PS C:\Users\stefa\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.2.1
Checking for frontend application configuration customizations. Module path: C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.2.1" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.34.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2023-08-31T14:35:44.802Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.2.1","cliVersion":"0.34.0","buildDate":"2023-08-31T14:35:44.802Z"}
Starting backend process. PID: 11548
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/stefa/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-12-18T09:01:22.288Z root INFO Backend Object.initialize: 4.5 ms [Finished 0.442 s after backend start]
2023-12-18T09:01:22.288Z root INFO Backend Object.configure: 3.8 ms [Finished 0.442 s after backend start]
2023-12-18T09:01:22.289Z root INFO Backend a.onStart: 1.6 ms [Finished 0.442 s after backend start]
2023-12-18T09:01:22.289Z root INFO Backend a.configure: 0.3 ms [Finished 0.466 s after backend start]
2023-12-18T09:01:22.290Z root INFO Backend u.onStart: 0.2 ms [Finished 0.466 s after backend start]
2023-12-18T09:01:22.291Z root INFO Backend d.configure: 0.1 ms [Finished 0.466 s after backend start]
2023-12-18T09:01:22.292Z root INFO Backend d.initialize: 23.9 ms [Finished 0.466 s after backend start]
2023-12-18T09:01:22.292Z root INFO Backend c.onStart: 0.2 ms [Finished 0.466 s after backend start]
2023-12-18T09:01:22.293Z root INFO Backend s.configure: 1.6 ms [Finished 0.468 s after backend start]
2023-12-18T09:01:22.294Z config INFO >>> Initializing CLI configuration...
2023-12-18T09:01:22.294Z root INFO Backend c.initialize: 0.4 ms [Finished 0.468 s after backend start]
2023-12-18T09:01:22.295Z root INFO Backend P.onStart: 0.8 ms [Finished 0.469 s after backend start]
2023-12-18T09:01:22.295Z config INFO Loading CLI configuration from c:\Users\stefa\.arduinoIDE\arduino-cli.yaml...
2023-12-18T09:01:22.296Z daemon INFO Starting daemon from C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-12-18T09:01:22.296Z root INFO Backend s.initialize: 0.3 ms [Finished 0.470 s after backend start]
2023-12-18T09:01:22.296Z root INFO Backend w.onStart: 1.1 ms [Finished 0.471 s after backend start]
2023-12-18T09:01:22.296Z root INFO Backend r.configure: 2.0 ms [Finished 0.471 s after backend start]
2023-12-18T09:01:22.297Z discovery-log INFO start
2023-12-18T09:01:22.297Z discovery-log INFO start new deferred
2023-12-18T09:01:22.297Z root INFO Backend d.initialize: 0.3 ms [Finished 0.472 s after backend start]
2023-12-18T09:01:22.297Z root INFO Backend y.onStart: 1.9 ms [Finished 0.473 s after backend start]
2023-12-18T09:01:22.297Z root INFO Backend r.configure: 1.8 ms [Finished 0.474 s after backend start]
2023-12-18T09:01:22.298Z root INFO Backend s.onStart: 0.6 ms [Finished 0.475 s after backend start]
2023-12-18T09:01:22.298Z root INFO Backend h.configure: 0.7 ms [Finished 0.475 s after backend start]
2023-12-18T09:01:22.298Z root INFO Backend a.configure: 0.6 ms [Finished 0.476 s after backend start]
2023-12-18T09:01:22.298Z root INFO Backend s.configure: 0.1 ms [Finished 0.477 s after backend start]
2023-12-18T09:01:22.299Z root INFO Backend l.configure: 0.1 ms [Finished 0.477 s after backend start]
2023-12-18T09:01:22.303Z root INFO Theia app listening on http://localhost:56487.
2023-12-18T09:01:22.304Z root INFO Finished starting backend application: 6.6 ms [Finished 0.482 s after backend start]
2023-12-18T09:01:22.305Z root WARN The local plugin referenced by local-dir:/c%3A/Users/stefa/.arduinoIDE/plugins does not exist.
2023-12-18T09:01:22.305Z root WARN The local plugin referenced by local-dir:/c%3A/Users/stefa/.arduinoIDE/extensions does not exist.
