 s after backend start]
2024-11-04T18:02:14.571Z root INFO Backend s.configure: 1.8 ms [Finished 1.221 s after backend start]
2024-11-04T18:02:14.573Z config INFO >>> Initializing CLI configuration...
2024-11-04T18:02:14.574Z root INFO Backend c.initialize: 0.8 ms [Finished 1.222 s after backend start]
2024-11-04T18:02:14.574Z root INFO Backend x.onStart: 1.1 ms [Finished 1.222 s after backend start]
2024-11-04T18:02:14.575Z config INFO Loading CLI configuration from c:\Users\xxx\.arduinoIDE\arduino-cli.yaml...
2024-11-04T18:02:14.576Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-11-04T18:02:14.576Z root INFO Backend s.initialize: 0.7 ms [Finished 1.224 s after backend start]
2024-11-04T18:02:14.576Z root INFO Backend w.onStart: 2.2 ms [Finished 1.226 s after backend start]
2024-11-04T18:02:14.576Z root INFO Backend r.configure: 3.4 ms [Finished 1.226 s after backend start]
2024-11-04T18:02:14.576Z discovery-log INFO start
2024-11-04T18:02:14.576Z discovery-log INFO start new deferred
2024-11-04T18:02:14.576Z root INFO Backend d.initialize: 0.7 ms [Finished 1.227 s after backend start]
2024-11-04T18:02:14.576Z root INFO Backend y.onStart: 3.0 ms [Finished 1.229 s after backend start]
2024-11-04T18:02:14.576Z root INFO Backend r.configure: 2.6 ms [Finished 1.229 s after backend start]
2024-11-04T18:02:14.576Z root INFO Backend s.onStart: 0.7 ms [Finished 1.231 s after backend start]
2024-11-04T18:02:14.576Z root INFO Backend h.configure: 0.6 ms [Finished 1.231 s after backend start]
2024-11-04T18:02:14.576Z root INFO Backend a.configure: 0.3 ms [Finished 1.232 s after backend start]
2024-11-04T18:02:14.576Z root INFO Backend l.configure: 0.1 ms [Finished 1.232 s after backend start]
2024-11-04T18:02:14.581Z root INFO Theia app listening on http://127.0.0.1:65286.
2024-11-04T18:02:14.581Z root INFO Finished starting backend application: 4.7 ms [Finished 1.236 s after backend start]
2024-11-04T18:02:14.582Z root WARN The local plugin referenced by local-dir:/c%3A/Users/xxx/.arduinoIDE/plugins does not exist.
2024-11-04T18:02:14.582Z root WARN The local plugin referenced by local-dir:/c%3A/Users/xxx/.arduinoIDE/extensions does not exist.
2024-11-04T18:02:14.582Z root WARN The local plugin referenced by local-dir:C:\Users\xxx\.arduinoIDE\plugins does not exist.
Restoring workspace roots: c:\Users\xxx\Documents\Arduino\libraries\IRremote\examples\SendDemo
isTempSketch: false. Input was c:\Users\xxx\Documents\Arduino\libraries\IRremote\examples\SendDemo\SendDemo.ino
2024-11-04T18:02:14.608Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2024-11-04T18:02:14.608Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'
2024-11-04T18:02:14.657Z root INFO Resolve plugins list: 82.2 ms [Finished 1.312 s after backend start]
2024-11-04T18:02:15.303Z daemon INFO time="2024-11-04T15:02:15-03:00" level=info msg="arduino-cli version 1.0.4"
time="2024-11-04T15:02:15-03:00" level=info msg="Using config file: c:\\Users\\xxx\\.arduinoIDE\\arduino-cli.yaml"
time="2024-11-04T15:02:15-03:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:65287
{"IP":"127.0.0.1","Port":"65287"}
2024-11-04T18:02:15.303Z daemon INFO Daemon is running.
