type or paste code here
```` at readableAddChunk (node:internal/streams/readable:297:9)
at Socket.push (node:internal/streams/readable:234:10)
at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
2025-01-04T02:51:04.157Z daemon INFO Starting daemon from V:\arduino-ide_2.3.4_Windows_64bit\resources\app\lib\backend\resources\arduino-cli.exe...
2025-01-04T02:51:05.302Z daemon INFO time="2025-01-03T21:51:05-05:00" level=info msg="arduino-cli version 1.1.1"
2025-01-04T02:51:05.303Z daemon INFO time="2025-01-03T21:51:05-05:00" level=info msg="Using config file: c:\\Users\\tyler\\.arduinoIDE\\arduino-cli.yaml"
2025-01-04T02:51:05.303Z daemon INFO time="2025-01-03T21:51:05-05:00" level=info msg="Executing `arduino-cli daemon`"
2025-01-04T02:51:05.305Z daemon INFO Daemon is now listening on 127.0.0.1:58659
{"IP":"127.0.0.1","Port":"58659"}
2025-01-04T02:51:05.548Z daemon INFO fatal error: out of memory allocating heap arena map
2025-01-04T02:51:05.548Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
at Socket.<anonymous> (V:\arduino-ide_2.3.4_Windows_64bit\resources\app\lib\backend\main.js:2:44411)
at Socket.emit (node:events:514:28)
at addChunk (node:internal/streams/readable:324:12)
2025-01-04T02:51:05.548Z daemon INFO Starting daemon from V:\arduino-ide_2.3.4_Windows_64bit\resources\app\lib\backend\resources\arduino-cli.exe...
2025-01-04T02:51:05.924Z daemon INFO runtime stack:
runtime.throw({0x188b43c?, 0x0?})
/usr/local/go/src/runtime/panic.go:1023 +0x65 fp=0x8b75ff850 sp=0x8b75ff820 pc=0xd2d265
runtime.(*mheap).sysAlloc(0x23a2e20, 0x3000?, 0x23b3220, 0x1)
/usr/local/go/src/runtime/malloc.go:760 +0x3e9 fp=0x8b75ff908 sp=0x8b75ff850 pc=0xd00f29
runtime.(*mheap).grow(0x23a2e20, 0x2000?)
/usr/local/go/src/runtime/mheap.go:1484 +0x76 fp=0x8b75ff988 sp=0x8b75ff908 pc=0xd1e4b6
runtime.(*mheap).allocSpan(0x23a2e20, 0x1, 0x0, 0x1c)
/usr/local/go/src/runtime/mheap.go:1246 +0x1b0 fp=0x8b75ffa28 sp=0x8b75ff988 pc=0xd1dd50
runtime.(*mheap).alloc.func1()
/usr/local/go/src/runtime/mheap.go:964 +0x5c fp=0x8b75ffa70 sp=0x8b75ffa28 pc=0xd1d7dc
runtime.(*mheap).alloc(0x10?, 0x8b75ffae8?, 0x81?)
/usr/local/go/src/runtime/mheap.go:958 +0x5b fp=0x8b75ffab8 sp=0x8b75ffa70 pc=0xd1d73b
runtime.(*mcentral).grow(0xd621c0?)
/usr/local/go/src/runtime/mcentral.go:254 +0x52 fp=0x8b75ffaf8 sp=0x8b75ffab8 pc=0xd0b312
runtime.(*mcentral).cacheSpan(0x23b47a0)
/usr/local/go/src/runtime/mcentral.go:170 +0x418 fp=0x8b75ffb70 sp=0x8b75ffaf8 pc=0xd0b178
runtime.(*mcache).refill(0x12ed3aa0108, 0xb8?)
/usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x8b75ffbb0 sp=0x8b75ffb70 pc=0xd0a793
runtime.(*mcache).nextFree(0x12ed3aa0108, 0x1c)
/usr/local/go/src/runtime/malloc.go:948 +0x85 fp=0x8b75ffbe8 sp=0x8b75ffbb0 pc=0xd01565
runtime.mallocgc(0xc0, 0x16d49a0, 0x1)
/usr/local/go/src/runtime/malloc.go:1149 +0x4a5 fp=0x8b75ffc70 sp=0x8b75ffbe8 pc=0xd01b85
runtime.newobject(0x8b75ffcd0?)
/usr/local/go/src/runtime/malloc.go:1390 +0x25 fp=0x8b75ffc98 sp=0x8b75ffc70 pc=0xd02125
internal/cpu.doinit()
/usr/local/go/src/internal/cpu/cpu_x86.go:54 +0x1e fp=0x8b75ffcf8 sp=0x8b75ffc98 pc=0xcf515e
internal/cpu.Initialize({0x0, 0x0})
/usr/local/go/src/internal/cpu/cpu.go:129 +0x1d fp=0x8b75ffd18 sp=0x8b75ffcf8 pc=0xcf4bbd
runtime.cpuinit(...)
/usr/local/go/src/runtime/proc.go:695
runtime.schedinit()
/usr/local/go/src/runtime/proc.go:788 +0xc5 fp=0x8b75ffd50 sp=0x8b75ffd18 pc=0xd30aa5
runtime.rt0_go()
/usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x8b75ffd58 sp=0x8b75ffd50 pc=0xd5e89c
2025-01-04T02:51:05.924Z daemon INFO Daemon exited with exit code: 2.
2025-01-04T02:51:06.950Z daemon INFO fatal error: out of memory allocating heap arena map
2025-01-04T02:51:06.951Z daemon ERROR Error: fatal error: out of memory allocating heap arena map
2025-01-04T02:51:06.951Z daemon INFO Starting daemon from V:\arduino-ide_2.3.4_Windows_64bit\resources\app\lib\backend\resources\arduino-cli.exe...