2023-12-18T09:01:22.306Z root WARN The local plugin referenced by local-dir:C:\Users\stefa\.arduinoIDE\plugins does not exist.
Restoring workspace roots: c:\Users\stefa\Prog\Arduino\Testen\ADXL335_Good_Code
isTempSketch: false. Input was c:\Users\stefa\Prog\Arduino\Testen\ADXL335_Good_Code\ADXL335_Good_Code.ino
2023-12-18T09:01:22.350Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["https://dl.espressif.com/dl/package_esp32_index.json"]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\stefa\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\stefa\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\stefa\\AppData\\Local\\Arduino15\\staging","user":"c:\\Users\\stefa\\OneDrive\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-12-18T09:01:22.351Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-12-18T09:01:22.355Z config INFO Loaded the CLI configuration.
2023-12-18T09:01:22.383Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/stefa/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/stefa/OneDrive/Documents/Arduino","additionalUrls":["https://dl.espressif.com/dl/package_esp32_index.json"],"network":"none","locale":"en"}
2023-12-18T09:01:22.384Z config INFO Validating the CLI configuration...
2023-12-18T09:01:22.390Z config INFO The CLI config is valid.
2023-12-18T09:01:22.391Z config INFO <<< Initialized the CLI configuration.
2023-12-18T09:01:22.438Z root INFO Resolve plugins list: 141.2 ms [Finished 0.615 s after backend start]
2023-12-18T09:01:22.630Z daemon INFO time="2023-12-18T10:01:22+01:00" level=info msg="Using config file: c:\\Users\\stefa\\.arduinoIDE\\arduino-cli.yaml"
time="2023-12-18T10:01:22+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-12-18T10:01:22+01:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:56488
{"IP":"127.0.0.1","Port":"56488"}
2023-12-18T09:01:22.631Z daemon INFO Daemon is running.
2023-12-18T09:01:22.789Z daemon INFO time="2023-12-18T10:01:22+01:00" level=info msg="Checking signature" index="c:\\Users\\stefa\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\stefa\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2023-12-18T10:01:22+01:00" level=info msg="Missing signature file" index="c:\\Users\\stefa\\AppData\\Local\\Arduino15\\package_esp32_index.json"
time="2023-12-18T10:01:22+01:00" level=info msg="Loading hardware from: c:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages"
time="2023-12-18T10:01:22+01:00" level=info msg="Loading package CONTROLLINO_Boards from: C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\CONTROLLINO_Boards\\hardware"
time="2023-12-18T10:01:22+01:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded platform" platform="CONTROLLINO_Boards:avr@3.1.0"
time="2023-12-18T10:01:22+01:00" level=info msg="Loading package arduino from: C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2023-12-18T10:01:22+01:00" level=info msg="Missing signature file" index="C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2023-12-18T10:01:22+01:00" level=info msg="Missing signature file" index="C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.13\\installed.json"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded platform" platform="arduino:esp32@2.0.13"
time="2023-12-18T10:01:22+01:00" level=info msg="Missing signature file" index="C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\installed.json"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded platform" platform="arduino:mbed@3.3.0"
time="2023-12-18T10:01:22+01:00" level=info msg="Missing signature file" index="C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\4.0.10\\installed.json"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded platform" platform="arduino:mbed_nano@4.0.10"
time="2023-12-18T10:01:22+01:00" level=info msg="Missing signature file" index="C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\installed.json"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded platform" platform="arduino:megaavr@1.8.8"
time="2023-12-18T10:01:22+01:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2023-12-18T10:01:22+01:00" level=info msg="Loading tools from dir: C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino5"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino8"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="arduino:bossac@1.9.1-arduino2"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.10.0-arduino1"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="arduino:imgtool@1.8.0-arduino.2"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="arduino:openocd@0.11.0-arduino2"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="arduino:rp2040tools@1.0.6"