2024-11-04T18:02:15.315Z config INFO Loaded fallback CLI configuration: {"directories":{"user":"C:\\Users\\xxx\\Documents\\Arduino","data":"C:\\Users\\xxx\\AppData\\Local\\Arduino15"}}
2024-11-04T18:02:15.315Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":"C:\\Users\\xxx\\Documents\\Arduino","data":"C:\\Users\\xxx\\AppData\\Local\\Arduino15"},"board_manager":{"additional_urls":[]}}
2024-11-04T18:02:15.315Z config INFO Loaded the CLI configuration.
2024-11-04T18:02:15.325Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/xxx/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/xxx/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-11-04T18:02:15.325Z config INFO Validating the CLI configuration...
2024-11-04T18:02:15.341Z config INFO The CLI config is valid.
2024-11-04T18:02:15.341Z config INFO <<< Initialized the CLI configuration.
2024-11-04T18:02:15.416Z daemon INFO time="2024-11-04T15:02:15-03:00" level=info msg="Checking signature" index="C:\\Users\\xxx\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\xxx\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2024-11-04T15:02:15-03:00" level=info msg="Loading hardware from: C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages"
time="2024-11-04T15:02:15-03:00" level=info msg="Loading package arduino from: C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2024-11-04T15:02:15-03:00" level=info msg="Missing signature file" index="C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
time="2024-11-04T15:02:15-03:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-11-04T15:02:15-03:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-11-04T15:02:15-03:00" level=info msg="Loaded platform" platform="arduino:sam@1.6.12"
time="2024-11-04T15:02:15-03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-11-04T15:02:15-03:00" level=info msg="Loading tools from dir: C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-11-04T15:02:15-03:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2024-11-04T15:02:15-03:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@4.8.3-2014q1"
time="2024-11-04T15:02:15-03:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-11-04T15:02:15-03:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-11-04T15:02:15-03:00" level=info msg="Loaded tool" tool="arduino:bossac@1.6.1-arduino"
time="2024-11-04T15:02:15-03:00" level=info msg="Loading package builtin from: C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2024-11-04T15:02:15-03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-11-04T15:02:15-03:00" level=info msg="Loading tools from dir: C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-11-04T15:02:15-03:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-11-04T15:02:15-03:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-11-04T15:02:15-03:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-11-04T15:02:15-03:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2024-11-04T15:02:15-03:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2024-11-04T15:02:15-03:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2024-11-04T15:02:15-03:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-11-04T18:02:15.426Z daemon INFO time="2024-11-04T15:02:15-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\libraries" isSingleLibrary=false location=platform
2024-11-04T18:02:15.448Z daemon INFO time="2024-11-04T15:02:15-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
time="2024-11-04T15:02:15-03:00" level=info msg="Loading libraries index file" index="C:\\Users\\xxx\\AppData\\Local\\Arduino15\\library_index.json"
2024-11-04T18:02:15.777Z daemon INFO time="2024-11-04T15:02:15-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\xxx\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2024-11-04T15:02:15-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\xxx\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2024-11-04T18:02:16.268Z root INFO Deploy plugins list: 82.2 ms [Finished 2.923 s after backend start]
2024-11-04T18:02:16.422Z discovery-log INFO start resolved watching
2024-11-04T18:02:16.596Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM3","label":"COM3","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-11-04T18:02:16.598Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM6","label":"COM6","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-11-04T18:02:16.598Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM5","label":"COM5","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-11-04T18:02:16.599Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM4","label":"COM4","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-11-04T18:02:17.960Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 337.5 ms [Finished 3.232 s after frontend start]
2024-11-04T18:02:17.960Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-11-04T18:02:18.151Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\xxx\Documents\Arduino\libraries\IRremote\examples\SendDemo\SendDemo.ino>, response: <c:\Users\xxx\Documents\Arduino\libraries\IRremote\examples\SendDemo>.
2024-11-04T18:02:18.308Z root WARN Frontend c.onStart took longer than the expected maximum 100 milliseconds: 112.0 ms [Finished 3.656 s after frontend start]
2024-11-04T18:02:18.373Z root INFO Start frontend contributions: 951.7 ms [Finished 3.675 s after frontend start]
2024-11-04T18:02:18.373Z root INFO Changed application state from 'init' to 'started_contributions'.
