IDE doesn't let me use a "for" loop
my sketch has a "for" repeating loop as follows:
  for (int p = 0; p < 21; p++){        // 21 pulses at ~37 KHz
    digitalWrite(9, HIGH);
    delayMicroseconds(9);
    digitalWrite(9, LOW);
    delayMicroseconds(9);}
No matter what I try, IDE stops compiling on that line with the error message:
"Expected initializer before 'for'. It doesn't help that I haven't the slightest idea what an initializer is.
One possible reason is the additional } at the end of the presented code. Another reason is that the error is somewhere else. But nobody will be able to tell you without seeing the complete code.
This happily compiles
  for (int p = 0; p < 21; p++) {       // 21 pulses at ~37 KHz
The problem is with the code that was not posted.
Not this time.  The given snippet pasted into a bare minimum sketch, and with <ctrl> T applied gives an error of
The correct formatting easily shows the dangling curly brace noted by @sterretje at the end of the sketch.  Remove the offending brace and the sketch compiles.
GIGO, circa 1957
"Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?" ... I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
Charles Babbage
The answer is always 42 ! :slight_smile:
OK, here's the sketch minimized to just the portion that transmits an IR signal each time a trigger signal is detected at D3. It loads and runs perfectly, even with what appears to be a dangling curly bracket at the end. Before I integrate this into my application for it I'm hoping someone can show me how to reduce the code from the two functions I'm now using ('zerobit' and 'onebit") by putting the 32 data bits into an array of "1"s and "0"s and using one of those tricky "for" loops to ripple thru the array and transmit the bits in sequence.
// Samsung_MUTE_Signal_Generator_Minimum_07-24-2022
  pinMode(3, INPUT);                  // HIGH on this pin triggers xmission
  pinMode(9, OUTPUT);                 // pin 9 drives IR LED xmitter
void loop()  {
  while (digitalRead(3) == LOW) {}    // wait for start signal to go high
  for (int p = 0; p < 171; p++) {     // xmit carrier burst of lead-in
  delayMicroseconds(4500);            // OFF time of lead-in
  onebit();                           // xmit 32 data bits of IR signal
  onebit();
  onebit();
  zerobit();
  zerobit();
  zerobit();
  zerobit();
  zerobit();
  onebit();
  onebit();
  onebit();
  zerobit();
  zerobit();
  zerobit();
  zerobit();
  zerobit();
  onebit();
  onebit();
  onebit();
  onebit();
  zerobit();
  zerobit();
  zerobit();
  zerobit();
  zerobit();
  zerobit();
  zerobit();
  zerobit();
  onebit();
  onebit();
  onebit();
  onebit();
  onebit();
  while (digitalRead(3) == HIGH) {}   // wait for D3 to return low
void zerobit() {                      // function to xmit "0" bit
  for (int p = 0; p < 21; p++){       // 21 cycles of 37 KHz carrier
    delayMicroseconds(590);           // 590 uSec low = "0" bit
void onebit() {                       // function to xmit "1" bit
    delayMicroseconds(1690);          // 1690 uSec low = "1" bit
I should mention, I tried making functions called simply "0" and "1" but IDE said NO.
2 closing brackets instead of 1 maybe
Do you realize you are transmitting 33 bits?
Do you mean to send 1 11110000 00001111 00000111 00000111?
No C/C++ identifier can begin with a numeral.
Not that you should use an obfuscated name like that anyway...
I like to use "num0" and "num1"
@OLDokasional
can you pls clarify if you need to send 32bit or 33 bit?
  //   fedcba9876543210fedcba9876543210
  //0b111110000000011110000011100000111
for 32bit something like this could do work:
  //0b111110000000011110000011100000111  // based on the original sketch
  // 0b11110000000011110000011100000111  // but only used 32 bit in this sketch
  const uint32_t data = 0b11110000000011110000011100000111;
void loop()  {
  sendLSBfirst(data);
void sendLSBfirst(uint32_t content)
  for (byte i = 0; i < 32; i++)
    if (content & 1UL << i)
      onebit();
      //Serial.print('1');   // debug only
      zerobit();
      //Serial.print('0');  // debug only
  //Serial.println();       // debug only
void anybit(uint16_t us)
    for (int p = 0; p < 21; p++) {      // 21 cycles of 37 KHz carrier
  delayMicroseconds(us);
  anybit(590);
  anybit(1690);
only tested with wokwi:
noiasca, your sketch loads and runs just fine, but your encoding is off, probably because of the 32/33 bit mixup. See attached comparison between your signal and mine. I tried messing with that 32 bit code string at start of your sketch, but nothing I tried worked.
Note that at the far right end my signal ends with four "1" bits, and the next burst is just to get back to baseline. Your signal ends with just three"1" bits. I don't know if that's the only way to end it, but I did what was necessary to make my signal look exactly like one from a Samsung OEM remote control. I'll try anything you send me.
@OLDokasional sorry, haven't seen your post.
So if you need 33 bytes you could switch over to a 64 bit variable.
may be the update helps:
sendBitmapData.ino - Wokwi Arduino and ESP32 Simulator
Babbage died in 1871 - did you mean 'circa 1857'?
Oops... : # No, wait... 1957 is the advent of "GIGO" which Mr. Babbage, PBUH, would be disappointed.