time="2023-12-18T10:01:22+01:00" level=info msg="Loading package atmel-avr-xminis from: C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\atmel-avr-xminis\\hardware"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded platform" platform="atmel-avr-xminis:avr@0.6.0"
time="2023-12-18T10:01:22+01:00" level=info msg="Loading package builtin from: C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2023-12-18T10:01:22+01:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2023-12-18T10:01:22+01:00" level=info msg="Loading tools from dir: C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.6"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.8"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.2"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.3"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.10.0"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.11.0"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.12.0"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.9.1"
time="2023-12-18T10:01:22+01:00" level=info msg="Loading package esp32 from: C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
time="2023-12-18T10:01:22+01:00" level=info msg="Missing signature file" index="C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\installed.json"
2023-12-18T09:01:22.864Z daemon INFO time="2023-12-18T10:01:22+01:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.11"
time="2023-12-18T10:01:22+01:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2023-12-18T10:01:22+01:00" level=info msg="Loading tools from dir: C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-12-18T10:01:22+01:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-12-18T10:01:22+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed\\3.3.0\\libraries" location=platform
time="2023-12-18T10:01:22+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
time="2023-12-18T10:01:22+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries" location=platform
time="2023-12-18T10:01:22+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_nano\\4.0.10\\libraries" location=platform
time="2023-12-18T10:01:22+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.13\\libraries" location=platform
time="2023-12-18T10:01:22+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\atmel-avr-xminis\\hardware\\avr\\0.6.0\\libraries" location=platform
time="2023-12-18T10:01:22+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\libraries" location=platform
2023-12-18T09:01:22.865Z daemon INFO time="2023-12-18T10:01:22+01:00" level=info msg="Loading libraries index file" index="c:\\Users\\stefa\\AppData\\Local\\Arduino15\\library_index.json"
2023-12-18T09:01:23.281Z daemon INFO time="2023-12-18T10:01:23+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\stefa\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2023-12-18T10:01:23+01:00" level=info msg="Adding libraries dir" dir="c:\\Users\\stefa\\OneDrive\\Documents\\Arduino\\libraries" location=user
2023-12-18T09:01:23.808Z root INFO Deploy plugins list: 141.2 ms [Finished 1.987 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-12-18T09:01:24.243Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 243.7 ms [Finished 1.839 s after frontend start]
2023-12-18T09:01:24.255Z root WARN A command editor.action.toggleStickyScroll is already registered.
2023-12-18T09:01:24.404Z daemon INFO time="2023-12-18T10:01:24+01:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from c:\\Users\\stefa\\OneDrive\\Documents\\Arduino\\libraries\\T-Wristband-master: invalid library: no header files found"
2023-12-18T09:01:24.408Z discovery-log INFO start request start watch
2023-12-18T09:01:24.409Z discovery-log INFO start requested start watch
2023-12-18T09:01:24.409Z discovery-log INFO start resolved watching
2023-12-18T09:01:24.419Z daemon INFO time="2023-12-18T10:01:24+01:00" level=info msg="starting discovery builtin:serial-discovery process"
time="2023-12-18T10:01:24+01:00" level=info msg="starting discovery builtin:dfu-discovery process"
time="2023-12-18T10:01:24+01:00" level=info msg="starting discovery builtin:mdns-discovery process"
2023-12-18T09:01:24.426Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\stefa\Prog\Arduino\Testen\ADXL335_Good_Code\ADXL335_Good_Code.ino>, response: <c:\Users\stefa\Prog\Arduino\Testen\ADXL335_Good_Code>.