2024-11-04T18:02:18.430Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2024-11-04T18:02:18.431Z root INFO >>> Restoring the layout state...
2024-11-04T18:02:18.433Z root INFO ------- SERIALIZED LAYOUT DATA -------
2024-11-04T18:02:18.434Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/xxx/Documents/Arduino/libraries/IRremote/examples/SendDemo/SendDemo.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":43,\"column\":1},\"firstPositionDeltaTop\":-2},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":430,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/xxx/Documents/Arduino/libraries/IRremote/examples/SendDemo/PinDefinitionsAndMore.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":323,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false,false],"bottomPanel":{"config":{"main":null},"pinned":[],"expanded":false},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]}}
2024-11-04T18:02:18.434Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2024-11-04T18:02:18.536Z root INFO [4dfdfc91-1cf8-416d-8230-7d6c3c49954b] Waiting for backend deployment: 222.7 ms [Finished 3.883 s after frontend start]
2024-11-04T18:02:19.921Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264) starting instance
2024-11-04T18:02:21.244Z root INFO [4dfdfc91-1cf8-416d-8230-7d6c3c49954b] Sync of 23 plugins: 2710.9 ms [Finished 6.594 s after frontend start]
2024-11-04T18:02:21.739Z root INFO <<< The layout has been successfully restored.
2024-11-04T18:02:21.950Z root INFO Initialize the workbench layout: 3333.8 ms [Finished 7.090 s after frontend start]
2024-11-04T18:02:21.954Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2024-11-04T18:02:21.955Z root INFO [4dfdfc91-1cf8-416d-8230-7d6c3c49954b] Loading plugin contributions
2024-11-04T18:02:21.956Z root INFO [4dfdfc91-1cf8-416d-8230-7d6c3c49954b] Load contributions of 23 plugins: 205.0 ms [Finished 7.297 s after frontend start]
2024-11-04T18:02:22.072Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2024-11-04T18:02:22.073Z root WARN a registered grammar configuration for 'cpp' language is overridden
2024-11-04T18:02:23.195Z root INFO Frontend application start: 5334.3 ms [Finished 9.849 s after backend start]
Checking for update
2024-11-04T18:02:23.236Z root INFO Replace loading indicator with ready workbench UI (animation): 919.4 ms [Finished 8.223 s after frontend start]
2024-11-04T18:02:23.237Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2024-11-04T18:02:23.243Z root WARN Linked preference "workbench.colorCustomizations" not found.
Update for version 2.3.3 is not available (latest version: 2.3.3, downgrade is allowed).
2024-11-04T18:02:23.646Z root ERROR [hosted-plugin: 5264] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
2024-11-04T18:02:23.646Z root ERROR [hosted-plugin: 5264] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
2024-11-04T18:02:23.646Z root ERROR [hosted-plugin: 5264] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2024-11-04T18:02:24.029Z root ERROR ---- !!!SLOW!!! DURATION: search took 786.090 ms. Args: [{"type":"Updatable"}] ----
2024-11-04T18:02:24.038Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): PluginManagerExtImpl/init()
2024-11-04T18:02:24.041Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-arduino-api@0.1.2 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.042Z daemon INFO time="2024-11-04T15:02:24-03:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
time="2024-11-04T15:02:24-03:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2024-11-04T18:02:24.043Z daemon INFO time="2024-11-04T15:02:24-03:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-11-04T15:02:24-03:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
time="2024-11-04T15:02:24-03:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
time="2024-11-04T15:02:24-03:00" level=info msg="Tool required for debug" tool="arduino:arm-none-eabi-gcc@4.8.3-2014q1"
2024-11-04T18:02:24.043Z daemon INFO time="2024-11-04T15:02:24-03:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
time="2024-11-04T15:02:24-03:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
2024-11-04T18:02:24.043Z daemon INFO time="2024-11-04T15:02:24-03:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.14.1"
2024-11-04T18:02:24.043Z daemon INFO time="2024-11-04T15:02:24-03:00" level=info msg="Tool required for debug" tool="arduino:bossac@1.6.1-arduino"
2024-11-04T18:02:24.045Z root ERROR Failed to get debug config: arduino:avr:mega:cpu=atmega2560, undefined Error: Debugging is not supported.
    at Object.callback (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:82356)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:937970)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:933919)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:933364)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1019505
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
2024-11-04T18:02:24.045Z root ERROR Request checkDebugEnabled failed with error: Debugging is not supported. Error: Debugging is not supported.
