Hi All, I’m running IDE 2.3.6 on Win-10, AMD Ryzen 5 1400 quad core processor, Nvidia GeForce GT710, feeding 40” LG tv as Monitor 1360x768 landscape mode. 2nd monitor Element tv, 1366x768 landscape inverted. (monitor is mounted upside down, attached to underside of shelf.
Issue, when IDE is in window mode, not full screen, the vertical size is too tall and exceeds the display height of my monitor, and I cannot resize it small enough. Like the program is adding 1 text line to my display vertical size. It is ok in full screen mode, but I don’t want the ide hogging the entire screen.
Is there a fix or setting I can adjust, or is it hard coded into the IDE?
Welcome to the forum
What is stopping you resizing the window ? Can you not grab the border and resize it ?
That’s it exactly, when I grab the border, it will not resize below my screen height plus 1 row. In fact the window when I initially open it will be at the correct height, but if I move the window left or right, then it auto-expands the height, and cannot be resized small enough again.
Does it work if you move or resize it using the keyboard. Start by pressing Alt + spacebar
Try clicking in the IDE window then hold the control key down and rotate the mouse wheel. Then try resizing the window after its contents are reduced. That works on Linux, not sure about windoz.
Thanks for the suggestion, but it did not work for Win-10.
Sorry. I would guess there is a problem with one of the window drivers.
It gives me a popup menu, I can move it around, but will not size it any smaller.