2023-12-18T09:01:24.446Z daemon INFO time="2023-12-18T10:01:24+01:00" level=info msg="started discovery builtin:dfu-discovery process"
time="2023-12-18T10:01:24+01:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.34.0\" to discovery builtin:dfu-discovery"
time="2023-12-18T10:01:24+01:00" level=info msg="started discovery builtin:serial-discovery process"
time="2023-12-18T10:01:24+01:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.34.0\" to discovery builtin:serial-discovery"
2023-12-18T09:01:24.447Z daemon INFO time="2023-12-18T10:01:24+01:00" level=info msg="started discovery builtin:mdns-discovery process"
time="2023-12-18T10:01:24+01:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.34.0\" to discovery builtin:mdns-discovery"
2023-12-18T09:01:24.474Z daemon INFO time="2023-12-18T10:01:24+01:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
2023-12-18T09:01:24.476Z daemon INFO time="2023-12-18T10:01:24+01:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
time="2023-12-18T10:01:24+01:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
time="2023-12-18T10:01:24+01:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
time="2023-12-18T10:01:24+01:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
time="2023-12-18T10:01:24+01:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
2023-12-18T09:01:24.480Z daemon INFO time="2023-12-18T10:01:24+01:00" level=info msg="from discovery builtin:dfu-discovery received message type: hello, message: OK, protocol version: 1"
2023-12-18T09:01:24.481Z daemon INFO time="2023-12-18T10:01:24+01:00" level=info msg="sending command START_SYNC to discovery builtin:dfu-discovery"
2023-12-18T09:01:24.485Z daemon INFO time="2023-12-18T10:01:24+01:00" level=info msg="from discovery builtin:dfu-discovery received message type: start_sync, message: OK"
2023-12-18T09:01:24.539Z daemon INFO time="2023-12-18T10:01:24+01:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM4"
time="2023-12-18T10:01:24+01:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM6"
2023-12-18T09:01:24.541Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM4","label":"COM4","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-12-18T09:01:24.543Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM6","label":"COM6","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-12-18T09:01:24.544Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM24","label":"COM24","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-12-18T09:01:24.550Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM23","label":"COM23","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-12-18T09:01:24.550Z daemon INFO time="2023-12-18T10:01:24+01:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM24"
time="2023-12-18T10:01:24+01:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM23"
2023-12-18T09:01:24.619Z root WARN Frontend c.onStart took longer than the expected maximum 100 milliseconds: 228.9 ms [Finished 2.236 s after frontend start]
2023-12-18T09:01:24.668Z root INFO Start frontend contributions: 716.7 ms [Finished 2.245 s after frontend start]
2023-12-18T09:01:24.671Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-12-18T09:01:24.696Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-12-18T09:01:24.697Z root INFO >>> Restoring the layout state...
2023-12-18T09:01:24.716Z root INFO ------- SERIALIZED LAYOUT DATA -------
2023-12-18T09:01:24.717Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/stefa/Prog/Arduino/Testen/ADXL335_Good_Code/ADXL335_Good_Code.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":77,\"column\":2},\"position\":{\"lineNumber\":77,\"column\":2}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":10,\"column\":1},\"firstPositionDeltaTop\":-16},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":77,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"},{"constructionOptions":{"factoryId":"serial-monitor"}}],"currentIndex":1}},"pinned":[false,false],"size":429,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":293},"rightPanel":{"type":"sidepanel","items":[]}}
2023-12-18T09:01:24.733Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2023-12-18T09:01:24.808Z root INFO [a8cef7d2-35d7-4422-9fd0-97574741a425] Waiting for backend deployment: 184.5 ms [Finished 2.422 s after frontend start]
2023-12-18T09:01:25.327Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708) starting instance
2023-12-18T09:01:25.765Z root INFO [a8cef7d2-35d7-4422-9fd0-97574741a425] Sync of 23 plugins: 960.8 ms [Finished 3.383 s after frontend start]
2023-12-18T09:01:26.008Z root INFO <<< The layout has been successfully restored.