2024-11-04T18:02:24.159Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(cortex-debug@1.5.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.159Z root INFO [hosted-plugin: 5264] Debugger contribution has been registered: cortex-debug
2024-11-04T18:02:24.161Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-arduino-tools@0.1.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.163Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(cpp@1.52.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.164Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(json@1.46.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.165Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(json-language-features@1.46.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.167Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.168Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-cs@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.200Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-de@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.202Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-es@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.204Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-fr@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.216Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.217Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-it@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.218Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-ja@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.219Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-ko@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.220Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.223Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-pl@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.224Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-pt-BR@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.226Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-ru@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.227Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-tr@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.231Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-uk@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.232Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-zh-hans@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.233Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): initializing(vscode-language-pack-zh-hant@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-11-04T18:02:24.256Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2024-11-04T18:02:24.266Z root INFO [hosted-plugin: 5264] calling activation function on Arduino IDE API for VS Code extensions
2024-11-04T18:02:24.277Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2024-11-04T18:02:24.374Z root INFO [hosted-plugin: 5264] calling activation function on JSON Language Features (built-in)
2024-11-04T18:02:24.435Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\extension.js)
2024-11-04T18:02:24.492Z root INFO [hosted-plugin: 5264] calling activation function on VS Code Arduino Tools
2024-11-04T18:02:24.549Z root INFO [4dfdfc91-1cf8-416d-8230-7d6c3c49954b] Starting plugins.
2024-11-04T18:02:24.559Z root INFO [hosted-plugin: 5264] PLUGIN_HOST(5264): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2024-11-04T18:02:24.638Z root INFO [hosted-plugin: 5264] Debug configuration provider has been registered: cortex-debug, trigger: 1
2024-11-04T18:02:24.639Z root INFO [hosted-plugin: 5264] calling activation function on Cortex-Debug
2024-11-04T18:02:24.649Z root INFO [hosted-plugin: 5264] GDB server console created
2024-11-04T18:02:24.660Z root INFO [4dfdfc91-1cf8-416d-8230-7d6c3c49954b] Start of 23 plugins: 2698.3 ms [Finished 10.008 s after frontend start]
2024-11-04T18:02:24.698Z root INFO Starting language server: arduino:avr:mega:cpu=atmega2560
2024-11-04T18:02:24.866Z fwuploader ERROR Error: Process exited with exit code: 1
    at ChildProcess.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:788453)
    at ChildProcess.emit (node:events:514:28)
    at Process.onexit (node:internal/child_process:291:12)
2024-11-04T18:02:24.866Z root ERROR Request updatableBoards failed with error: Process exited with exit code: 1 Error: Process exited with exit code: 1
2024-11-04T18:02:25.021Z daemon INFO time="2024-11-04T15:02:25-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\xxx\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2024-11-04T15:02:25-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
time="2024-11-04T15:02:25-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\xxx\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2024-11-04T18:02:26.126Z daemon INFO time="2024-11-04T15:02:26-03:00" level=info msg="Resolving include IRremote.hpp for arch avr"
time="2024-11-04T15:02:26-03:00" level=info msg="  found better lib" lib=IRremote prio=6B1
2024-11-04T18:02:27.739Z daemon INFO time="2024-11-04T15:02:27-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\xxx\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2024-11-04T18:02:27.739Z daemon INFO time="2024-11-04T15:02:27-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
2024-11-04T18:02:27.740Z daemon INFO time="2024-11-04T15:02:27-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\xxx\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
You have flagged this topic as solved by yourself
For the benefit of others, please explain what the problem was and how you solved it