2025-01-04T02:51:08.679Z daemon ERROR Error: spawn UNKNOWN
at ChildProcess.spawn (node:internal/child_process:413:11)
at spawn (node:child_process:783:9)
at w.spawnDaemonProcess (V:\arduino-ide_2.3.4_Windows_64bit\resources\app\lib\backend\main.js:2:43854)
at async w.start (V:\arduino-ide_2.3.4_Windows_64bit\resources\app\lib\backend\main.js:2:42651)
at async t.retry (V:\arduino-ide_2.3.4_Windows_64bit\resources\app\lib\backend\main.js:2:1286619)
2025-01-04T02:51:08.679Z daemon INFO Starting daemon from V:\arduino-ide_2.3.4_Windows_64bit\resources\app\lib\backend\resources\arduino-cli.exe...
2025-01-04T02:51:08.679Z daemon INFO runtime stack:
/usr/local/go/src/runtime/panic.go:1023 +0x65 fp=0x350c7ff950 sp=0x350c7ff920 pc=0xd2d265
/usr/local/go/src/runtime/malloc.go:760 +0x3e9 fp=0x350c7ffa08 sp=0x350c7ff950 pc=0xd00f29
/usr/local/go/src/runtime/mheap.go:1484 +0x76 fp=0x350c7ffa88 sp=0x350c7ffa08 pc=0xd1e4b6
/usr/local/go/src/runtime/mheap.go:1246 +0x1b0 fp=0x350c7ffb28 sp=0x350c7ffa88 pc=0xd1dd50
/usr/local/go/src/runtime/mheap.go:964 +0x5c fp=0x350c7ffb70 sp=0x350c7ffb28 pc=0xd1d7dc
runtime.(*mheap).alloc(0x10?, 0x350c7ffbe8?, 0x81?)
/usr/local/go/src/runtime/mheap.go:958 +0x5b fp=0x350c7ffbb8 sp=0x350c7ffb70 pc=0xd1d73b
/usr/local/go/src/runtime/mcentral.go:254 +0x52 fp=0x350c7ffbf8 sp=0x350c7ffbb8 pc=0xd0b312
/usr/local/go/src/runtime/mcentral.go:170 +0x418 fp=0x350c7ffc70 sp=0x350c7ffbf8 pc=0xd0b178
runtime.(*mcache).refill(0x22ee5b00108, 0xb8?)
/usr/local/go/src/runtime/mcache.go:182 +0x153 fp=0x350c7ffcb0 sp=0x350c7ffc70 pc=0xd0a793
runtime.(*mcache).nextFree(0x22ee5b00108, 0x1c)
/usr/local/go/src/runtime/malloc.go:948 +0x85 fp=0x350c7ffce8 sp=0x350c7ffcb0 pc=0xd01565
/usr/local/go/src/runtime/malloc.go:1149 +0x4a5 fp=0x350c7ffd70 sp=0x350c7ffce8 pc=0xd01b85
runtime.newobject(0x350c7ffdd0?)
/usr/local/go/src/runtime/malloc.go:1390 +0x25 fp=0x350c7ffd98 sp=0x350c7ffd70 pc=0xd02125
/usr/local/go/src/internal/cpu/cpu_x86.go:54 +0x1e fp=0x350c7ffdf8 sp=0x350c7ffd98 pc=0xcf515e
/usr/local/go/src/internal/cpu/cpu.go:129 +0x1d fp=0x350c7ffe18 sp=0x350c7ffdf8 pc=0xcf4bbd
runtime.schedinit()
/usr/local/go/src/runtime/proc.go:788 +0xc5 fp=0x350c7ffe50 sp=0x350c7ffe18 pc=0xd30aa5
runtime.rt0_go()
/usr/local/go/src/runtime/asm_amd64.s:349 +0x13c fp=0x350c7ffe58 sp=0x350c7ffe50 pc=0xd5e89c
2025-01-04T02:51:08.679Z daemon INFO Daemon exited with exit code: 2.
2025-01-04T02:51:09.923Z daemon ERROR Error: spawn UNKNOWN
2025-01-04T02:51:09.923Z daemon INFO Starting daemon from V:\arduino-ide_2.3.4_Windows_64bit\resources\app\lib\backend\resources\arduino-cli.exe...
2025-01-04T02:51:12.204Z daemon ERROR Error: spawn UNKNOWN
2025-01-04T02:51:12.204Z daemon INFO Starting daemon from V:\arduino-ide_2.3.4_Windows_64bit\resources\app\lib\backend\resources\arduino-cli.exe...
2025-01-04T02:51:13.592Z daemon ERROR Error: spawn UNKNOWN
2025-01-04T02:51:13.592Z daemon INFO Starting daemon from V:\arduino-ide_2.3.4_Windows_64bit\resources\app\lib\backend\resources\arduino-cli.exe...
2025-01-04T02:51:14.855Z daemon ERROR Error: spawn UNKNOWN
2025-01-04T02:51:14.855Z daemon INFO Starting daemon from V:\arduino-ide_2.3.4_Windows_64bit\resources\app\lib\backend\resources\arduino-cli.exe...
2025-01-04T02:51:17.068Z daemon ERROR Error: spawn UNKNOWN
2025-01-04T02:51:17.068Z daemon INFO Starting daemon from V:\arduino-ide_2.3.4_Windows_64bit\resources\app\lib\backend\resources\arduino-cli.exe...
2025-01-04T02:51:19.467Z daemon INFO Daemon exited with exit code: 3221225794.
Closing channel on service path '/services/electron-window'.
Closing channel on service path '/services/ide-updater'.
Stored workspaces roots:
No sketches were scheduled for deletion.
The error message says you are out of memory. You need to provide more information.