2023-12-18T09:01:26.078Z root INFO Initialize the workbench layout: 1328.0 ms [Finished 3.626 s after frontend start]
2023-12-18T09:01:26.080Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-12-18T09:01:26.081Z root INFO [a8cef7d2-35d7-4422-9fd0-97574741a425] Loading plugin contributions
2023-12-18T09:01:26.086Z root INFO [a8cef7d2-35d7-4422-9fd0-97574741a425] Load contributions of 23 plugins: 66.8 ms [Finished 3.695 s after frontend start]
2023-12-18T09:01:26.097Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-12-18T09:01:26.098Z root WARN a registered grammar configuration for 'cpp' language is overridden
2023-12-18T09:01:26.409Z root ERROR [hosted-plugin: 4708] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2023-12-18T09:01:26.409Z root ERROR [hosted-plugin: 4708] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
2023-12-18T09:01:26.411Z root ERROR [hosted-plugin: 4708] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2023-12-18T09:01:26.421Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): PluginManagerExtImpl/init()
2023-12-18T09:01:26.427Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): initializing(vscode-arduino-api@0.1.2 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-18T09:01:26.500Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): initializing(cortex-debug@1.5.1 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-18T09:01:26.501Z root INFO [hosted-plugin: 4708] Debugger contribution has been registered: cortex-debug
2023-12-18T09:01:26.505Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): initializing(vscode-arduino-tools@0.0.2-beta.8 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(4708): initializing(cpp@1.52.1 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(4708): initializing(json@1.46.1 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-18T09:01:26.505Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): initializing(json-language-features@1.46.1 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-18T09:01:26.511Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(4708): initializing(vscode-language-pack-cs@1.78.0 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(4708): initializing(vscode-language-pack-de@1.78.0 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(4708): initializing(vscode-language-pack-es@1.78.0 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(4708): initializing(vscode-language-pack-fr@1.78.0 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-18T09:01:26.512Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-18T09:01:26.513Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): initializing(vscode-language-pack-it@1.78.0 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-18T09:01:26.513Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): initializing(vscode-language-pack-ja@1.78.0 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-18T09:01:26.514Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): initializing(vscode-language-pack-ko@1.78.0 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-18T09:01:26.516Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-18T09:01:26.527Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): initializing(vscode-language-pack-pl@1.78.0 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(4708): initializing(vscode-language-pack-pt-BR@1.78.0 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(4708): initializing(vscode-language-pack-ru@1.78.0 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(4708): initializing(vscode-language-pack-tr@1.78.0 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(4708): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(4708): initializing(vscode-language-pack-zh-hans@1.78.0 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-18T09:01:26.539Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): initializing(vscode-language-pack-zh-hant@1.78.0 with C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2023-12-18T09:01:26.608Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): PluginManagerExtImpl/loadPlugin(C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2023-12-18T09:01:26.640Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): PluginManagerExtImpl/loadPlugin(C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2023-12-18T09:01:26.741Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): PluginManagerExtImpl/loadPlugin(C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
2023-12-18T09:01:26.802Z root INFO [a8cef7d2-35d7-4422-9fd0-97574741a425] Starting plugins.
2023-12-18T09:01:26.809Z root INFO [hosted-plugin: 4708] PLUGIN_HOST(4708): PluginManagerExtImpl/loadPlugin(C:\Users\stefa\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2023-12-18T09:01:26.891Z root INFO [hosted-plugin: 4708] Debug configuration provider has been registered: cortex-debug, trigger: 1
2023-12-18T09:01:26.897Z root INFO [hosted-plugin: 4708] GDB server console created
2023-12-18T09:01:26.908Z root INFO [a8cef7d2-35d7-4422-9fd0-97574741a425] Start of 23 plugins: 823.6 ms [Finished 4.524 s after frontend start]
2023-12-18T09:01:27.402Z root INFO Replace loading indicator with ready workbench UI (animation): 881.0 ms [Finished 4.579 s after frontend start]
2023-12-18T09:01:27.406Z root INFO Frontend application start: 3154.3 ms [Finished 5.552 s after backend start]
Checking for update
2023-12-18T09:01:27.413Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-12-18T09:01:27.414Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
2023-12-18T09:01:27.831Z root ERROR ---- !!!SLOW!!! DURATION: search took 418.907 ms. Args: [{"type":"Updatable"}] ----
2023-12-18T09:01:27.836Z root WARN A command arduino-include-library--TTGO TWatch Library:TTGO is already registered.
2023-12-18T09:01:27.845Z daemon INFO time="2023-12-18T10:01:27+01:00" level=info msg="Required tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2023-12-18T10:01:27+01:00" level=info msg="Required tool" tool="esp32:esptool_py@4.5.1"
time="2023-12-18T10:01:27+01:00" level=info msg="Required tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2023-12-18T09:01:27.845Z daemon INFO time="2023-12-18T10:01:27+01:00" level=info msg="Required tool" tool="esp32:mkspiffs@0.2.3"
time="2023-12-18T10:01:27+01:00" level=info msg="Required tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
time="2023-12-18T10:01:27+01:00" level=info msg="Required tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-12-18T10:01:27+01:00" level=info msg="Required tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
time="2023-12-18T10:01:27+01:00" level=info msg="Required tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2023-12-18T10:01:27+01:00" level=info msg="Required tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-12-18T10:01:27+01:00" level=info msg="Required tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-12-18T10:01:27+01:00" level=info msg="Required tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-12-18T09:01:27.922Z daemon INFO time="2023-12-18T10:01:27+01:00" level=info msg="Required tool" tool="arduino:dfu-util@0.11.0-arduino5"
2023-12-18T09:01:27.932Z root INFO Starting language server: esp32:esp32:XIAO_ESP32S3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=default_8MB,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default
Update for version 2.2.1 is not available (latest version: 2.2.1, downgrade is allowed).
2023-12-18T09:01:28.420Z daemon INFO time="2023-12-18T10:01:28+01:00" level=info msg="Required tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2023-12-18T10:01:28+01:00" level=info msg="Required tool" tool="esp32:esptool_py@4.5.1"
time="2023-12-18T10:01:28+01:00" level=info msg="Required tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2023-12-18T10:01:28+01:00" level=info msg="Required tool" tool="esp32:mkspiffs@0.2.3"
time="2023-12-18T10:01:28+01:00" level=info msg="Required tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
time="2023-12-18T10:01:28+01:00" level=info msg="Required tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-12-18T10:01:28+01:00" level=info msg="Required tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
time="2023-12-18T10:01:28+01:00" level=info msg="Required tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2023-12-18T10:01:28+01:00" level=info msg="Required tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-12-18T10:01:28+01:00" level=info msg="Required tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-12-18T10:01:28+01:00" level=info msg="Required tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-12-18T09:01:28.422Z daemon INFO time="2023-12-18T10:01:28+01:00" level=info msg="Required tool" tool="arduino:dfu-util@0.11.0-arduino5"
2023-12-18T09:01:28.428Z daemon INFO time="2023-12-18T10:01:28+01:00" level=info msg="Required tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-12-18T09:01:28.429Z daemon INFO time="2023-12-18T10:01:28+01:00" level=info msg="Required tool" tool="arduino:dfu-util@0.11.0-arduino5"
2023-12-18T09:01:28.433Z daemon INFO time="2023-12-18T10:01:28+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\stefa\\AppData\\Local\\Arduino15\\libraries" location=ide
2023-12-18T09:01:28.434Z daemon INFO time="2023-12-18T10:01:28+01:00" level=info msg="Adding libraries dir" dir="C:\\Users\\stefa\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\libraries" location=platform
time="2023-12-18T10:01:28+01:00" level=info msg="Adding libraries dir" dir="c:\\Users\\stefa\\OneDrive\\Documents\\Arduino\\libraries" location=user
2023-12-18T09:01:33.113Z daemon INFO time="2023-12-18T10:01:33+01:00" level=info msg="Required tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2023-12-18T10:01:33+01:00" level=info msg="Required tool" tool="esp32:esptool_py@4.5.1"
time="2023-12-18T10:01:33+01:00" level=info msg="Required tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2023-12-18T10:01:33+01:00" level=info msg="Required tool" tool="esp32:mkspiffs@0.2.3"
time="2023-12-18T10:01:33+01:00" level=info msg="Required tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
time="2023-12-18T10:01:33+01:00" level=info msg="Required tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-12-18T10:01:33+01:00" level=info msg="Required tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
time="2023-12-18T10:01:33+01:00" level=info msg="Required tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2023-12-18T10:01:33+01:00" level=info msg="Required tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-12-18T10:01:33+01:00" level=info msg="Required tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-12-18T10:01:33+01:00" level=info msg="Required tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-12-18T09:01:33.117Z daemon INFO time="2023-12-18T10:01:33+01:00" level=info msg="Required tool" tool="arduino:dfu-util@0.11.0-arduino5"
2023-12-18T09:01:33.118Z daemon INFO time="2023-12-18T10:01:33+01:00" level=info msg="Required tool" tool="esp32:mkspiffs@0.2.3"
2023-12-18T09:01:33.125Z daemon INFO time="2023-12-18T10:01:33+01:00" level=info msg="Required tool" tool="arduino:dfu-util@0.11.0-arduino5"
2023-12-18T09:01:33.125Z daemon INFO time="2023-12-18T10:01:33+01:00" level=info msg="Required tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
When i open the IDE i can see the icon at the bottom of my screen but it doesn't open. The code above is from the windos power sell.
I use Windos 10 and Arduino IDE 2.2.1
